Addiction 2021.1
#5876
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
A question for the Garmin folks with multiple bikes - is there a way to set it up so that it'll autodetect which bike is being used and/or select activity type (Road or Gravel and associated info screens) based on the sensors?
I now have both bikes (R3 and Haano) entered under Gear. The power meter (with cadence) is on the R3 and I just installed my old Garmin Speed/Cadence sensor on the Haanjo. I do not see any way of associating a sensor with a particular bike or a activity type.
A cursory search yields muddled answers. TIA!
I have three bikes with power meters, two bikes with Di2, one with eTap, and one with just a crank cadence sensor. I learned that it helps to assign names to each sensor so they can be found quickly.
The new Garmins have no bike settings.
We have a forum section that often talks about these things: https://www.bikeforums.net/electroni...hting-gadgets/ I would direct you there for help.
Keep the chain tight!
Likes For Trsnrtr:
#5877
Klaatu..Verata..Necktie?
Quoted: 10419 Post(s)
Liked 11,880 Times
To be fair, I have been known to switch sensors when one has a low or dead battery and I don't have any CR2032s lying around and I'm all ready to roll. I just make sure to change the "bike" entry in Strava to list the bike I rode.
#5878
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
I believe you can create new 'Profiles' in the Garmin computer and associate particular sensors to that profile. You could name each profile by bike. However, there does not seem to be any 'bike' association or any automatic association to a profile by active sensors. That would have to be done after the upload.
#5879
Quoted: 20810 Post(s)
Liked 9,456 Times
A search offered a recent thread along these lines in the Electronic section and I've bumped it looking for clarification. I named my gravel Activity Profile after the Haanjo and then configured the data screen the way that I want it (without power, since I don't have a meter on that bike... yet ).
It doesn't look as if Garmin will automatically select an Activity Profile based on the sensors present, which would be nice, but isn't essential. I'm also unclear on whether there's only one default bike for all cycling activities (meaning that you'd have to manually change it post-ride any time that you're not on your default bike) or whether you can have a default bike per Activity Profile.
#5880
Super Modest
Liked 4,620 Times
Correct. The new Garmins have no bike setting or at least I've never found one.
The only difference in the ride profiles is the custom screen(s) displayed.
My wife has three bikes and she only uses one profile.
Likes For Trsnrtr:
#5881
Liked 9,456 Times
That's what I had been doing, but having half of the displayed data fields empty because of a lack of Power/Cadence on the Haanjo was just sad.
#5883
Super Modest
Liked 4,620 Times
Yep. They pissed a lot of people off when they removed bike profiles. I use two profiles, one for road bikes and one for trikes though I could get by with just one profile.
#5884
Liked 9,456 Times
#5885
VFL For Life
Bikes: Velo Volmobile
Quoted: 28591 Post(s)
Liked 1,855 Times
#5886
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Same here, I’m going to try and go out around noon for 30-40, mostly because I want to play with my new bike.
#5887
Should Be More Popular
Quoted: 22587 Post(s)
Liked 8,924 Times
#5889
Liked 9,456 Times
#5891
Liked 9,456 Times
Likes For WhyFi:
#5892
VFL For Life
Liked 1,855 Times
#5893
VFL For Life
Liked 1,855 Times
#5894
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Likes For ls01:
#5895
Liked 8,924 Times
#5897
he said member
Bikes: yes please
Liked 1,951 Times
Holy carp, yesterday's group ride was hard. Im sorrer than I should be. I was riding angry though , 269 watts per hour average.
Also I figured out what the Tax thing was from yesterday. 2nd properties don't get the homestead exemption. So the properties I'm looking at were rentals and the owners are trying to sell them.
#5898
VFL For Life
Liked 1,855 Times
#5899
Liked 8,924 Times
#5900
VFL For Life
Liked 1,855 Times
