Homebrew chain clean and homebrew hot wax
#51
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
I started using wax last summer and found it worked well. It may have been that I cleaned everything thoroughly before applying it and had I done the same and oiled it. I did find it seemed to attract lest dust which was a goal.
This winter I went back to oil, just because of frequency of application needed.
My waxing method is simply.
Clean chain with mineral spirits, wipe down and let dry. Place in crock pot with melted wax that has a small amount of kerosene added.
Let chain sit in wax until I stop seeing bubbles come out from the links. Turn off the crock pot (if not already off) and let cool until a skim coat starts to appear on the surface and then remove chain. I feel letting the wax cool slightly before removing the chain lets more wax stay on the chain. This is based on how much wax dripped off the chain when I hung it to dry the first time I didn't let the wax cool. It may not matter for your results.
#52
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I've got my ultrasonic cleaner and crockpot ready to go. I used to wax chains about 25 years ago but when that bike got stolen I never got around to doing it on the next bikes. I cleaned up the drivetrain of my Brompton this winter, and was inspired to get back into it, mostly for the cleanliness. This thread has been helpful!
So, I have two questions.
1. The ultrasonic cleaner has a heater built in. I'm not sure if it will get hot enough to melt the wax (I think it will), but do any of you think there would be an advantage to soaking the chain in molten wax with the ultrasonic vibrator on? Maybe gets the wax deeper into the nooks and crannies? I tend to think it would work the same, but I'm curious about opinions. Any negatives? I might just try it, and if it works reasonably then return the crockpot (and get my $8 back, haha). If it's the same then I'll keep the crockpot and just leave the wax in it, as suggested above.
2. I was moving things around in the garage and came across an old citronella candle. Do you think if I melted down and used that wax, it would keep away the mosquitoes during summer rides? :-)
#53
Quoted: 8 Post(s)
I hope the wax comes out clean as a block when it solidifies. If it does, I might have a crockpot to get rid of...
I was a little disturbed about how much dirt came off my old chain!
Also, I was pretty surprised that the mineral spirits didn't dissolve off all the grease from the new chains I cleaned. After soaking and sonicating for about a half hour, a lot of grease came off of the chain onto a rag. Makes me wonder if there's more grease still on the insides. Maybe I'll try MEK next time.
FWIW, I put the Dupont wax-based Teflon spray onto the cassette and derailleur cogs, to help with friction there.
#54
Why, oh why, oh why do people come up with these complicated cleaning methods for chains? They make absolutely no chemical sense...that answers that question...and are often counter productive.
Your cleaning "method" is overly complicated and has too many unnecessary steps. Let's start with your "mixture". Kerosene by itself would do the job. No need for the transmission fluid nor the intake cleaner. I'm not a huge fan of kerosene since it is a bit oily and doesn't evaporate cleanly. If you had used mineral spirits, you could have stopped right there and skipped to step 4 with a little bit of air drying in between.
Everything else you did...the alcohol soak, the excessive water treatment (5 times really!?) and the bake out of the water...were totally unnecessary and possibly damaging. The alcohol soak wouldn't have damaged the chain but boiling it in water up to 5 times just encourages oxidation of the steel.
Finally, there is the "hot wax". I've tried it in the past but never found it to be a superior method. All hot wax is is liquid wax. There are other ways to liquify the wax without heating it up. Solvents work just as well as heat and make the wax a whole lot easier to apply.
Yes, I'm talking about wax based lubricants. Drip it on, let the solvent evaporate and ride. Easy peasy. Don't make it hard when you can keep it simple and get the same result.
#55
Non omnino gravis
Drip-applying wax will never work remotely as well as immersion in hot wax. Source: I've tried both. As far as solvent-carried wax, Squirt is pretty good, White Lightning is terrible. Melted paraffin is better.
The only thing that approached the service interval/performance of hot wax was Muc Off Extreme Hydrodynamic, which was also the key to the grimiest, gnarliest drivetrain ever. Turned anything that even looked at it jet black.
#56
Quoted: 1163 Post(s)
Liked 442 Times
Well, I cleaned and waxed three chains successfully. I don't know if it made a difference or not, but I did use the heated ultrasonic bath for doing the wax too. It took a while to melt the wax, but once it was melted it got good and hot (almost 100C).
I had the same experience as you (when trying to clean the chain) with noticing how much crud came off the chain into the mineral spirits. I tried an experiment and again used the hot water bath/ultrasonic and put the dirty chain in a container with clean mineral spirits and ran several 20 minute cycles. For 1 thing I would say that other than some fumes, nothing exploded - haha...
