20" Wheel Front Hub width 74mm vs 100mm?
Old 11-23-16, 09:42 AM
Rick Imby
Quoted: 239 Post(s)
Liked 3 Times in 3 Posts
So I know all the Dahon and Tern 20" wheeled bikes have 74mm front axle widths.
I know the Xootr Swift front wheel is 100mm like most BMX bicycles and 20" kids bikes.
What width is the Bike Friday, Birdy 18", Brompton 16", old Raleigh, or any folding bike front hub width?
Rick Imby is offline
Old 11-23-16, 10:31 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
narrow fork contributes to smaller folded package.
Brompton is a 74*, Bike Friday [NWT] Pocket Llama 20" is 100.. (Mine has Disc Brakes)
* to put in electric motor hubs the fork must be spread to 10cm
I think the 349-16" TikIt and new PackIt are 74 .. 24 spoke 9mm axle. Brompton is 28 spoke , 8mm axle.
fietsbob is offline
Old 11-23-16, 03:11 PM
Pinigis
Pinigis's Avatar
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times in 241 Posts
Origami Crane 8 is 74mm, the Gazelle, Cricket, Mantis, and Hawk are all 100mm.
Paul Pinigis
Owner of Origami Bicycle Company
Pinigis is offline
Old 11-24-16, 11:39 AM
zebede
Hello
zebede's Avatar
Bikes: n+1
Quoted: 110 Post(s)
Liked 29 Times in 25 Posts
Originally Posted by fietsbob
I think the 349-16" TikIt .... are 74 .. 24 spoke 9mm axle. ...
Exactly, confirmed by measurement.
zebede is offline
Old 11-24-16, 04:47 PM
Rick Imby
Quoted: 239 Post(s)
You guys are a vertitable Encyclopedia of information---
Thanks
Old 01-08-17, 11:42 AM
Rick Imby
Quoted: 239 Post(s)
Ok So now what about Seatpost sizes?
Dahon 34.0---Swift 34.0--33.9 is also claimed to work.
Bike Friday ?
Origami?
Old 01-08-17, 11:52 AM
fietsbob
Bikes: 8
My Pocket Llama has a seat post sizing shim with an inside diameter of 27.2mm.
But the actual ID of the Seat Mast Tube, the OD of the shim, is larger..
But ... Bike Friday does not use a Telescoping seat tube as a part of its fold procedure.
fietsbob is offline
Old 01-08-17, 08:24 PM
tudorowen1
Bikes: Brompton S6L ,Bike Friday NWT, Phillips 8 speed folder, Trek 930, Thorn XTC
Quoted: 76 Post(s)
Liked 9 Times in 8 Posts
I am not sure how many companies produce the 74mm front hub..My guess is only one..It may be Formula ..not sure..I may be wrong but the Brompton hub of 74mm is perhaps made by the same manufacturer that makes them for Dahon and Tern and all the other Dahon Licensed companies..
Much better choices of hub in the 100mm width..Very hard to get a quick release sized 74mm..
tudorowen1 is offline
Old 01-10-17, 01:40 PM
Pinigis
Pinigis's Avatar
Quoted: 452 Post(s)
There are a lot of companies out there making 74mm hubs, you just have to look around for them.
Paul Pinigis
Pinigis is offline
Old 01-10-17, 01:58 PM
fietsbob
Bikes: 8
I have a Schmidt and Shimano dyno hub that both fit Bromptons, so 74mm ..
fietsbob is offline
Old 01-10-17, 06:54 PM
berlinonaut
Quoted: 319 Post(s)
Liked 14 Times in 11 Posts
As a start: Aside from Brompton, Dahon and Tern there are (as mentioned by fietsbob) Schmidt and Shimano Dynohubs. There are also various dynamo-hubs from Shutter Precision in 74mm with both, Dahon and Brompton axles. You can get "normal" 74mm hubs i.e. from American Classic, from Phil Wood, from Jtek in the UK, as a custom hub from Royce in the UK, from Bike Friday and from a gazillion asian brands and manufacturers.
74mm-hubs may not be as common as 100mm hubs but are by far not only produced by only one single company.
Not really. In fact most of them have. You just have to do your homework in form of minimal research to find out.
berlinonaut is offline
Old 01-10-17, 08:35 PM
tudorowen1
Quoted: 76 Post(s)
You may be able to find many 74mm hubs in the USA but in the UK they are very rare..CH White stocks them but on his website they only have 74mm hubs with 20 holes..Most Dahon or Dahon licenced bikes use 28 spokes..He does sell 74mm quick releases..So if you want a 74mm 28 spoke hub it would have to be a Brompton hub I would think..I can think of no other place to source them in the UK apart from Brompton dealers..However it is easy enough to source... 74mm hub complete wheels..
