Schwinn vs Vilano
Schwinn vs Vilano
Hey Folks,
I'm looking to explore into the world of Hybrid bike. Till date i used to ride MTB bike's for fun and now looking into options of hybrid bike where i can use to even commute to work.
I have around 6miles each side commute so assuming around 12-15miles daily ride.
Since its starters in hybrid im looking to start with a small investment.
I have listed 3 bikes below
1) 700C Schwinn Kempo Men's Bike
2) Vilano Diverse 3.0
3) Schwinn 700c Men's DSB Hybrid Bike
I feel Schwinn Kempo, should be a good option or if you wanna suggest some other options im open too. Please help me in finalizing with your expert opinion.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I'd steer clear of any of those and look for a used bike on Craigslist. I'm guessing either Target, Walmart or Amazon is where you have been looking?
Those will not be reliable bikes that I'd want to use every commute, and if you buy it at a big box store, they will likely be put together badly. If you must stick to that price range and want new, look at some of the bikes at Dick's Sporting Goods, Diamondback is a little bit higher quality. If you can spend a couple hundred more, you'll do better with a low end Trek or Giant hybrid bought at a real bike shop and properly assembled.
Quoted: 5224 Post(s)
Liked 3,581 Times
what size are you & where do you live? maybe we can help you find a used bike
Bikes: 2016 Trek DS 8.3 Hybrid, 2013 Schwinn Searcher
Trek DS all day. I'm not saying a dept store Schwinn CANNOT be a decent bike to start with, but, for a few dollars more, why not INVEST in something less likely to let you down?
Bikes: Giant Roam 2
Quoted: 11 Post(s)
I'll agree with everyone here on buying a cheap/properly sized bicycle from a shop rather than from a big box store. If you plan on riding even weekly the cost will be cheaper in the long run. Also more likely you will enjoy your purchase more.
Quoted: 5 Post(s)
As long as you are considering the Schwinn Kempo, take a look at the Schwinn Phocus 1500. It's an upgraded version of the Kempo that can be had for $300 and specs-wise is comparable to a Trek FX 2 Disc which costs $260 more. I'm not going to say the Schwinn is the equal of the Trek but it is a good bike at much less cost. I've got one and couldn't be more satisfied, and I did compare against Trek bikes. If you don't mind doing adjustments yourself you will wind up with a good bike that will be a fine introduction to hybrids.
Tragically Ignorant
Liked 9,098 Times
Also, definitely try a bike before you buy it. Fit is not easy to figure out with just numbers. I'm not saying you won't prefer the Schwinn to the Trek or something else, but you won't know until you sit on them.
Quoted: 5 Post(s)
BUT, and this is a big one, be honest with yourself. If you are not familiar enough with bikes to do those kind of adjustments, you also probably aren't going to know if the big box store set up your bike correctly. My LBS guy tells me he makes A LOT of his money fixing up screwed up bikes from WM that are essentially brand new.
Tragically Ignorant
Liked 9,098 Times
That's really cool, and I'm glad that worked for you. You are definitely NOT the typical big box buyer. Were you mechanically inclined before you got into bikes?
Quoted: 5 Post(s)
I do agree with trying before buying. In the case of the Schwinn Phocus 1500 you won't find it in stores. But the Schwinn Circuit uses the same frame and is available in Target stores to try. So for purposes of fit, you can get an idea if the Phocus 1500 will be acceptable.
Quoted: 5 Post(s)
Thanks! Not very mechanically inclined unless it involves computers. Lol. But YT is a great resource and you can learn a lot if you want to. Making mistakes is part of the process and helps you improve.
Liked 3,581 Times
Lifelong wheel gazer ...
Bikes: All garage sale finds...
Quoted: 72 Post(s)
Liked 36 Times
I agree with the thinking that says hold off and get a good quality bike off of CL or at an LBS. If you get something that fits properly and is well built you greatly increase your chances of enjoying the ride and bonding with the bike.
That said, I do have a Wally World MTB with a decent aluminum frame. It’s been a great bike to date and I’m not done with it yet. The geometry is perfect for my height, reach, and desired level of comfort. However, I constantly have to “work” the gears in certain settings. Annoying, but I’m accustomed to it.
So depending on the bike and manufacturer, type of metal etc, the frame of the department store bike may be of decent quality. But it’s a sure bet the components will be junk. If your’e mechanically inclined you can make it work, but if not you’ll end up very frustrated.
So either way you go, and to quote a Cajun carnival barker, “you pays you money and takes you chances.”
Current bikes: Unknown year Specialized (rigid F & R) Hardrock, '80's era Cannondale police bike; '03 Schwinn mongrel MTB; '03 Specialized Hard Rock (the wife's)
Gone away: '97 Diamondback Topanga SE, '97 Giant ATX 840 project bike; '01 Giant TCR1 SL; and a truckload of miscellaneous bikes used up by the kids and grand-kids
Status quo is the mental bastion of the intellectually lethargic...
