Question for Australia-NZ friends
Old 11-19-19, 11:16 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3023 Post(s)
Liked 193 Times in 123 Posts
Here you go ...
27 Super-Weird Things About The USA Every Australian Notices When Visiting
https://www.buzzfeed.com/jemimaskell...sa-differences
1. The water level in these toilets is very high.
Machka is offline
Likes For Machka:
Old 11-20-19, 07:06 AM
FiftySix
I'm the anecdote.
FiftySix's Avatar
Bikes: Norco CityGlide, Schwinn "Speedster" Willy
Quoted: 509 Post(s)
Liked 313 Times in 235 Posts
Originally Posted by Machka View Post
Here you go ...
#6 is probably my biggest peeve over here. Sugar is seemingly added to EVERYTHING that's not a dessert or candy. I love eating deserts or candy, but I don't want my food to taste like desserts or candy.
FiftySix is offline
Old 11-20-19, 02:32 PM
Hondo Gravel
Of Worms and Ruins
Bikes: Too many Motobecanes
Quoted: 704 Post(s)
Liked 261 Times in 189 Posts
I’ve noticed to straight shooting toilets that use little water started to catch on here in the US. I still have those water guzzling toilets. I had one in the barn that must have been from the 1960s now talk about wasting water. But it was very comfortable it is still there but has been deactivated after a smashed some plumbing I haven’t fixed yet.
Hondo Gravel is offline
Old 11-20-19, 04:44 PM
Hondo Gravel
Of Worms and Ruins
Quoted: 704 Post(s)
Australia and New Zealand aren't real, that's just TV. Come on, WAKE UP, SHEEPLE!!1
Oh yes Australia is real here is the proof.
Old 11-20-19, 07:53 PM
skidder
Cereal Killer
Quoted: 326 Post(s)
Liked 46 Times in 40 Posts
OK I'm not sure I buy that demonstration 100%. The first test, she waited a good long time and the water was quite still before pulling the plug. Very impressive that the leaves did indeed go straight down, no swirling.
But for the other two tests, she poured the water in from the appropriate side to pre-swirl the water in the appropriate direction. The leaves still in the basin are already moving in the correct direction before she pulls the plug.
So I'm not convinced 10m is enough to create the effect, I'd want to see a more careful experiment where the water comes completely to rest before unplugging, and the drain is opened by a non-swirl-inducing-mechanism (for instance, not dunking your hand in there and disturbing the water)
Yeah, its entertaining, but I thought it was fake the first time I saw it. The swirl of water would not be based on the geographic equator, but on the Earth's magnetic field, and the magnetic north and south poles are not aligned with the geographic north and south (much less the equator). I know the north magnetic pole is somewhere in northwestern Canada, southern one would be on the opposite side of the Earth. So you have to go quite a way away from the geographic equator to find out if the swirl is in the opposite direction.
skidder is offline
Old 11-20-19, 07:57 PM
skidder
Cereal Killer
Quoted: 326 Post(s)
Here you go ...
My British relatives comment on the same things. Others they notice is how many folks in the Los Angeles area have perfectly aligned, perfectly white teeth (cosmetic dentistry is popular) and how many tanning salons are in the area (we get 300+ days of sunshine per year).
skidder is offline
Old 11-20-19, 09:17 PM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1720 Post(s)
Liked 193 Times in 170 Posts
They have to have some grounding in reality, Machka is also a Canadian. We all know Canadians are real, just a different real.
If you have trouble with reality and existence, get a grip and make a really nice sandwich.
Rollfast is offline
Old 11-20-19, 09:42 PM
noisebeam
Al
noisebeam's Avatar
Quoted: 3600 Post(s)
Liked 135 Times in 90 Posts
Magnetic field?
It has been fun, but let's get real now: Neither the spin of the Earth nor it's magnetic field will have any noticeable effect on a sink or toilet draining no matter where on Earth it is.
noisebeam is offline
Old 11-21-19, 10:21 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
Liked 202 Times in 156 Posts
+1 water is not normally magnetized (I'm not sure it ever could be, except maybe for dissolved metals/minerals in it)
RubeRad is offline
Old 11-21-19, 01:33 PM
FBOATSB
FBOATSB's Avatar
Bikes: Old Schwinns
Quoted: 596 Post(s)
Liked 32 Times in 25 Posts
The theory that the effect influences draining water to rotate clockwise in the northern hemisphere and anti-clockwise in the southern hemisphere has been repeatedly disproven by modern-day scientists.[8][9][10
https://en.m.wikipedia.org/wiki/Coriolis_force
FBOATSB is offline
Old 11-21-19, 02:01 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
[9]
[10
Thank you, finally The Answer
The Coriolis force still affects the direction of the flow of water, but only minutely. Only if the water is so still that the effective rotation rate of the Earth is faster than that of the water relative to its container, and if externally applied torques (such as might be caused by flow over an uneven bottom surface) are small enough, the Coriolis effect may indeed determine the direction of the vortex. Without such careful preparation, the Coriolis effect is likely to be much smaller than various other influences on drain direction such as any residual rotation of the water and the geometry of the container.
I bet sunlight hitting the side of a bucket and creating a temperature differential creates enough current in apparently-still water to mask coriolis
RubeRad is offline
Old 11-21-19, 02:07 PM
noisebeam
Al
noisebeam's Avatar
I gave the answer in post 33
Old 11-21-19, 02:08 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
I also kinda said it in 23, but now that wikipedia has said it, the matter is settled
RubeRad is offline
Old 11-21-19, 02:12 PM
noisebeam
Al
noisebeam's Avatar
Post #20 .
I've been subtle so as not to ruin the fun. I figured the people who cared had common sense, already knew or would look it up long ago.
Old 11-21-19, 02:17 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
respeck!
RubeRad is offline
Old 11-21-19, 02:33 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 9431 Post(s)
Liked 954 Times in 577 Posts
[9]
[10
That's what THEY want you to believe. Big Water.
Seattle Forrest is offline
Old 11-24-19, 07:28 PM
Rollfast
What happened?
Rollfast's Avatar
Here you go ...
We're a lot more full of it than you folks. And we had to give up Delta 88s, a break please!
Rollfast is offline