And all you guys will tell me they are available but they are very difficult to source in the UK..Sent from the USA or Korea.. will incur expensive postal charges
Old 01-10-17, 09:07 PM
berlinonaut
Quoted: 319 Post(s)
Phil Wood in 74mm is available at Bricklanebikes, Jtek at SJS, just to name the two.
Old 01-11-17, 08:48 AM
leoho5
Quoted: 35 Post(s)
Be careful though of attempting to use a Brompton hub on a non-Brompton as Brompton hubs use 8mm axles instead of the more common 9mm. They are not interchangeable.
leoho5 is offline
Old 01-11-17, 10:13 AM
fietsbob
Bikes: 8
Although a clever mechanical person can put a shim sleeve around the axle [ 1/2 a mm r = 1mm D.]
fietsbob is offline
Old 07-24-17, 11:36 PM
jorymil
Boston Biker Boy
As a Tern owner, I'm trying to solve this as well. I'd like to be able to build myself a quality front wheel that'll last a while.
Bike Friday still sells their Tikit hub (come on BF - let me post links) but it's a 24-hole hub, and there aren't any 24-hole rims out there that I'm aware of, so I'd have to do some creative lacing. I'm drawing a blank on where to find the American Classic hub. There seems to be an active link for the Dahon Neutron hub, however, which is made by American Classic. It looks like bricklanebikes has some Phil Wood hubs, but they're not part of the regular Phil Wood catalog, so guessing they're NOS. Axle diameter there is 8 mm. From Jtek's site, their axle diameter is also 8 mm, which means you'd either have to replace the axle or do some questionable shimming to work with a Tern/Dahon.
Am I missing any other non-dynamo options? Any 24-hole rims out there?
John
jorymil is offline
Old 07-25-17, 04:10 AM
badmother
badmother's Avatar
Quoted: 317 Post(s)
Found this one TERN Front Hub black 411929 | eBay
while searching for other items. Can not find anything about spoke count so ask. Same seller has several Tern hubs, also dynamos but all low spoke count hubs.
Edit: Same seller, narrow front hub 28 holes.
https://www.ebay.co.uk/itm/TERN-Front...-/272637997327
badmother is offline
Old 07-27-17, 09:41 AM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 306 Post(s)
Liked 44 Times in 33 Posts
John
Velocity Wheels - Hand Made in USA
1nterceptor is offline
Old 07-27-17, 05:16 PM
jorymil
Boston Biker Boy
Awesome possum - the Velocity A23: a 24-hole 406-mm rim actually exists! Thank you.
John
jorymil is offline
Old 07-27-17, 05:54 PM
jorymil
Boston Biker Boy
...and I almost missed the 24-hole Aeroheat, which is black-only with machined sidewalls. Totally getting one of them ASAP - will see if the LBS can order one for me. Gotta do one for the rear now, too ;-)
Hub-wise, I ended up buying the Tikit hub plus a 28-hole Novatec hub from SJS Cycles in the UK. Will probably end up keeping both - PITA to return the Novatec overseas.
Thanks to everyone for their responses!
jorymil is offline
Old 07-27-17, 06:01 PM
jorymil
Boston Biker Boy
Originally Posted by mtb_addict
What is the axle nut size on these 74mm hub?
I looking for replacement nuts for my my Dahon.
I believe Dahons use 9mm axles with standard 1 mm/thread pitch. Your local bike shop should have plenty on hand: even though the hub shell is narrow, the axle dimensions are otherwise standard.
John
jorymil is offline
Old 05-11-22, 02:44 PM
cattleandcane
what size is rear axle for dahon d7 vitesse please
cattleandcane is offline
Old 07-01-22, 03:09 AM
Ron Damon
Quoted: 459 Post(s)
Liked 565 Times in 354 Posts
130mm OLD like all Dahons?
Ron Damon is offline
hhk25
Folding Bikes
30
07-27-18 11:42 AM
Winfried
Folding Bikes
14
09-21-17 11:41 AM
chagzuki
Folding Bikes
0
03-24-11 09:18 AM
vincentnyc
Folding Bikes
40
02-06-10 11:39 AM