Bikes: Trek FX 7.2 & Motobecane 529HT
When I first got back into cycling in 2014 at the ripe age of 50, I didn't have a clue where to start. Reading here, I learned all of the pitfalls of dept store bikes. For $300, I found a one year old Trek FX 7.2 that probably didn't have 50 miles on it. In just a tick over 4 years, I have put 3200 miles on the Trek, and it's been flawless. I've had a LBS tune it up once at about 2000 miles in, and it just continues to perform. It's equipped with Shimano Alivio and rides like a dream. Good deals are out there....
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
For those who are interested in department store bikes, check out the 'KevCentral' YouTube channel. He does a lot of honest reviews of big box bikes (mostly ones he finds at Walmart). I think he does very fair review and demonstration videos, and often compares them to other "real" brands he owns (like Trek or Raleigh). He's found a few gems along the way, along with a number of real losers as well. It's worth checking out, even just for curiosity's sake.
Warning up front: he's mostly looking at the "mountain bike" genre sold at Walmart. He doesn't have a lot of street-oriented hybrids. He did just look at a $99 Schwinn Cutback, which looks like a bit of a blend of something like a Trek FX and a Raleigh Redux (it has a 1x drivetrain). He has also reviewed a few belt drive bikes (not found at Walmart) which are interesting.
Bikes: 2000 Trek 720 Multitrack (plus)
Quoted: 48 Post(s)
Generally, you don't need a suspension fork unless you're riding cobblestone streets. Most low end bikes use very low end forks that are theree just to add a marketable "bullet list" feature. Same is true of mechanical brakes. They are better than rim brakes, but not by much. Money spent on poor suspension or budget mechanical brakes would be better spent on better drive train components or tires or saddle, etc.
Tragically Ignorant
Liked 9,098 Times
I've looked at Vilano's online and was not impressed. But 30 years from now, somebody on the Classic & Vintage forum will post, "Hey, I just pulled a rusted and pitted Vilano out of a dumpster. Worth restoring?" And the answer will be a resounding and unanimous, "Yes! Vilano's are great bikes! Good luck with your restoration and don't forget to post pics!"
Bicyclerider4life
THAT is Hilarious!
I have a 45 year old "big box" Huffy cruiser that has needed nothing but normal maintenance items replaced.
No broken/cracked frame welds, no broken dropouts, still running the original wheels with the original bearings in the hubs, and all the original spokes!I have a 45 year old "big box" Huffy cruiser that has needed nothing but normal maintenance items replaced.
Oh yeah, for 12 plus years I was averaging 4,000 miles a year on it.
I've only had to replace 4 sets of tires and tubes, and 3 chains in over 48,000 miles. Yet the bike isn't "reliable"?!?
Full Disclosure: I replaced the 48 tooth chainring with a 36 tooth after approximately 4 or 5 years, and 16,000 to 20,000 miles, because I wanted lower grearing. The chainring did not need replacing. The rear sprocket as never been changed, and does not need replacing. Ain't steel chainrings and cogs grand?
I don't care what bike you buy, who made it, or how much it cost. If you maintain it, it will be reliable and last a long time. If you don't, it won't be reliable (although I suppose you could rely on it to fail) nor will it last.
To categorically state that big box bikes are garbage and unreliable is reprehensible and a disservice to everyone.
How many people who can't afford anything "better" has that attitude STOPPED from getting ANY bike?
"Buy used from CL or the Bay ..." Yeah. Right. And how many of those bikes don't need work, and don't cost considerably more up front than a big box bike, and as an added bonus, just MIGHT be STOLEN?
To the OP: Get whichever bike you like and tell the snobs to take a long ride on a short pier.
Tragically Ignorant
Liked 9,098 Times
THAT is Hilarious!
No broken/cracked frame welds, no broken dropouts, still running the original wheels with the original bearings in the hubs, and all the original spokes!.I have a 45 year old "big box" Huffy cruiser that has needed nothing but normal maintenance items replaced.
I looked up the specific bikes the OP was talking about. A couple of them I've actually sat on. They're bad bikes, very poorly equipped, and likely to be a bad fit because of the one size fits all approach big box stores use. He can definitely do better for the same money, and I hate to see someone get discouraged from biking because they bought a POS.
I don't appreciate the name calling.
Tragically Ignorant
Liked 9,098 Times
Tragically Ignorant
Liked 9,098 Times
What got me is that I was also suggesting he'd do better looking at a Diamondback at the same price point at Dick's. It wasn't close to a snobby answer.
If somebody asks for advice on specific bikes, and you respond "get whatever you want, just maintain it", I think that really doesn't answer the OP's request.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
If you can, get to a real Bike Shop and try to sit on a few different bikes. Let them fit you to a bike in your price range and you will be money ahead not to mention the fun and comfort. I can not say what you should buy but I did buy a used Schwinn that was the wrong size, put a bunch of time and money into it, sold it for less than I invested, bought a nice flat bar bike that was fitted to me and I could not be happier. I would say that quality and fit would be your two most important criteria as a starting point then look at what options the bike would offer for the future. Things like fenders or racks etc. may be important as you do not know now where you interests are going to take you.
Good luck, Frank.
Good luck, Frank.