But I did have to decant off dirty mineral spirits 3 or 4 times until I was happy. The detailed instructions on the Molten Speed Wax website suggest starting with a new chain and cleaning it really clean. I now understand why they say that. After you are satisfied the majority of dirt is gone from the mineral spirits, they recommend running it through denatured alcohol a couple of times. They say that this step is important - apparently it gets rid of mineral spirit residue. I know all this sounds anal retentive to go through so many steps but hey, it’s the winter time - the results so far are actually promising, so this may not be a waste of time!
I plan to take a coat hanger and bend it up for a better swishy tool to improve the waxing. I do believe that the ultrasonic action might have given improved penetration of the wax since I did see fizzy bubbles emanating from the wax/chain while the ultrasonic was running. As I said, I have not road tested my chain yet but will soon so I can give a future update. Molten Speed Wax give an estimate of 400 miles of riding that a chain is good for before it needs a refresher.
PS: I think that the power of the ultrasonic matters. I bought a 3.5 gallon “Prosonix” unit that is heated. It has 6 ultrasonic transducers. The power is decent but could be even MORE powerful. Putting the dirty chain directly in the hot water (without the Pyrex bowl) with simple green added MAY be as effective (or more effective) compared with mineral spirits - the jury is still out on this. Once the chain comes out of the simple green it needs to go through the denatured alcohol to push the water out. I have had some disappointing flash corrosion crop up - kind of disappointing after going through so many steps...
#57
Quoted: 8 Post(s)
I wonder if the number of transducers relates to the size of the ultrasonic unit? I got a little 2 liter, heated unit on ebay, and it seems pretty strong (compared to my wife's jewelry cleaner).
I did the denatured alcohol step in a Tupperware, sloshing it around the chain for a while. Just one treatment. I guess I forgot that they recommended two rounds. The ultrasonic unit specifically said no flammable solvents. I was willing to do the mineral spirits in it, under close supervision, but I thought it would be too dangerous to put denatured alcohol in it.
Did you get grease and crud wiping off on a rag, even after your last mineral spirits treatment?
Also, by the way, after I put the waxed chain onto the bike and spun the pedals a while, there was wax flaking off as expected, but also some little black bits. I cleaned the drivetrain so thoroughly that I find it hard to believe that it came from the cogs or derailleur. I'm wondering if it worked its way out of the insides of the chain. And now I'm wondering if it was a one-time event, and so I should rewax before running the bike.
Anyone else have a similar experience? By the way, this was with a new chain.
#58
Liked 442 Times
I noticed all those flakes but to me you should just ride the bike and re-evaluate after you ride. I suspect it will continue to flake off and actually become a bit cleaner looking after riding it some.
I'm using the Molten Speed Wax which has additives. I suspect that these additives are what gives the wax a grey color. What is the color of the wax you are starting with? If what you are seeing on your chain is significantly darker than the wax you are starting with then my guess would be that you maybe didn't get your chain as clean as you could have.
#59
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Most of the wax based lubricants use mineral spirits or a related solvent mixture. There is a limit to how much wax you can dissolve in the solvent but that limit is fairly high. Most wax based lubricants also aren't just canning wax in a solvent. They have other materials in there to modify the crystallinity of harder waxes. There is also a bit of teflon in the mixture as well as soft waxes.
Based on what metric? Using heat just makes the wax fluid. Adding solvent makes the wax fluid. Both will penetrate as well to where it is needed. I, too, have tried both. The involved process of removing the chain, melting wax, dipping chains and reinstalling is far too tedious for the short interval between applications.
Compare that to simply dripping on lubricant and letting it dry. I suspect that the mileage before the chain wears out is similar and, from my experience, the mileage between lubricant application is similar...or even slightly longer in the case of the solvent based wax lubricants. Even if the application interval was a bit shorter for solvent based wax lubricants, the convenience of application far outstrips that of hot wax.
And why do you feel White Lightning is terrible? I haven't tried Squirt so I won't comment but White Lightning hasn't had any downsides for me in nearly 20 years of use.
Stuart Black
Stuart Black
#60
Non omnino gravis
Compared to White Lightning alone, hot wax is cheaper, cleaner, and lasts longer.
#61
Liked 442 Times
Hey, cyccommute: If White Lighting works for you, that's great. Unfortunately my experience with the White Lighting was much like DrIsotope below, so I say +1 to that.
I had so much squeaking with the White Lightning, along with massive wax build up on my derailleur pulleys - that it turned me off to wax based lubes for years. I've been using wet lube for the last 8 to 10 years with decent results but the dirtiness, need for frequent re-application and what seems to be accelerated chain wear on the KMC and SRAM chains that I have been running has made me want to try the melted wax technique.
The first time you do it, sure wax is going to take a longer time. But I suspect that with practice, this procedure will speed up considerably.
My experience is limited to the blue-label White Lightning. The required quantity of application, combined with how short a period of time the stuff actually lasts, puts it all the way at the bottom of the list of chain lubes I've tried. I've found no other lube that lasts for fewer miles than White Lightning. it's likely fine for MTB guys who apply before every ride and put in a handful of trail miles, but I averaged almost 38 miles a day last year, and am sitting around 40 a day this year. A lube that requires daily application is not what I'm looking for.
#62
Non omnino gravis
^^^ This mirrors my experience exactly. Wet lubes are excellent, except for the mess. The initial application of hot wax is a bit tedious until you're used to the process (now I spend about 10 minutes every other Tuesday to do 2 bikes) and White Lightning is always terrible-- I had mentally blocked out the encrusted horror of White Lighting covered jockey wheels.
#64
Liked 4,217 Times
As to wear, I don't see any wear that I would call excess nor do I get mileages on my chains that is shorter than most other people report.
Sorry but I'm not buying the 10 minute time frame. It takes longer than that to melt a sufficient amount of wax to dip a chain. Add in the time to remove, dip, cool and reinstall the chain and the time has to be longer than that.
You also seem to be getting a lot less mileage out of hot waxing than I get out of White Lightning. I can (I've actually measured it) go 600 to 700 miles between applications. For your daily mileage that's 2 to almost 3 weeks.
As for "the encrusted horror", that is because people try to get the same noise that they get with wet lubes by drowning out the sound of chain noise with wax lubricants. I have seen jockey wheels encrusted with wax from the over use of White Lightning but I've also see jockey wheels encrusted with near boulders from the over application of wet lubes. White Lightning really doesn't need to be applied as frequently as some people think.
Stuart Black
Stuart Black
#65
Quoted: 8 Post(s)
Just fill the tank with water then put a container with the denatured alcohol in the basket.
I'm using pure paraffin wax. I understand that MSW can have molybdenum powder in it, which gives it the grey color. I don't know whether it would rub off and stain fabrics, but I'm avoiding it to keep it clean (and simple).
#66
#67
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
the hot wax method I found to be a fun and relaxing experience.
#68
No, not from my experience anyway. I have tried kerosene, OMS, denatured alcohol and benzine (white gas). None seem to work. Google suggest xylene but that, to my recollection, is nasty smelly stuff and I cant imagine xylene is what is used as a solvent in commercial wax lubes.
#69
Quoted: 4559 Post(s)
Liked 2,802 Times
Ditto, the method @DrIsotope described.
Once you set up a method it's quick, efficient and clean. I swap once a month between a pair of identical chains, KMC Z72 with Missing Links. The used chain goes into the crock pot of paraffin.
Melt the paraffin in a crock pot (I think we both use the Li'l Dipper?) and just leave it in the little pot. Plug it in at the end/beginning of the month or whatever your preferred maintenance schedule is. I do it in stages, so it's probably 10-15 minutes total spread out over a couple of days.
I don't worry about how long the chain is in the crock pot. When I'm busy I've left a chain for a few days. Doesn't hurt anything. I use hanger loops made from bent paper clips to hang and drip the chain. When it cools I coil it up and store it in a ziplock baggie for next month.
I don't worry about wiping the freshly waxed chain clean. On the first ride any excess flakes off. No accumulation on the drive train that would leave wax crumbs indoors.
That's an advantage to a leisurely soak in the crock pot. The chain gets hot so when I fish it out to drip dry most of the excess stays liquid and drips off cleanly. But a quick run through on a cool chain would cause the wax to congeal more quickly and leave more excess.
My only recent regret is swapping my road bike temporarily to a conventionally lubed chain, around late November I think. I was experimenting with chain lengths to check the effect on drive train tension -- on my '89 Centurion Ironman it felt like the tension was excessive in the largest freewheel cogs (21 and 24, I think), mostly due to the heavy tension of the cage pivot spring in the Suntour GPX derailleur, which wasn't adjustable. I wanted to experiment with adding a few links, but I happened to have an oiled chain that was already the right length. So I swapped that on.
Now I need to clean the chainrings and freewheel again before switching back to the paraffin treated chains. Just running the bike the past few weeks has made a mess of the drive train -- the city spread sand everywhere in anticipation of ice storms (which never happened).
I'd have saved more time in the long run if I'd just added a few links back to the waxed Z72 chains. The "easy" route of temporarily using an oiled chain will take more time in cleaning.
Once I switch the road bike back to waxed chains, and convert the hybrid to wax, I'm sticking with it. For our climate with only moderate wet weather it's ideal.
