Hands up, Surrender!! I lost to a freewheel today.
Old 02-23-17, 04:59 AM
virginia12
Thanks
virginia12 is offline
Old 02-23-17, 05:57 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Location: Ascending or Descending the NH Mountains NW of Concord!
Bikes: Snazzy* Schwinns, Classy Cannondales, & a Lonely '83 Santana Tandem (* Ed.)
Quoted: 467 Post(s)
Liked 17 Times in 11 Posts
Originally Posted by Signeld View Post
Hi there - would the easy-out tool make it possible to remove AND reuse an 80'ies regina corsa freewheel with two destroyed notches?
Thanx for sharing in this thread.
Doubtful!
Also, if your Regina has two notches for removal it is probably from the '60s to early '70s. By the '80s all the Regina's had gone to a splined inner body.
BTW, I've had some luck occasionally transplanting an old Atom inner body into the outer Regina Corsa body in order to keep using the Regina sprockets.
Bob
Dreaming about riding in NH's summertime!
Visit my websites:
FreeWheelSpa.com orpastorbobnlnh.com
pastorbobnlnh is offline
Old 02-23-17, 06:38 AM
Cougrrcj
Over forty victim of Fate
Cougrrcj's Avatar
Bikes: A few...
Quoted: 299 Post(s)
Liked 5 Times in 5 Posts
Years ago, I had to replace a driveside spoke on my bottom-end Fuji Special Tourer. We tried the correct tool and breaker bar, but it wasn't gonna happen. Then we took the wheel to the shop , put the removal tool in the vise and two of us did the old 'bus steering wheel turn' technique - Other spokes started snapping. We waved the white flag, and was forced to buy a whole new wheel and freewheel.
'75 Fuji S-10S bought new, 52k+ miles and still going!
'84 Univega Gran Tourismo
'84 Univega Viva Sport
'86 Miyata 710
'90 Schwinn Woodlands
Huffy MTB - for trips to corner store
MTB of questionable lineage aka 'Mutt Trail Bike'
Cougrrcj is offline
Old 02-23-17, 07:09 AM
big chainring
Quoted: 410 Post(s)
Liked 25 Times in 18 Posts
Theres a Campy tool for removing Regina freewheels. I destroyed the notches on a Regina freewheel and took it to my local bike shop. They said a special Campy tool makes short order of removal. Didnt see the tool, but the freewheel came right off.
big chainring is online now
Old 02-23-17, 08:26 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1732 Post(s)
Liked 81 Times in 58 Posts
Originally Posted by Metacortex View Post
From what I've seen the easiest and fastest way to non-destructively remove a freewheel with stripped or damaged notches is to use a #8 easy-out tool. This was how Schwinn dealers were taught to do it back in the '60s and '70s. You can get the tool here: Irwin 52408 #8 Easy Out Screw Extractor
This works, but you're likely to ruin the hub dustcap in the process. You might be able to pound it back into usable form after removing the freewheel, but it will be cosmetically compromised. But the freewheel will hide it in use.
JohnDThompson is offline
Old 02-23-17, 08:38 AM
JohnDThompson
Old fart
Probably the #704 tool:
But even this needs some of the remover slots to be intact. If the OP's freewheel is far gone, the EZ-Out method may be the best bet.
Old 02-23-17, 10:32 AM
Metacortex
Bikes: Fillet-brazed Schwinns
Quoted: 203 Post(s)
Liked 8 Times in 6 Posts
Not if you shorten the easy-out by 1/4" as described in the Schwinn service manual instructions I linked to.
Metacortex is offline
Old 07-20-19, 08:52 AM
rebalrid
Excellent thread this one . Getting an Irwin easy out next week . Damaged notch on a Regaina gold anodized fw
rebalrid is offline
Old 07-20-19, 08:56 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 361 Post(s)
Liked 23 Times in 18 Posts
Sounds like my Helicomatic system ain't so bad afterall. Take the retainer ring off with the bottle opener tool and the gear cluster practically falls off. It's really convenient when having to r&r a DS spoke.
Jon
Jon T is offline
Old 07-20-19, 10:43 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1719 Post(s)
Liked 126 Times in 92 Posts
I don't think I ever had a Regina FW. Started with a UO-8, then a Lambert which went SunTour early on, then raced a Fuji Pro and worked in a Fuji/Centurian/SunTour shop. Greased the FW threads with Phil and have never had issues getting them off. (Well, I have had to summon up more leverage and strength a few times. Legs and low gears win over this scrawny upper body.) Only having the first couple of cogs screw on is another feature I like.
Ben
79pmooney is offline
Old 07-21-19, 05:09 AM
Narhay
Narhay's Avatar
Quoted: 572 Post(s)
Liked 12 Times in 11 Posts
I brought my stuck freewheel to a city mechanic shop with air tools. At home I had been hanging off cheater bars and it wouldn't budge. I think I pulled a muscle doing it too.
Mechanic put a socket on his air gun, we held the wheel and it came off like butter.
Narhay is offline
Old 07-22-19, 05:49 PM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 353 Post(s)
Liked 209 Times in 135 Posts
I think even reading this thread has jinxed me.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Likes For RobbieTunes:
Old 07-22-19, 05:59 PM
Chombi1
Chombi1's Avatar
Quoted: 992 Post(s)
Liked 18 Times in 17 Posts
It has always been my Regina FWs that were hardest to remove from my wheelsets...ALWAYS!
So hard that I felt like I was going to break my ribs and rupture my lungs with all the force I had to exert to remove most of them. What is it with Reginas anyways????
Never the same problems with my Everest, Zeus, Maillard or Sachs FWs........
These days, every time I install a Regina FW on my wheels, it feels like I'm doing a permanent installation, because of this......just like a fixed cup??
Chombi1 is offline
Old 07-23-19, 06:51 AM
63rickert
Quoted: 512 Post(s)
Liked 26 Times in 22 Posts
No one is going to believe this but I'll put it out there anyway. The freewheels that get stuck the worst are the ones greased the heaviest. They'll even cut new threads in the hub shell. Threads that fit real good. Regina is worst because it is best at cutting new threads. And in old days all the strongest riders were on Regina. Mount freewheels dry and you'll have fewer problems. No, the two pieces will not electro-weld themselves. Does not occur in this instance.
Regina with buggered slots goes to LBS. Always. DIY is fine, DIY to extremes is fine. Destroying irreplaceable relics because you can't ask for help?
63rickert is offline
Old 07-23-19, 11:20 AM
madpogue
Quoted: 699 Post(s)
Liked 86 Times in 66 Posts
Works if you have an LBS with staff old enough to have ever seen a two-slot Regina or Suntour freewheel. Uncommon (LBS so staffed, not the freewheel) these days.
madpogue is offline
dchsueh
General Cycling Discussion
12
09-08-11 10:07 AM
Mr. Beanz
Southern California
4
06-06-11 09:39 AM
gdalivestock
Texas
4
05-07-10 07:06 AM
wagathon
Fifty Plus (50+)
2
02-06-08 03:40 PM
