Mirrors
Quoted: 55 Post(s)
Liked 32 Times
Mirrors
I've finally taken the plunge and started riding on (busy) city streets outside my subdivision. By far, my biggest obstacle is not knowing what is coming up behind me on my left. What mirror solutions have you found to work? Fork mounted? Helmet mounted? Handlebar mounted? I'm running MTB handlebars exclusively and don't have tons of room left for a mirror but if that's the best solution I'll figure it out.
Thanks!
Thanks!
aka Phil Jungels
Mountain Myrricle - the best there is! MHO
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
I really like the "ultralight German mirror" from D+D Oberlauda. https://www.amazon.com/D-Oberlauda-Ul.../dp/B0089CHAT0
It has a wide field of view, mounts easily, and doesn't vibrate out of position when you ride. You can mount it underneath the handlebar grip, and then it doesn't stick out like the Mirrycle.
Quoted: 2495 Post(s)
Liked 738 Times
I really like the "ultralight German mirror" from D+D Oberlauda. Amazon.com : Ultralite German Mirror : Bike Mirrors : Sports & Outdoors
H
Quoted: 167 Post(s)
Liked 5 Times
I would like to mention an entirely new method I only learned about recently.
I don't see how the hand mirror you linked to would be any closer than a mirror mounted under the grip.
ATMO, that hand mirror seems like a lousy design. I move my hands around a lot during a ride, so I'd have to constrain that movement in order to keep my rear view aligned. How would you look in the mirror when signalling, shifting, or drinking a water bottle?
Liked 738 Times
For a closer mirror, the Take-a-Look and similar eyeglass or helmet-mounted mirrors would probably work well. Personally, I don't like helmet mounted mirrors because they don't stay in place and they invariably get broken when I take my helmet off. And I don't wear sunglasses at night, so the glasses-mounted ones are out for me.
H
You gonna eat that?
I like a helmet-mounted mirror. I can scan behind myself by moving my head a bit. To me, a rearview mirror is one of the most important pieces of safety gear for riding in traffic.
As for your remark about "riding on (busy) city streets outside my subdivision." One thing I've discovered is that I can ride most of the way to where I want to go by cutting through neighborhoods on the residential streets and crossing the busy streets instead of riding on them. Areas that I used to think of as sketchy are really not too bad - mostly just immigrant/laborer neighborhoods. I used to view them as kind of dangerous but they don't bother me at all now. With a little creative use of Google Maps in the Bicycle or Pedestrian modes, you can often find little cut-throughs and worm holes through the city - look for pedestrian crossings, paths through parks, etc. Exploring them can lead to new routes that keep you away from the heaviest traffic.
Quoted: 167 Post(s)
Liked 5 Times
I have a Blackburn bar end mirror on one of my bikes and it is never in quite the right position to see what I want to see. I have learned to instinctiely roll my handgrip forward or backward to get the right angle. There is just enough squish in the handgrip and mirror mount to fine tune the view to perfection.
I don't think the hand mirror would replace a helmet mirror but it could. For one thing, even with your hands on the bars the mirror would be closer to your eyepoint than a mirror 4" below handlebar level. Enough to matter. Next you can easily take your hand off the bar or twist your wrist this way and that.
You, like many on this forum, consider a mirror to be a passive warning device that is constantly monitoring your rear end and ready to warn you of imminent danger. I disagree. A mirror is useless until it is looked at. Whether you look at it as part of a regular 360* scan or as a status check before an offensive maneuver like a lane change or overtake, the mirror cannot provide any useful information until your attention is focused on it.
Perhaps that's why I like the German mirror; it's big and in a similar location to a motorcycle mirror. I also change my front brake to be operated by the right lever, just like on my motorcycle. Consistent muscle memory is important!
I consider myself reasonably acronym proficient. What is ATMO pray tell, I need to add that one to my lexicon. If you get from this that I think the snowmobile mirror is an underrated method of checking behind you would be correct. And, FWIW, the price in that link is especially attractive. I have seen them for twice that price plus shipping.
H
H
Cheers,
Tim
Liked 738 Times
That sounds to me like the Blackburn mirror isn't stable enough. That's a huge advantage of the German mirror; it's easy to adjust and stays where I put it. I've used it on century rides and it stays aligned the whole time.
So long as you have a primary mirror (like your helmet mirror) then maybe the hand mirror could supplement that. It just seems to be a bad idea to have to compromise my hand positioning every time I need to look in the mirror.
I'm not sure where you made this assumption! My mirror is part of my constant scan. My scan was developed as a cockpit scan from when I flew jets for the Air Force, and as a motorcyclist I practice a very active scan.
