Help on removing rounded off Hex head
Old 01-03-21, 11:20 PM
rsbob
Grupetto Bob
rsbob's Avatar
Bikes: Bikey McBike Face
Quoted: 2560 Post(s)
Liked 5,591 Times in 2,901 Posts
Was a dumb-@$$ and rounded off the seat post bolt. Suggestions on removing?
And yes, I will buy some proper Ritchey hex tools heads so this doesn’t happen again.
TIA
Road 🚴🏾‍♂️ & Mountain 🚵🏾‍♂️
rsbob is offline
Old 01-03-21, 11:30 PM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 292 Times in 215 Posts
The last resort when removing damaged bolts is to drill out the head with a drill bit similar in size to the diameter of the threads.
If the seatpost clamp is integrated into the frame then it might be a pain to get the rest of the bolt out -maybe an Easy Out (google it)
If the clamp is removable (not a built in part of the frame) then you can probably just buy a new clamp. The threads and the face of the bore where the head of the bolt sits can get damaged over time and reduce the clamping force, which usually results in the bolt being overtightened.
Wilfred Laurier is offline
Old 01-03-21, 11:40 PM
phughes
phughes's Avatar
Quoted: 1034 Post(s)
Liked 1,289 Times in 743 Posts
TIA
Go to Lowes and get some Grabits.
This was a screw from the timing cover for an engibe I was working on. The head was a 4mm. This Grabit fit perfectly in the head, and allowed me to easily remove the screw.
phughes is offline
Likes For phughes:
Old 01-03-21, 11:42 PM
phughes
phughes's Avatar
TIA
This was a screw from the timing cover for an engine I was working on. The head was a 4mm. This Grabit fit perfectly in the head, and allowed me to easily remove the screw.
phughes is offline
Likes For phughes:
Old 01-04-21, 12:34 PM
ririder
ririder's Avatar
Bikes: Giant Defy Advanced 2, Giant Talon , Specialized Sequoia, Fuji Crosstown
Quoted: 30 Post(s)
Liked 65 Times in 32 Posts
40 years of turning wrenches on everything from helicopters to high speed packaging machines.... ^^^^^ that right there is the best solution
ririder is offline
Likes For ririder:
Old 01-04-21, 01:12 PM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
In the past I have dremel'd a slot into them then used a large flathead screwdriver. For the torque range of a seat post clamp, shouldn't need much torque.
Otherwise, yeah.......that tool shown above is awesome. Used them on my car plenty of times.
burnthesheep is offline
dedhed
SE Wis
dedhed's Avatar
Quoted: 2740 Post(s)
Liked 3,385 Times in 2,048 Posts
Internal Allen head? - Find the closest Torx bit and pound it in there and unscrew it.
External hex head? - Vice grips or grinder/dremel and cut the head off.
dedhed is offline
Likes For dedhed:
Old 01-04-21, 02:10 PM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
I've never had much luck with Grabit's. The Torx trick works sometimes. Drilling out the head has worked for me. I've also used a Dremel and flat cutting tool to cut the middle of the screw through the clamp opening.
topflightpro is offline
Old 01-04-21, 02:15 PM
Altair 4
Quoted: 258 Post(s)
Liked 291 Times in 157 Posts
Phughes - thanks for posting about that Grabit. I've had a set of easy outs but honestly never had a success with them. I gotta keep that in mind the next time I visit the big box store.
Altair 4 is offline
Likes For Altair 4:
Old 01-04-21, 04:00 PM
rydabent
Quoted: 3352 Post(s)
Liked 1,056 Times in 635 Posts
Beside a grabit or other removal tool, use a small punch and give the bolt a few good raps in the center. That helps to "unload" the threads and makes the removal tools work easier.
rydabent is offline
Old 01-04-21, 04:21 PM
Milton Keynes
Milton Keynes's Avatar
Quoted: 2281 Post(s)
Liked 1,710 Times in 936 Posts
I was going to suggest this method. I've used it plenty of times, on both stripped out screws and special screws like the torx heads with the little pin sticking up in the middle so you can't use a regular torx bit on them.
Milton Keynes is offline
Old 01-04-21, 04:30 PM
rosefarts
With a mighty wind
Quoted: 1084 Post(s)
Liked 854 Times in 483 Posts
TIA
Harbor Freight is good enough if the tools are the right size.
Also important, no matter what brand of tools you use, is to know when to stop. There's an internal torque wrench/ bad feeling/ material strain gauge that you can develop over time. It works until it doesn't.
rosefarts is offline
Old 01-04-21, 04:41 PM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1090 Post(s)
Liked 935 Times in 600 Posts
2cam16 is offline
Old 01-04-21, 04:52 PM
Pratt
Quoted: 414 Post(s)
Liked 498 Times in 295 Posts
Will a cut off disc in a Dremel reach the middle of the bolt between the ends/sides of the clamp? You might be able to just cut it in half.
Pratt is offline
Old 01-04-21, 06:23 PM
Barry2
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times in 687 Posts
+1
Used this method to save my Vintage Stem.
Use a little finesse and support the seat clamp from behind when you tap in the Torx.
Barry
Barry2 is offline
