Crankset size measurement questions
Quoted: 578 Post(s)
Liked 664 Times
I'm finally joining the modern world with bike parts but I need a little help on the details.
My frame has a 100mm bottom bracket, but the width with the external bearings measures 129mm
What size crankset to I purchase?
How are cranksets sized?
I've seen some brands advertise sizing via the dropout spacing or chan line.
Are there any absolute measuerments I should know about?
The bearings are 24mm, and I presently have Race Face crankset, but I would like to find a 165mm solution of any brand.
Thanks!
Thanks!
Quoted: 1829 Post(s)
Liked 1,707 Times
Please, make and model of the bike you are talking about. Context needed
You appear to want shorter crank arms. Raceface has made dozens of different crank models. Which is yours, and from what year? Don't know about now, but Raceface used to make cranks with multiple arm lengths
Likes For alcjphil:
Expired Member
Quoted: 3705 Post(s)
Liked 5,541 Times
Yep, need to post bike and crank.
Likes For shelbyfv:
Clark W. Griswold
Quoted: 4414 Post(s)
Liked 4,056 Times
The Crank generally will determine the spindle length not the other way around but it sounds like maybe this is some sort of fat bike just guessing from the little info provided but in the end you probably might want to take things to a bike shop and pay them to measure and order everything so you aren't getting the wrong thing.
Quoted: 352 Post(s)
Liked 804 Times
You want a crankset spec’d to fit your bottom bracket shell, and may need to get the appropriate bottom bracket, or spacers to make your new spindle length compatible with the installed bottom bracket.
Quoted: 6250 Post(s)
Liked 4,851 Times
You have to know what type BB shell you have to pick a BB. Then you have to know if anyone makes a BB that will work with the crankset you want to use.
Expired Member
Liked 5,541 Times
Guess OP changed his mind.
