ISO and for trade thread part 5
#1126
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
jeirvine - saw your ad, just trying to empty my stash a bit. I am going to try listing some stuff tonight on the sale page. Wife is tapping her foot and I think I will have to decide what moves out....
#1127
Quoted: 4512 Post(s)
Liked 6,385 Times
ISO
Gold rims, non aero, 32 or 36 hole, good from 10 ft +? or so. Maybe complete wheels?
#1128
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
#1129
ISO Sachs New Success 8 speed RD, long cage
I know, it's a unicorn. I have a full bin of non-aero brake levers (Diacompe, Shimano, Weinmann) some Shimano 5 and 6 speed UG hubs of various levels (there's an XT and a 105 in there,) Biopace rings galore, 26.0 Ritchey Pro ergo drops in super huge 46mm size, Shimano 105 7 speed era hubs, Exage Sport brakes with a nice polished finish, a few random Shimano downtube levers, 9 speed bar ends, 7 speed bar ends, 8 speed bar ends, 10 speed bar ends, a couple 7 speed cassettes, a Nishiki ONP frameset (wait, WHAT?) a ridiculous pile of old MTB pedals that I should probably just throw away, Jandd Expedition racks, front and rear, sandblasted bare and ready to tour. Also slightly bent Nitto bullhorns and small drop bars in decent shape, a weird Nitto riser stem that has a hole for a brake cable to pass through (completely...) some random Suntour Cyclone parts from an old Fuji The Finest, Altenburger dual pivot brakes, Tourney centerpulls, Diacompe, Weinmann, and some generic centerpulls as well. I have a couple XT headsets, a 730 and the one with the oversize bearings (735?) Let me know if you can use any of this garbage, I missed out on the last NOS RD on ebay and I'm willing to part with a mass of alloy, steel and dirt of equal value.
#1130
Liked 6,385 Times
#1131
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
You may already be aware, but don't try to use one of the ARIS 6/7s RD with 8 cogs. It will index perfectly,no problem there, but getting enough travel across all the cogs will be an issue. I've done it, had to even pull the c-clip off the hanger bolt to gain the extra mm's required - even with the limit screw backed out all the way. I've since moved that one back to a 7s setup, and have an 8s (short-cage, sorry) Sachs doing the job.
#1132
trial and error
#1133
ISO: 36 hole Mavic GL330 tubular rim, the generation with the red with gold lettering stickers. Brake track wear is fine, as long as there's life left in it.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
#1134
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
ISO - Mid-late '80s Shimano 105 or 600 road levers, prefer aero
Have - Campag Centaur(?) bottom bracket, Italian thread, 24x36, 68x111mm. Full disclosure - bought this at a thrift sale, it was in a box for a higher-end BB of the same size, so presumably removed for an upgrade. Clearly been installed/removed, but it's buttery smooth. From the tapers, it's hard to tell if crank arms were ever attached.
Options - I may consider a different model of levers, as long as they're aero and hoods are in good shape. I also have other parts, but mostly MTB.
(Clockwise to tighten on drive side means Italian thread, right
#1135
Quoted: 2363 Post(s)
Liked 1,749 Times
I never mentioned English thread. So there is no such thing as an Italian threaded shell that's 68mm wide?
#1136
Bikes: Numerous
Liked 3,098 Times
There are cases with old bikes where someone started with a 68 mm English thread shell that got stripped and they had it re-tapped to an Italian thread standard.
#1137
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Usually by mistake. I had a 96 ELOS Cramerotti with such a shell. The story is the mechanic (kid) was talking on the phone, as he was facing the drive side of the bike and took too much off. They had to add a 2 mm spacer to get the BB and crank out far enough for the Chorus derailleur to be in range. I got a decent discount on it and it worked fine but it was annoying just to know what the clown had done.
#1138
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
My Bikes
My Bikes
#1139
I've seen a few Fuji's that had 70mm ISO threaded bottom brackets as well. Before the Shimano empire took over things seemed to have varied quite a bit more than today.
#1140
Bikes: Yes
Liked 3,868 Times
Yes, I found out the hard way and came up against the travel issue. Since the Sachs 8 speed spacing results in a cassette that is 1.4mm wider than Shimano, hitting the largest cog with a 7 speed derailleur is dodgy. I REALLY love the ergos, but I'm afraid the other necessary bits are going to break the bank. My last ditch effort is a mid cage 105 8 speed RD, gonna try that one out later today.
So, if my theories are correct, you could use a pre-2001 Campy Racing T rear derailleur. A Racing T RD isn't necessarily cheap, but they're at least a lot more common than the Sachs.
My Bikes
My Bikes
#1141
Liked 1,749 Times
There probably are, since we’re talking 2-3% margin of error in measurement, but the cups on that BB won’t fit in a true 68 mm English thread BB shell. If you shop for a bottom bracket and pick 68x111, you’ll get a 1.37 x 24 component. The picture of course makes it clear what you have but some people who don’t use these parts routinely might not understand and I was just trying to help clarify for you.
#1142
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
There may be a _correlation_ between thread type and shell width/spacing, but shell width/spacing is coincidental. So let's just say it's Italian thread, and let any potential buyer/trader infer the shell width/spacing, since it's the thread type that distinguishes.
#1143
Liked 6,385 Times
@JohnDThompson
The correlation between shell width and thread spec is quite loose. There are more than a few reasons why an Italian thread shell may be other than 70mm wide, and more than a few instances of English thread shells being other than 68mm wide. My position is that shell width should be ignored when determining thread spec.[/QUOTE]
Completely agree with this, many scenario's where it ended up not following the norm, standard or pattern, necessity being the mother of invention, all things are possible.
#1144
Liked 1,749 Times
Can we just say that it's Italian threaded, and leave it at that? My sincere apologies for any other misunderstanding I might have caused with any gaffe related to width. I just want someone who needs it to have this BB...... (and wouldn't mind some brake levers my '85 600 is waiting for...)
#1145
Quoted: 887 Post(s)
Liked 335 Times
ISO SunTour Superbe Seatpost 26.6mm
I am searching for a 26.6 Superbe seatpost for my Cimarron. I have the original, but it has two problems - it is deeply scored, and one bolt and nut have been replaced (not even close to the original). I have searched paybay and found some that were too large, and all were about the price (or way more) than I paid for the bike.
I could sand it down and maybe end with a 26.5mm post, but I would still have the fugly hardware on one side.
#1146
Quoted: 1199 Post(s)
Liked 1,355 Times
ISO: BF member or place that can paint the flutes black on my super record crankset
#1147
Bikes: many
Quoted: 1444 Post(s)
Liked 1,393 Times
@malcala622 I'm sure you can do it. A bit of Testor's black paint, a fine brush and a rag dampened with mineral spirits to clean up the margins should do the trick.
Neat crank fixing bolt. What is that?
#1148
Liked 1,355 Times
The bolts came in a bag of odd and ends bike parts. They were replaced because the caps didnt sit flush with the cranks.
#1149
Liked 6,385 Times
You've got nothing to lose, easily undone.If it doesn't turn out good, wipe off before completely dry with thinner, solvent, brake or carb clean and try again. Like a wet/dry erase board.
#1150
That seems to be the way I'm heading. I am bummed out that I have to change derailleurs, but I have a Nervar crank too, so I guess more Euro and less Asia wouldn't look out of place
