Rear Derailleur Compatibility
I've neglected to properly care for my Shimano 600 SIS rear derailleur and in attempting to clean it thoroughly of rust, have somehow damaged it so that the jockey wheel is constantly rubbing against the bottom of the cassette. There are other identical Shimano rear derailleur's for sale, but many look worn, or are too expensive for what I am hoping to spend. The front derailleur is also a Shimano 600. Could I use another Shimano model, 6-speed rear derailleur with the appropriate cage-length and mounting for my integrated bolting? Thanks for your responses,
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Any 6, 7, 8, or 9 speed derailleur will work, excepting a few Dura Ace models.
Likes For cxwrench:
If you are looking for older RD and use index shifting, a RD with a cable adjuster built in or a unit marked SIS is your best choice. Units prior to these may not index properly.
Quoted: 1438 Post(s)
Liked 1,092 Times
When reinstalling the derailleur, did you correctly engage the "B" screw with the tab on the derailleur mount?
Likes For dsbrantjr:
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
It sounds like the jockey wheel bushing/bearings are kaput. I don’t know about the road bike derailleurs but many mtb models had replaceable jockey wheels.
Bikes: lots
Liked 2,932 Times
Bikes: lots
Liked 2,932 Times
Yes he did, and you replied w/ this. Which is wrong. Worn out pulley bearings would not make the pulleys suddenly become closer to the cassette cogs.
Quoted: 194 Post(s)
Liked 204 Times
Ah, so you can use 'w/' and we cannot use 'brifters'.... Proper words, proper words
It would be interesting to know how the derailleur was cleaned, because without (w/out) pictures it might indicate what kind of problem it is, and whether it is fixable.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
I'm not right off seeing this problem being caused by damaging it during cleaning. I would first think this is simply an adjustment or installation issue . If so you could possibly experience the same adjustment or installation issue with a replacement derailleur. I would double check everything before condemning the unit.
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
In my experience, the bushings inside pulley wheels never wear out before the wheel itself develops tooth wear issues. Even then, not usually significantly worn out of round.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
