Old 06-21-21, 06:35 PM
  #4351
Flatforkcrown
Flatforkcrown's Avatar
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times in 159 Posts
Flatforkcrown is offline
Likes For Flatforkcrown:
Old 06-21-21, 06:47 PM
  #4352
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
B.O.B done for now. Used thin two-hole conduit clips to anchor the copper to the trailer but they give under movement so I added thicker one-hole clips for reinforcement. Slotted one clip for a screw to move in that acts as a stop at the ends of the swing when deploying or stowing the stand. Now the mesh flexes so I need to add a reinforcing plate but this should support the weight I expect this thing to haul.
thumpism is offline
Old 06-26-21, 04:20 PM
  #4353
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,237 Times in 686 Posts
Modified some fenders and bent some bike bits to fit 42-622 tyres on the Koga-Miyata Graveller and redished a front wheel because my laziness caught up with me.
The rear fender cut would have been cleaner if it didn't turn out the chainstay bridge/kickstand plate was too close and needed to be bent up- and backwards.
JaccoW is offline
Likes For JaccoW:
Old 06-27-21, 07:18 PM
  #4354
billnuke1
billnuke1's Avatar
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times in 389 Posts
Atala patiently waited for it’s turn on the stand...a little Phil’s on some key areas and I was down the road! Just around the block!
Great ride, and it’s pretty! Stupid busy! Gotta find some quality ride time for this one!
billnuke1 is offline
Likes For billnuke1:
Old 06-27-21, 07:21 PM
  #4355
billnuke1
billnuke1's Avatar
Quoted: 350 Post(s)
Actually, the brakes sucked! Gotta clean the rims off!
Old 06-28-21, 02:16 AM
  #4356
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Fixed some clearance issues of the front fender using rivets.
JaccoW is offline
Likes For JaccoW:
Old 07-01-21, 11:53 AM
  #4357
leftthread
leftthread's Avatar
Quoted: 111 Post(s)
Liked 213 Times in 105 Posts
leftthread is offline
Likes For leftthread:
Old 07-01-21, 01:06 PM
  #4358
sloar
Bikes: they change so much I'm tired of updating this
Quoted: 1212 Post(s)
Liked 1,125 Times in 425 Posts
Just picked up this Vitus, every time I find a Vitus there is always issues. I had to drill out one of the shift cables out of the shifters and there’s two dings on the frame. It was missing wheels and a front derailleur, but it came with new frame decals. A friend brought me a derailleur today so I’ll be able to finish it tomorrow.
Semper fi
sloar is offline
Old 07-01-21, 02:20 PM
  #4359
rjhammett
rjhammett's Avatar
Bikes: 85 De Rosa, 92 Merckx MX Leader, 99 Tommasini Sintesi, 08 Look 585, 89 Merckx Corsa Extra, 72 Holdsworth Professional
Quoted: 362 Post(s)
Liked 549 Times in 241 Posts
I picked up this Andy Gilmour tandem recently for cheap. I did a complete overhaul and replaced the straight bars, stem, cheap friction thumbies and rear derailleur with upgraded components. I had everything except the new rear brake cable which I had to purchase.
rjhammett is offline
Likes For rjhammett:
Old 07-03-21, 12:53 PM
  #4360
leftthread
leftthread's Avatar
Quoted: 111 Post(s)
Next in this week's episode of "Seized Stem:"
After a boatload of Liquid Wrench, PB Blaster, heat on the stem plug in the steerer tube and various whacks, nothing. My body weight on the headset wrench is not budging the knurled adjustable cup on the 600 headset either. Cool Nitto stem though.
Old 07-03-21, 04:21 PM
  #4361
Prowler
Quoted: 472 Post(s)
Liked 1,028 Times in 404 Posts
I've been doing a lot of repair to the horse barns as horses get pretty bored and chew on things. That includes painting and, today, while waiting for the paint to dry I decided to make a proper FW holder. I've had a rough one of these cobbled together. I clamp it into my strong vice and it holds very well while I use "the mother of all chain whips" to loosen the screwed on cogs, as needed. I decided I should have a well made one, suitable for the four sizes of large cog I have in my collection. Simple but effective.
You can see the cog sizes written near each set of screw holes. Easy. The goop in the screw holes is bee's wax to lubricate the threads, making repeated insertion and retraction easy. Screws are about 25 mm long. The lumber is 1 1/2"
Prowler is online now
Likes For Prowler:
Old 07-03-21, 04:29 PM
  #4362
SkinGriz
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times in 582 Posts
So cogs are just screwed onto a multi speed freewheel? Similar to how the freewheel screws unto the hub?
SkinGriz is offline
Old 07-03-21, 05:36 PM
  #4363
Prowler
Quoted: 472 Post(s)
I cannot make a broad sweeping statement like that. My fav FWs (Suntour) vary over the years. Some have only the first cog screwed on, others 2 or 3. The rest are splined on. The design changed over the years. I'm not too familiar with Shimano or others. pastorbobnlnh is the foremost authority. As with all things Bicycle, you have to study, ask questions and "conduct unspeakable experiments" to learn all that stuff.
Many folks do not care as they would never consider disassembling a FW and servicing it. I have the skill set, the tools and the time. And it amuses me.
Old 07-03-21, 07:12 PM
  #4364
SkinGriz
Live not by lies.
Quoted: 860 Post(s)
I think the knowledge would be useful and fun to pull the cogs off a cheap 6 speed. Turn into a single speed by reinstalling one cog and changing where that cog is to get chain line straight. Like a ghetto cassette system.
I didn’t have a freewheel tool when I pulled freewheel off one of my kids bikes to give her easier gearing. Saw all the tiny balls as I destroyed it.
Determined that if a freewheel needs more than synthetic auto oil/gear oil/ATF to wake it up- then it’s beyond what I’ll deal with.
SkinGriz is offline
Old 07-03-21, 07:46 PM
  #4365
SkinGriz
Live not by lies.
Quoted: 860 Post(s)
Thank you prowler for bringing this up. For some reason I thought they were pinned together or something.
Thank you RJ. Calvin Jones. Sheldon Brown.
SkinGriz is offline
Old 07-04-21, 03:59 PM
  #4366
bikemig
bikemig's Avatar
Quoted: 5885 Post(s)
Liked 3,468 Times in 2,078 Posts
1973 Raleigh Grand Sport
I've been working on a '73 Raleigh Gran Sport. It's a 22 and a 1/2 (57) CT so I think it's my size but it does look a bit small. I may have to run a tallish stem to make this fit right. It has nice zeus drop outs but the PO chopped off the hanger and used a raleigh branded suntour on a hanger. The bike has been spread to 126 mm. The frame is in nice shape paint wise. It's missing the Carlton decal on the seat tube and the 531 stickers but I can get those from VeloCals. It came to me with a very nice brooks leather saddle, a nifty 13-30 7 speed Maillard freewheel, and nice quality suntour derailleurs and shifters. The wheels are mismatched but they're in good shape as well.
It has 3 issues.
(1) There is some rust on inside of the seattube. I've never done an OA bath but I'm likely to try one out on this bike.
(2) The seat tube is out of round so that a 27.2 doesn't fit right. The existing seatpost is tight as heck. I may just sand the existing seatpost until it inserts right and call it a day.
(3) The crank dust cap is stuck. I carved out a flat for a screwdriver using a dremel tool and I've hit it with PB blaster but so far no dice. I think I'll try some freeze off next.
I finally found a bike that even gugie might like.
bikemig is offline
Old 07-04-21, 04:10 PM
  #4367
natterberry
natterberry's Avatar
Bikes: ‘83/‘85 Trek 760, ‘82 Trek 614, ‘77/‘78 Trek 304, ‘74 Raleigh International
Quoted: 285 Post(s)
Liked 220 Times in 138 Posts
Very nice @bikemig. Almost identical to my Competition (paint, Zeus dropouts)
I also think that mine looks small, and have to break out the tape measurer to reassure myself.
natterberry is offline
Likes For natterberry:
Old 07-04-21, 04:29 PM
  #4368
bikemig
bikemig's Avatar
I like the white and blue a lot. I've looked for one on and off for a while but it was tough finding one in a 22 and 1/2 for some reason. I hope we do that SW WI ride one of these days again. That's a heck of an area to find some hills to ride in.
bikemig is offline
Old 07-05-21, 06:44 PM
  #4369
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 874 Post(s)
Liked 2,297 Times in 1,109 Posts
I have this old Schwinn Suburban I had to buy as part of a bundle and I've almost literally been kicking it around the garage as it was just stuck together for the seller to take pictures of. That combined with never getting anything more than the dose of Cosmoline or whatever they used made it hard to move around. While it is pretty much in survivor condition, it is rough and I don't think there is any sense in the labor I'm putting into it let alone what it is going to cost to put new cables on it. I grew up poor and never imagined I would ever own a Schwinn and seeing how these things were built I think I did better with the second hand bikes my dad bought me when I was a kid. I just don't have any love for this thing but I'll get it ridable anyway. I think I just like the hubs.
Chuck M is offline
Likes For Chuck M:
Old 07-06-21, 08:57 AM
  #4370
noglider
noglider's Avatar
Quoted: 7333 Post(s)
Liked 2,430 Times in 1,419 Posts
@bikemig, you and I have very similar tastes.
noglider is offline
Likes For noglider:
Old 07-06-21, 10:16 AM
  #4371
daverup
daverup's Avatar
Bikes: A bunch of old bikes.
Quoted: 275 Post(s)
Liked 853 Times in 411 Posts
Picked this 2002 LeMond Buenos Aires, I've been working on the overhaul.
As found,
Today, still waiting on some new tires,
daverup is offline
Old 07-08-21, 03:26 PM
  #4372
djkashuba
djkashuba's Avatar
Bikes: Motobecane Le Champion, Raleigh International, Bertin, Raleigh DL-1 1980, Colnago Super,Follis, Bianchi Competizione, Brompton M6L, Black Mountain Monstercros
Quoted: 125 Post(s)
Liked 839 Times in 151 Posts
Damn.
by djk762, on Flickr
djkashuba is offline
Likes For djkashuba:
Old 07-08-21, 04:06 PM
  #4373
leftthread
leftthread's Avatar
Quoted: 111 Post(s)
Thanks again to pastorbob, iirc, for the dental floss trick to hold the pawls.
Old 07-08-21, 07:51 PM
  #4374
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1360 Post(s)
Liked 2,175 Times in 1,180 Posts
I've been away from cycling related stuff for a while and while not bicycle related I have been "wrenching" on a number of things that have been in need some attention. All of the glazing failed on the window at my backdoor. Some of the aluminum bars were damaged during the initial instal which caused the leaking and are no longer available from the manufacturer so I had to do a bit of fabrication. Cut and file along with glazing tape and a bit of silicone and it should be good for a few more years.
2 more aluminum pieces to fabricate and I am done...luckily no broken glass, but a B .;2h to get it out of the frames.
Threshold is next, along with the ADU.
Best, Ben
Voltaire
xiaoman1 is offline
Likes For xiaoman1:
Old 07-08-21, 10:48 PM
  #4375
Nemosengineer
Nemosengineer's Avatar
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times in 245 Posts
I have been away for a while due to work and other stuff, I have been playing with my Mini Cooper, a chassis upgrade has kept me busy collecting parts. It's morphing into a dual purpose track day car and world class bicycle hauler.
Untitled by nemosengineer, on Flickr
AST Coilovers with 7 Kg Swift springs and spherical ball mounts with adjustable camber.
M7 Maxx G control arms and sway bar end links
Powerflex race bushings on control arm mounts
A set of new modified engine and trans mounts (much stiffer) and a racing torque link. in addition all ball joints and steering bits have been replaced, As usual I'm waiting on sway bars and various other bits to show up from Germany, a major brake upgrade is also in the works.
My R55S still on the stock suspension.
: Mike
Booyah Hubba-Hubba!!!
Nemosengineer is offline
Likes For Nemosengineer:
