SRAM Apex 1 crankset BB compatiblilty
Hey all,
Apologies if this has been asked or discussed previously but am wanting to upgrade my Kona Rove groupset from Claris to a Sram Apex 1 set up, but cant get my pea brain around the BB situation. The apex crankset has the following listed as compatible bottom brackets, BB30/PF30-68mm, GXP/PF GXP 68mm, does anyone know if this is even close to compatible what my Rove has, CH52. Sorry for being a dullard but cant quite be sure that its all gonna work, so any advice, experience or ideas would be grand,
Cheers,
A
Cheers,
A
Non omnino gravis
The CH52 is a typical square-taper bottom bracket with English threads. If you're getting an Apex 1 GXP crankset, you just need an English threaded GXP bottom bracket, like this one.
