Drivetrain Suggestions for Vintage 1x Build?
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 67 Post(s)
Liked 19 Times
Hey guys -
So, long story short, I have two Bridgestone MTBs - an MB6 and an MB3. I broke the freewheel and hub on my MB6 which eventually prompted me to decide to move all of the 3x7 Deore parts from the MB3 onto the MB6 and to build the MB3 with a 1x setup. I already got a new wheelset with a compatible hub, and I ordered a new crankset with a 32T N/W chainring. The last thing I need to decide is what kind of drivetrain to go with.
As I see it, I have a couple of options and a couple of questions:
1. Will an 11 speed MTB cassette fit on an 8/9/10 sped hub? If so, is there a major reason to go with 11s over 10s?
2. Regardless of whether I go with 10 or 11s, for NEW options I could go with a Deore setup like this or potentially a Box Two setup like this or even a Microshift build. For those of you who have experience with these, which would you go with?
3. On the flip side, if you guys think I can get better bang-for-my-buck going with USED component, what would you recommend going with? I've found some Deore XT 10s stuff for about $40-50 for an RD and $30-40 for the shifter. Anything else I should look for?
4. Anything else I should be thinking about?
Thanks!
The MB-3 as it currently sits today.
The MB-6 before its freewheel/hub failure.
Thanks!
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I see no reason to get an 11 speed. The newest drivetrain I own is 10 speed, I only went with that to get a clutch derailer. If you can get everything in 1 box, that is great. You will spend more in shipping than it is worth trying to piece together used vintage parts.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Any shimano style 11sp mtb cassette will work on your 8-9-10 sp hub.
10 vs 11 really just comes down to the range and gear spacing YOU want/need. Nobody else can possibly answer this question for you.
For the overall range.... Best thing to do it figure out what the highest and lowest gear ratios are that you used with your 3x7 setup, and go from there. Or if you tell us we can help you with the math to figure out how that translates to 1x.
As for gear spacing.... are you OK with the spacing between ratios getting wider than you have with your 3x7?
Are you using this strictly for trail riding, or for a mix of trails and roads?
Without answering the above questions, you may as well be asking people what shoe size they like.
Likes For Kapusta:
Quoted: 67 Post(s)
Liked 19 Times
Hey - thanks for the response.
1. I currently have a (28-38-48) up front and a 12-28 on the back, giving me a low (or high? easiest gear) of 1.00 and hardest gear of 4.00. I rarely use the the 48 ring as I mostly ride trails. I do sometimes ride to the trails, but the main ones I do are 2-3 miles from my house and I don't mind having to go a bit slower on the way there.
2. With a 32T up front and a 11-42 in the back, I would have an easiest gear of 0.76 and a hardest of 2.91. What would the theoretical max speed of the 2.91 be then? Should that be enough for riding on flats?
Thanks guys.
Quoted: 186 Post(s)
Liked 234 Times
32/11 would give you 21.5 mph spinning 90 rpm. That is about what I spin on the road.
Lets clarify something any cassette that starts with an 11 tooth will fit on a your 8+ speed freehub any that starts with 10 will not. So you could even go 12 speed if you wanted. I currently run an 11 speed XT and Box 1 setups on my mtn bikes and both are fine but I do prefer the XT shifter. MIcroshift, Box, Deore whatever. I'd just want to spend as little as possible on that bike so even one of the 8 or 9 speed wide range setups from Microshift and Box would be fine if the price is right. The reason to go more gears is tighter spacing which is nice on my road bike but I really don't care on my mtn bikes. Only thing I care about is range on my mtn bike.
Likes For Canker:
Quoted: 67 Post(s)
Liked 19 Times
Thanks!
You even can use the 11-50 12 speed cassettes from SRAM or Sunrace.
These days, just go 12. You will appreciate the range and gaps. Go with Shimano, not that hackery.
Or 11 speed with the 11-51 Deore cassette.
Look at gearing calculator. Obviously all gearing advice depends on your riding and fitness.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Direct mount was something Shimano wanted to try about ten years ago, but they got run off the road by the success of SRAM’s 11 speed. I don’t know what its present support status is, but most stuff is still the old standard Campy hanger. You only need a Goatlink or Roadlink to use an RD that is too small for your cassette. Since you bought a groupset you’ll be fine.
Remember your present front ring is made for shifting, so the chain will want to fall off. A narrow wide ring is in order. Your ring bolts may also be too long.
32-11 top gear on a 26er sounds verging on too low to me. I’ve got 30-11 on my 27.5+ and it spins out with the least advantage. Since you got the 46t cassette, try a 36t front. In gearing threads someone always says they need a triple to get their 6:1 range, but you are already used to shorter gearing
Quoted: 67 Post(s)
Liked 19 Times
Oval improves traction on slippery ground. snow, mud etc. it shouldn't change gearing. A 32T oval changes from 30-34 depending on where in the stroke it is. Since you already bought a 32T, I would just ride that and see.
I have Oval (AB) on my fatbike and hybrid and love it. but it doesn't give you more power, it smoothes out the stroke force. I guess that could make your legs more efficient, a tiny bit.
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 70 Post(s)
Liked 116 Times
Let us know how the Box 2 drivetrain works out. I've been looking at those.
I converted a bike to 1x using Microshift last year. It works okay, but I still haven't obtained the best chainline.
Funny once I got the bike done, I build another for the purpose, commuting, by single speed, and haven't gone back. The Microshift equipped bike hangs in the garage like a queen.
But that points out the one thing you may have to fuss with - the chain line.
I think you made a good choice. Hope it works great- right out of the box!
It'll be great in St Joe's and Sierra Azul!😃