#70
So I tried hot waxing my chain and it sounded sort of dry after one 25 mile loop in cold damp weather? Du you cut the paraffin with oil or something? I re-waxed and mixed in 1/4 sae 30 oil I had on the shelf. Testing tomorrow.
#71
Liked 2,802 Times
I've used only plain Gulf wax. I melt three bars in a Li'l Dipper crock pot, then dunk the clean chain and let it soak overnight. A couple of hours would probably be adequate. I want to be sure all the bubbles are out of the friction surfaces and the paraffin has time to penetrate.
Also, when the chain is thoroughly hot the excess wax will drip off more readily and cleanly, leaving very little external residue. When I tried just running a cold chain through the paraffin it didn't seem to penetrate and the wax cooled quickly, causing more buildup. So I prefer the long soak.
Regarding chain noise, I've found the chain to be nearly silent for the first 100 miles or so. Gradually I'll hear a bit more noise but it never sounds like the chain is dry or desperately needs to be re-waxed. I just arbitrarily chose an interval of one month or 400-500 miles to remind myself to do it near the end or beginning of every month. I use two chains so one is always ready to go.
It's difficult to judge lube intervals by chain noise alone. Every wet lube I've tried makes the chain silent for the first ride. Then it's noisier and pretty much remains audible for weeks or even months.
Tonight I'm swapping back to waxed chains on the road bike because the oiled chain I used in December-January was covered in grit from sanded streets in preparation for winter icing. That chain was new two months ago but I'll probably discard it rather than messing with trying to clean out that grit.
In contrast I'd ridden my waxed chain comfort hybrid/errand bike for months including on gritty sandy limestone trails and gravel without the chain needing any attention.
#72
Non omnino gravis
I've read tale of folks using Coleman lantern fuel (white gas) to make the wax liquid. Some guys will dip the chain only once, then maintain the wax by dripping on paraffin melted in the white gas. Seems an option, but dipping it is plenty easy on it's own.
#73
Liked 4,217 Times
But, if you insist on making your own, I would start with mineral spirits. I suspect that when you have tried to dissolve the wax in the past you probably did it will a block. You should grind or shave the wax to size reduce it and dissolve smaller particles. You need more surface area because the wax is somewhat crystalline and can be slow to dissolve. A stirrer of some kind and time...perhaps lots and more if the particles are large...may also be needed.
Heat might also help but be careful! While less flammable than other solvents, mineral spirits does have a flash point of around 50°C (some mixtures can be lower). For the metrically challenged, that's 122°F which ain't the hot. Don't do it in your house. Outside would be best or, as I said above, just buy the commercial stuff.
Frankly, the whole "wax your chain" thing is kind of a case of spending a lot of money...double boilers, crockpots, elaborate cleaning schemes using expensive equipment, constant removal of the chain, etc... on a cheap part to save a few pennies. Buy cheap chains which are just as good as the expensive ones and change the chain when it wears out. All the elaborate cleaning and lubricating schemes aren't going to get you much more mileage than less elaborate schemes.
"White gas" is just petroleum naphtha which is a slightly different cut of the petroleum distillation than mineral spirits. They are so closely related as to have no effective difference in solution properties.
Stuart Black
Stuart Black
#74
Non omnino gravis
The OZ Cycles guy uses Xylene for his homebrew wax, and we can't get that either.
#75
First, I wouldn't bother with a DIY lubricant. Someone else did the work to come up with a mixture so why try to reinvent the wheel? I'm not against experimentation, research and development...I do it for a living...but if you are trying to save money by "sticking it to the man", you won't. You have to come up with a mixture, test it, tweak it, test it some more, ad infinitum. You'll waste a lot of materials and time testing and tweaking and, in the end, spend a whole lot more than it you just bought the commercial stuff. I could easily see spending $1000 on equipment and materials to save $15.
In relation to elaborate cleaning and spending a lot of money on equipment. Thats not me, at all. My fist cleaning of the chain, after using the factory lube, was shaking in a jar of OMS to get rid of the dirty grease. Now I just melt a few t-lights in a old, small sauce pan over a low gas flame, dump in the chain, swish it around for a minute, take out the chain and discard the now blackish, left over wax. This way the chain is cleaned and lubed in one go, with no cleaning chemicals involved. Honestly, it only takes a few minutes and all I have spent is 3$ on a bag of 50 t-lights. I dont think the elaborate methods with ultrasonic cleaners and crock pots, that take forever to heat up, is worth for me.
If I could find an oil that didnt stink when heated, I would add in some oil and then I could also just apply some to the chain if it sounds dry and I cant be bothered waxing it. It will then all come of in the next waxing. I remember from my youth we had castor oil for RC engines. I was thinking about getting some or an other vegetable oil. Any thoughts?
