Small rust cleanup on paint
Quoted: 1872 Post(s)
Liked 692 Times
How do you guys like cleaning up small rust spots that are on paint, not chrome?
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 206 Post(s)
Liked 460 Times
You could just use an emery board or really small wire brush. I'd use of those little brass brush dremel attachments. I bought one of those like $10 piece of garbage rotary tools from Harbor Freight just for things like cleaning rust, and polishing small aluminum stuff. It's too weak to get away from you and gouge your frame or parts, but it'll clean that up in no time. My other Dremel is way to unforgiving for that kind of work. Then just touch it up with some model paint.
Quoted: 1557 Post(s)
Liked 1,733 Times
Evaporust Gel. Slop a thick gob of gel onto that rust spot, and then immediately cover it up with saran wrap. The key is to not let it dry out too soon. Unwrap it half an hour later. Wash off with soapy water. The rust will come right off in black clumps.
And then you use these sanding q-tips to sand remaining rust out and feather-edge the edge of the paint:
Quoted: 3015 Post(s)
Liked 3,792 Times
Scrape it off with an x-acto knife.
Edumacator
Quoted: 2436 Post(s)
Liked 3,118 Times
I sort of do both...scrape with exacto, then evaporust...
Edumacator
Liked 3,118 Times
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
1. scrape off rust
2. Evaporust
3. I bought at ACE years ago https://www.amazon.com/Ospho-605-Met...000C02CDG?th=1
4. paint
Evaporust + Ospho is a great combo for small parts including chromed bits
2. Evaporust
4. paint
Bikes: A few
Quoted: 289 Post(s)
Liked 195 Times
I have an older Paasche air eraser, which is basically airbrush sized, but is actually a miniature blaster/etcher. Harbor Freight sells a version.
https://www.harborfreight.com/air-er...kit-69277.html
