What the fork????
What the fork????
I am in a predicament where I need to replace my fork (got into an accident), and now I can't seem to find a replacement fork that meets the specs below. Can anyone help point me in the right direction?
700C CARBON CROSS/GRAVEL FORK,
STRAIGHT STEERER: ALLOY( 1-1/8"),
CROWN: 45mm,
BLADE: CARBON STRAIGHT W/FLAT DISC MOUNT W/EYELET,
OFFSET:45mm ( UD WEAVE )
Fits Most 700x40c Tires (29x1.5inch),
QUICK RELEASE AXLE
CROWN: 45mm,
QUICK RELEASE AXLE
Quoted: 4199 Post(s)
Liked 3,851 Times
Many consider axle to crown seat distance an important spec too. Have you tried your LBS and search engined it on line already? Andy
AndrewRStewart
AndrewRStewart
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
how much do you wanna spend? ritchey and whiskey make some nice forks fitting your criteria
sorry I’m a bit of a novice to all this. I copied and pasted the specs from the website i bought it from. Not sure what you mean by LBS but I have been searching using the specs in the original post.
Liked 3,851 Times
Likes For Andrew R Stewart:
Quoted: 2026 Post(s)
Liked 1,096 Times
What model and make of bike was the old fork on? Can to manufacturer sell you a replacement?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
@jaydfos you might check out ebay. there's a bunch of forks there
Quoted: 714 Post(s)
Liked 800 Times
Soma has one that will work. It has a bit more rake, but that shouldn't be a huge problem. 1 1/8" steerer and QR dropouts make it kind of a Unicorn in the current tapered steerer/thru axle market.
https://www.somafabshop.com/shop/pro...-blk-48mm-3283
Likes For dsaul:
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
You can also consider any number of high quality chrome-moly steel forks, such as available from Soma, Surly, and others. Something like a Disc Trucker fork would probably work well. It'll be heavier than a carbon fork for sure, but also a third the price.
Likes For hokiefyd:
Thanks and sorry about that!
Sorry! Motobecane Omni Strada Sport
Alibaba actually just sent me the incorrect fork. Supposedly they are going to have a replacement made but we shall see.
Quoted: 513 Post(s)
Liked 448 Times