ATMO is an acronym coined by the master frame builder, Richard Sachs. It stands for According To My Opinion. It's basically the same thing as IMHO, but makes no assumption that the speaker is actually humble (Sachs definitely isn't!). Just a more bike-geek oriented acronym.
Cheers,
Tim
Cheers,
Tim
H
Bike Commuter
Bikes: Mt. Shasta - Capella
Another vote for the Take-A-Look. Mine has served me well for years. I had lost it and got a Cycle Aware Heads-Up from the LBS, and do not recommend that one, it broke after about a month's worth of use (the mount is plastic, unlike the metal of the Take-A-Look). Thankfully I found the Take-A-Look again shortly thereafter and it still works great.
Quoted: 167 Post(s)
Liked 5 Times
Interesting. All in all we agree more than we disagree. Still, most motorcycle mirrors stick up above the bar about as far as your mirror hangs below the bar. The total distance involved is considerable. I'm not believing that you ride a Harley with ape-hanger handlebars with underslung mirrors... ... ironically enough, those hand mirrors are also used by motorcyclists who usually have plenty of DOT mandated rearward visibility onboard anyway... ... go figure. Best.
H
H
On my Triumph Sprint 955, the mirrors are on stalks mounted to the fairing, above the handlebars. The placement I showed is close enough for me; I'm not too sensitive about the exact mirror position.
Since that pic, I changed the bars over to drops and moved the mirror to the outside. But I found that I really liked that mirror position on flat/upright bars.
Best of luck with the hand mirror. I wouldn't mind giving it a try, but I'm skeptical enough about it that I won't buy it any time soon.
DeadheadDave
Bikes: 1 Trek road bike, 1 Cannondale
Quoted: 18 Post(s)
I like Mirrycycle, too. I have one on my road bike and one on my commute bike. They give a good view and they stay put.
aka Phil Jungels
And, the Mirrycle does NOT have to stick way out. Make your first adjustment with the stalk pointing straight forward. and you can have it up or down..... They keep position very well, do not vibrate, and are durable, as well as offering an extremely good view behind you.
Quoted: 55 Post(s)
Liked 32 Times
Thanks for the suggestions. So far, I'm liking that German mirror the best. I had a (cheap) bar-end mirror years ago and it was a PITA but like I said, it was a cheapo so maybe a higher quality version would work best.
I agree with the poster who mentioned rear visibility being the most vital component of riding in traffic.
Right now, I'm only riding the streets during low traffic periods and when possible, I'm just on them for short sections. Unfortunately, this part of the city is about as unfriendly to bike traffic as it is possible to be. No two subdivisions have entrances that are directly across from one another, which requires bicycles to actually ride on the busy streets. The only bright spot is that my part of the city is newly developed and the roads are being drastically improved into 4-lanes with continuous sidewalks on one or both side. Riding on the sidewalks is legal here and I plan to use them a lot when I see a stretch with no pedestrians present.
Quoted: 55 Post(s)
Liked 32 Times
I didn't see the month-old thread asking this same question but now that I've read that one I've ordered the "Take a Look" helmet/eyeglasses mirror. I hope it lives up to it's positive reviews.
Bikes: 2010 Fuji Absolute 2.0, 2011 Gary Fischer Cobia 29", 1980's Ross 10 speed, 2014 Fuji Gran Fondo
Even though the op decided on which mirror he will be purchsing, I wanted to give my experience just in case anyone else is still trying to decide on a mirror. I also use a "ultralight German mirror" from D+D Oberlauda. It is an excellent mirror - stays in adjustment and provides a great view.
contiuniously variable
I use my ears to watch behind me unless i need to make a turn. I might get a mirror set, but it needs to fit on my handlebars.
- Andy
- Andy
- Andy
Living 'n Dying in ¾-Time
Bikes: Specialized Crossroads
Thank you to everyone who contributed to this thread. Lots of great tips. I've started riding my bike here in Manhattan and will need as much help as possible from mirrors.
That ultra-light German one looks cool.
In fact, just ordered one.
Quoted: 55 Post(s)
Liked 32 Times
I got my Take-A-Look mirror yesterday and put in my glasses and took the bike for a spin. Didn't care for it at all. I then clipped it onto my newly purchased helmet and so far, it seems perfect!! It was just too close to my face on the glasses but using the helmet visor puts it far enough away that I get a much better field of view. Also, for those who haven't used one of these types of mirrors, it's a steep learning curve compared to the type of mirrors found on cars and motorcycles. I am going to have to work on building the correct muscle memory for moving my head just right to scan the area behind my head. It's almost counter-intuitive and keep doing the opposite of what I need to do. I've probably spent less than five minutes riding with the mirror and I suspect that just a decent ride or two will have me acclimated to the mirror.
