Bad pedal and shoe config, too much flex?
Old 05-19-20, 09:17 AM
finnstones
Quoted: 5 Post(s)
"One thing to consider is if you get a shoe that is too flexible and don’t have a supportive pedal, it may cause your feet to really hurt. "
so am i at risk combining
Scott Road Comp BOA Shoe ...Is this not stiff enough?
with
Time XPRO 10 Pedals ..very flex pedals
finnstones is offline
Old 05-19-20, 10:49 AM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,205 Times in 701 Posts
I would guess the source of this info needs to be considered, and it's a matter of degrees. When I read that statement, my mind immediately goes to wearing Adidas Samba Classics with a flat track pedal. I had a similar setup for commuting, and my feet were fine for that short ride, but for an actual fitness ride, I only did that once and learned my lesson. I suspect you'll be fine with the setup you describe, but you'll be the judge about what level of flex supports your feet enough.
noobinsf is offline
Old 05-19-20, 11:10 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
The combination you mentioned will not be a problem.
First, any 'road' cycling shoe has a reasonably stiff sole. Using running shoes or other non-cycling shoes for longer rides can cause discomfort.
Second, the sore foot issue is usually only with smaller cleats on 'mountain bike' pedals. Road pedals like the Time ones mentioned have a large cleat. 'Touring' cycling shoes, which usually have much more flexible soles and only work with mtb pedals, are often not ideal for harder riding.
But road shoes with road pedals? THat's the best possible scenario. If you are having foot pain it is almost definitely not caused by too-flexible shoes.
Wilfred Laurier is offline
Old 05-19-20, 11:54 AM
Flip Flop Rider
Flip Flop Rider's Avatar
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times in 322 Posts
only one way to know. install and ride. return if not right or replace
Flip Flop Rider is offline
