New Wheel Recommendation
Quoted: 60 Post(s)
Liked 195 Times
Hi All,
Looking for recommendations on a new wheel set for an early 80's 10 speed that currently has 700cm rims, 5 speed freewheel, with a 100m front and 126mm back spacing. Rim width to fit 28-32mm tires.
Budget is $200-$400.
Thanks in advance.
Thanks in advance.
Quoted: 1944 Post(s)
Liked 2,164 Times
There are a few thoughts.
The easiest route is to cold set the frame to 130mm freehub and buy a new cassette compatible wheelset.
If you do not want that route; non-steel frame, one way is to find NOS, or excellent, freewheel hubs and build the wheel with modern vintage looking rims, like a TB-14. Probably cost more than your budget.
Another option is to find an NOS, or excellent, vintage wheelset.
One option I don’t like is a new freewheel compatible wheelset. Unfortunately, these are usually low quality since no one makes high quality freewheel compatible hubs these days.
I’ve gone the old freewheel hub/build route, but lately the way I have gone with is to get a 130mm freehub and swap out the freehub body; 7 speed in place of the 8-10 speed.
I’ve done this where I can’t cold set. It does take a bit of work and an understanding of what you can swap. You do need to have the cones and seals, so it can be somewhat expensive without any stash.
John
John
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
You will almost certainly be able to put a 130 spaced wheelset in your frame without cold setting. If you already have one, try a test fit.
Quoted: 3810 Post(s)
Liked 6,698 Times
Hard to beat his deal: https://www.velomine.com/index.php?m...itililma04v1l0
Likes For nlerner:
Bikes: 1970's Piasentin Super Vitus 971, 1979 Carlton Professional, 2005 Trek 5000, 2011 Niner EMD, 2018 Argon 18 XRoad, 1990 Diamondback Master TG Centurion
Quoted: 56 Post(s)
Liked 73 Times
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
I was able to find a wheelset with Shimano 6200 freewheel hubs and Mavic Monthlery Pro rims for only $50 on Facebook Marketplace. A little elbow grease, some new bearings and some ACTUAL grease later, and I have a nice set of wheels for my bikes with 126mm dropouts. I did have to scrape a lot of old tubular glue off the rims, but in the end, $50 for a wheelset? Can't beat that!
Quoted: 60 Post(s)
Liked 195 Times
Thanks everyone for your input.
I don't own any 130mm wheels so don't know if it would fit for sure but good to read its definitely possible. I own a number of new freewheels so prefer not to change to cassette if possible.
I did see the velomine deal. The price seems right at <$200, but really didn't see any other options. So is that really "it" for available newly manufactured 126mm freewheel 5/6 speed wheels?
Again, thank you all.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
If you want to make your own wheels (or have them made) Velo Orange has some fancy looking 126mm freewheel hubs:
https://velo-orange.com/products/gra...heel-hub-126mm
front hub:
https://velo-orange.com/products/fro...ilver-and-noir
front hub:
Quoted: 60 Post(s)
Liked 195 Times
front hub:
front hub:
Liked 2,164 Times
Origin 8 hubs are made by Formula. I’m not sure that would be my first choice.
I know it is not a popular option, but I have purchased a number of good used wheelsets off of eBay and they have worked out.
It does take a bit of time and research. Check out sellers and ask questions. There are some good ones out there.
John
John
Likes For 70sSanO:
