Flu Like Symptoms Day After a Long/Hard Ride
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
I've noticed a few times that after a (relatively) long or hard day in the saddle, I tend to have some flu like symptoms the next day (runny nose, fatigue, what feels like a fever but is not).
This seems to happen when the training load is higher and I'm experiencing more stress and if I'm fasting (I do intermittent fasting as the primary goal right now is to lose weight as opposed to performance).
I feel perfectly fine the day after (i.e. two days after the ride).
Do any of you experience the same or similar thing?
Likes For Metallifan33:
Quoted: 20810 Post(s)
Liked 9,456 Times
Some fatigue and an RHR that's a couple ticks higher isn't unusual for me, but nope to the rest.
Quoted: 6193 Post(s)
Liked 4,809 Times
If I ride hard and don't hydrate correctly and replace enough spent carbs correctly during and just after the ride, then I will feel tired afterward and into the next day.
If I ride at any effort level for a time and don't hydrate correctly then I will also feel tired just after the ride and the next day.
Likes For Iride01:
Quoted: 822 Post(s)
Liked 1,960 Times
What do you mean by a hard effort? Double Century with 20K of climb? Two hour loop 30 miles 1K of climb?
Dehydration and blood glucose would be my first considerations after a hard ride and fasting.
Quoted: 218 Post(s)
Liked 102 Times
Yeah... I've been fasting the entire day and go for a fasted ride in the late afternoon for between 1.5 to 2 hrs. I guess it's time to change the diet. Oh well, fasting was the easiest diet for me, but I think I've reached the limit of efficiency for the method.
Likes For Andy Somnifac:
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Liked 4,809 Times
Hard in relation to my usual effort of the previous month or so.
Some training methods say to do some long rides entirely in zone 2 or low zone 3.
Likes For Iride01:
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Nope. The day after a hard ride I'm usually okay, more of a deep-seeded fatigue. The second day after a hard ride has a bit more fatigue and is generally when I go easy/off.
Never had flu symptoms, though. That's not a good/normal thing.
Likes For rubiksoval:
Bikes: Argon 18 Gallium, GF 29er, old Trek Madone
Quoted: 31 Post(s)
Liked 47 Times
I’d suggest getting blood work and a full physical, just to rule out anything more serious.
Living in Florida, it’s really easy to get dehydrated. And I go at it pretty hard. If I don’t drink enough or eat enough I can be pretty tired and out of sorts the rest of the day. But never the next.
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
I sometimes feel like that after a long, hard brevet. Pretty common among randonneurs, though I can’t tell you the precise physiological reason. A cheeseburger and milkshake help. (Maybe not the best diet food.)
Quoted: 741 Post(s)
Liked 412 Times
Have tou been checked for allergies recently? Also, if ride in an area with air pollution, manufactured or organic, that can cause a lot of problems for your body.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,468 Times
I don't know about the rest, but the runny nose may be due to riding in cold dry weather.
Quoted: 874 Post(s)
Liked 2,287 Times
I think maybe supplements in your water bottle could help. I started using Nuun a few years ago and it really helped. I usually do two to three hour rides , sometimes longer , but always take water with me. I found that sometimes in warmer weather I would fill my bottle two or three times . As I got older I started getting a let down or fatigue feeling so my daughter told me about this supplement and no more fatigue . I guess it could be psychological but it really works for me . The other thing I found is that if I stop every hour or so to stretch I get my strength back a bit. Repetitive motion can be bad when cycling if you don’t find a way to extend or stretch the legs back and neck.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
I feel like that when I push my endurance envelope and have seen it referred to as endurance hangover. Just a "long" ride like last weekend's 4h tempo (62mi, 5600ft) won't do it - that just creates leg fatigue (legs feel stiff and like concrete the next day). It specifically has to push my endurance limit.
Airway irritation can follow hours of breathing hard in cold air. Nothing unusual.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
I often have trouble sleeping the night after a hard ride, but never have any symptoms the next day other than being tired.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
After a really hard ride (say, a full gas solo century with climbing), I may have issues with thermal regulation during that night's sleep. It feels like a fever but isn't. The next day I may feel fatigued, in part because of the ride and in part because the thermal regulation stuff inhibits a good night's sleep. No fever-like symptoms during the following day, though.
As to the running nose, in my mid 50s, I started having a very mild running nose pretty much all the time. I figure that' just part of being an old man.
Especially with exercise and fasting, make sure you keep up with your electrolytes. No food means no salt, no salt means water will run through you faster than you want it to. That might mean switching to Gatorade or adding salt tablets. Not being able to keep in water will also reduce your blood volume - all of which will mess up thermal regulation and potentially give you headaches, lightheadedness, or worse.
After a long ride on a hot day, or even an hour on the treadmill a few degrees warmer than usual - I have no problem scarfing down half a frozen pizza with 2x recommended daily sodium intake. And instead of feeling like crap (like I often do after gorging on junk), I actually feel better.
But yes, if adding electrolytes doesn't solve your problem, might want to check with a doctor before pushing yourself any harder.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
You've put yourself in a continually depleted state. You can't increase the training load and decrease caloric intake and expect to have any kind of decent results. Proper nutrition and recovery are absolutely key to improving, and to losing weight. Stop the fad diets, just work on balanced nutrition and with the increased workload, you'll lean out.
Likes For Rides4Beer:
