Mirror for trekking bars?
Old 03-14-14, 01:02 PM
lenA
Bikes: 2011 Surly LHT 2005 LeMond Zurich
There is a learning curve with convex mirrors..:-)
It wouldn't put me off though if there were other new design features that were an improvement.
Under what conditions and how often do you need to use a mirror?
I mostly rely on a mirror when I'm going to make a left turn from the right side of the road, or if I'm coming to a stretch with no shoulder.
lenA is offline
Old 03-15-14, 03:21 AM
rifraf
Bikes: Surly Ogre, Extrawheel Trailer
Quoted: 122 Post(s)
Liked 34 Times in 30 Posts
Originally Posted by fietsbob
no rear rack load may need be part of the plan, as it would be just what the mirror would see.
the panniers ..
Ahhhh
I didnt consider that!
Moving right along now.........
rifraf is offline
Old 03-17-14, 03:07 PM
bktourer1
bktourer1's Avatar
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 47 Post(s)
Liked 42 Times in 33 Posts
+2 on the D+D Oberlauda/Ultralight German mirror try the ACA Store. This is whats on my trekking bars
bktourer1 is offline
Old 03-17-14, 03:59 PM
NeilGunton
Crazyguyonabike
Bikes: Co-Motion Divide
Quoted: 35 Post(s)
Liked 3 Times in 2 Posts
Just saw this thread, and there doesn't seem to be any mention of a simple method which I used successfully with my Novara Safari: Just use Third Eye bar end mirrors, in combination with some MTB bar-ends that have an L-bend (I used Titec, but they don't seem to be made any more). These will slide on to the butterfly bars, and then use the Third Eye MTB bar-end mirror on the end of the bar-ends. It looks like the pic below.
(You can see the larger original version here)
I like this better than the commercial solutions because I have found that the arm of the commercial mirrors is usually quite thin and produces vibration when riding on rough roads or trails. This makes it hard to see what's in the mirror.
Like I said the Titec bar ends are now unavailable, but for reference these are what I used:
Amazon.com: Titec L-Bend AL Bar End: Sports & Outdoors
These might be similar, though I can't really tell for sure without holding them in my hand:
Amazon.com: Origin8 Pro Pulsion Compe-Lite Bar Ends - Long Black, "L" Shape: Sports & Outdoors
And here are the Third Eye Bar End MTB mirrors:
Amazon.com: Third Eye Bar End Bicycle Mirror: Sports & Outdoors
Hope that helps,
Neil
p.s. Something I forgot to mention: Using the MTB bar ends as mirror arms also has the advantage that you can use them to attach things like lights, or anything else that expects a standard MTB diameter bar to clamp to. I had my DiNotte lights on the arms in the picture I posted above, for example.
File Type: jpg
NeilGunton is offline
Old 03-17-14, 10:19 PM
Northwestrider
Northwestrider's Avatar
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
I've tried the German Ultra light mirror, but didn't like it due to its convex shape making cars appear much farther away then they are, I've gone with a large helmet mirror that I'm trying to get used to. So far I like it fairly well Safe Zone Bicycle Helmet Mirror I'd prefer a mirror on my handle bar, but have not found one that works as well as this helmet mounted one.
Northwestrider is offline
Old 03-18-14, 06:28 AM
ak08820
Bikes: MGX MTB, Fuji Supreme, Miyata 90 and a Trek 700 in the works
Quoted: 16 Post(s)
Originally Posted by bikeideas
Not happy with other eyeglass-mount mirrors available, I made my own pictured here. If this style mirror is your choice, please copy the design and make one.
Great idea/design. Where did you get the round mirror and what material is the part with 3 holes?
Please describe in detail.
I have a Blackburn helmet mirror but it vibrates a lot and is difficult to adjust/position so that you will not see your own face.
I also have a cheap handlebar mounted 3" round mirror which I like a lot over the helmet mirror. Another such mirror had convex mirror which is useless as by the time you notice the vehicle in the mirror, it is too close.
I tried to use a Schwinn mirror that goes over the grip with a velcro - totally useless with vibrations.
So, to me the best mirror seems to be a handlebar mounted mirror with an arm about 9-12" long that will allow to clear the rider's body and show the rear. I am also looking for a mirror for a trekking bar and a bar end fitted with a bar end mirror should work and the bar end can be loosened when the bike needs to be flipped or packed in a box, etc.
ak08820 is offline
Old 03-18-14, 06:37 AM
bikeideas
bikeideas's Avatar
Bikes: Trek Elite 9.8
Thanks for you comments. All the materials are easily accessible, just look around. The temple piece is rubber. Obviously, vibration is the enemy, that piece you must keep taut to reduce. I would think a 9-12" arm would wobble wildly.
bikeideas is offline
Old 03-18-14, 06:39 AM
ak08820
Quoted: 16 Post(s)
The arm was meant for a handlebar mounted mirror. For that the arm is a 6mm rod. I created confusion by mixing 2 designs in my response.
ak08820 is offline
Old 03-18-14, 06:40 AM
lenA
For the folks who don't like convex mirrors.
You had to adapt to using the convex opposite side rear view mirror in your vehicle I'm sure.
Seems to me that you will make that adjustment after a while if you wanted to work on it a bit.
lenA is offline
Old 03-18-14, 06:50 AM
bikeideas
bikeideas's Avatar
I understood that the 9-12" was for the bike. When you are testing the arm: I found when I designed my eyeglass-mount mirror, the thicker I made the wire arm, the heavier it was so the more it vibrated. So your 6mm diameter may change per testing. Follow my signature if you want to see my design further.
Old 03-18-14, 07:24 AM
djb
Quoted: 2739 Post(s)
Liked 971 Times in 794 Posts
Len, for me here is the crux of the matter, a mirror is useful when it gives you a heads up of dangerous situations that are happening behind you, a flat mirrors advantage over a convex one is that it gives you a more detailed, longer reaching view behind you that is faster and easier to identify a danger.
A faster and more more detailed (I say detailed, but Im meaning, giving you a clearer idea of what is going on, simply cuz the image is bigger and not "wideangled") view of someone hugging the edge of the road in a curve behind you (for example) is going to give you a little bit more time to react than with a convex mirror where the object doing whatever dangerous thing is going to be much smaller and the convex effect distorts the time/distance thing along with the image being smaller due to teh convex effect.
Different mirrors have diff convex curves, as well as varying degrees of optical quality (plastic, crappy plastic etc) so this comes into play, but having spent years with a convex type mirror mounted on brake hoods, going to a flat, optically very good Take-A-Look model was immediately better for giving me a bit more time to quickly assess a danger with a glance.
I guess we disagree here, but by addressing directly the shortcomings of convex vs flat, I hope to support my point of view with examples of "why".
again, any mirror used is better than none, I just feel a flat one gives you a bit more time to properly assess and react, and with cycling, a half second or second can be the difference, I know I have certainly avoided unpleasantness by not much more than that, so I'll take it.
Oh, and your car reference, we use the flat rear view in our cars to see behind us, we use the convex side mirrors for seeing what is immediately beside us.
Use your car side mirrors to judge stuff behind you while you are stopped at the side of a 45 or 60mph road and you will see how fast and unclear stuff comes up.
safe riding
djb is offline
Old 03-18-14, 08:50 AM
lenA
Thanks. I'll give a helmet mirror a try.
lenA is offline
Old 03-18-14, 10:24 AM
djb
As I really wasnt sure how I'd like them, I'm glad it only cost 15 bucks, it is kinda weird having g it in your field of vision. That's exactly why I never was keen on them over 25 yrs ago.
I guess none of them are perfect.
djb is offline
Old 03-18-14, 02:17 PM
Rob_E
Rob_E's Avatar
Bikes: Downtube 8H, Surly Troll
Quoted: 303 Post(s)
Liked 22 Times in 21 Posts
I started out with trekking bars on my touring bike. I've gone through a couple of different bars and tried a couple different mirrors. I ended up with a Take-a-Look mounted on my glasses. Everything else either interfered with a hand position or failed to show me anything useful. The Take-A-Look can be pointed in just about any direction. I ditched my contacts and went to photosensitive glasses so that I always have eye protection, sunglasses, and a place to hang my mirror. I use it almost daily. Also I can easily switch bikes and not worry about making sure all the bikes have a mirror.
Rob_E is offline
Old 03-18-14, 04:06 PM
Sharpshin
Quoted: 152 Post(s)
This is a cluttered pic what with my helmet hanging off of the headlight and the front pannier down below. But here's a mirror arrangement which is working for me, said mirror gotten for the princely sum of $7.95 at the Wal Mark bike dept and held in place by the velcro strap. I'm debating putting one on the right side too
Sharpshin is offline
Old 03-28-16, 12:19 PM
radarek
I wanted to know your sourece for the SAFARI type handlebar
Hello
Please let me know of the source for your handlebar or similar design. I see that you've attached comfort handles at the edge.
Thanks
Roman
radarek is offline
Old 03-28-16, 12:59 PM
djb
Roman, here in Canada the bars like this that I have seen in stores in Montreal have almost the same shape. Depending on where you live, if in Europe you will probably be able to find diff shapes as they seem to be more popular there. Here they are rather rare and the ones I saw in a store a few weeks ago cost $26 Can., on sites like Nashbar in the US, they cost $20 US.
djb is offline
Old 03-28-16, 01:39 PM
arnaguedes
arnaguedes's Avatar
Bikes: Charge Duster Chromoly
love my zefal spy
you can use it in any angle and any spot, trekking bar or on the top tube
File Type: jpg
arnaguedes is offline
Old 03-28-16, 08:01 PM
DeadGrandpa
DeadGrandpa's Avatar
Bikes: Too many, yet not enough.
Quoted: 492 Post(s)
Liked 311 Times in 201 Posts
I use one very similar to this: Bell Sports 7015978 SMARTVIEW MIRROR Black - Walmart.com
It has a velcro strap wrap around on the handle, and I like it very much. It does not need to be installed on the bar end, only near the bend at the "corner" of the trekking bar. And yes, I have trekking bar handlebars on my #1 bike and am going to replace the drops on my #2 bike with trekking bars also. It is simply more comfortable and functional.
DeadGrandpa is offline
Old 03-28-16, 08:52 PM
AusTexMurf
AusTexMurf's Avatar
Bikes: 2010 Origin8 CX700, 2003 Cannondale Backroads Cross Country, 1997 Trek mtn steel frame converted commuter/tourer, 1983 Univega Sportour, 2010 Surly LHT, Others...
Quoted: 48 Post(s)
Liked 15 Times in 12 Posts
Originally Posted by Wanderer
Ha, found it - Evo Mirror
This is the mirror I was thinking of. I have one on my Bike Friday Triple w/ road bars and STI's. Works well for me.
AusTexMurf is offline
Old 03-28-16, 09:14 PM
DropBarFan
Quoted: 671 Post(s)
Liked 49 Times in 43 Posts
EfficientVelo SafeZone helmet mirror is extra-wide & sturdy, by far the best mirror I've tried of either type. Past 2 weeks I've been riding a bike w/handlebar mirror & the the helmet-mounted SafeZone mirror works so much better I tend to forget the handlebar mirror is even there.
DropBarFan is offline
Old 03-28-16, 10:55 PM
Happy Feet
Happy Feet's Avatar
Quoted: 2236 Post(s)
Liked 1,314 Times in 707 Posts
Made by Bell. Fastener is velcro and I put some tape over to keep the end flap down.
File Type: jpg
Happy Feet is offline
Old 03-29-16, 12:35 AM
saddlesores
saddlesores's Avatar
Bikes: inferior steel....and....noodly aluminium
Quoted: 1053 Post(s)
Liked 341 Times in 229 Posts
Originally Posted by Happy Feet
Made by Bell.
i believe that one is a clone of the backburn bar end mirror. great mirror! mine held
up to 6-7 years of rough riding. bar ends are nice, easy to switch sides when
constantly crossing borders right-hand vs. left-hand drive.
went with a generic balljoint style fit-over-the-handgrip with velcro strap when
switched to flutterby bars.
other options possible below.
gold clamp is an e-bike mirror mount, black clamp is a h-bar h20 cage mount.
File Type: jpg
File Type: jpg
saddlesores is online now
Old 03-29-16, 08:45 AM
Happy Feet
Happy Feet's Avatar
That gold clamp would be handy.
Minnesnowtan
Commuting
59
07-08-20 07:32 PM
jefnvk
Touring
33
10-17-17 02:34 PM
rex615
General Cycling Discussion
5
05-20-12 10:41 AM
dclifton
Touring
10
11-05-10 04:33 PM
eric von zipper
Touring
11
02-01-10 06:23 PM
