Wider tires on narrow rims
Quoted: 35 Post(s)
Anyone have experience using narrow width rims on a folder? Many of the narrow rims recommend 1.35 or narrower tires. Anyone try to put wider tires on them? Any recommendation for the smallest rim width that a 1.50 tire would fit?
Thanks in advance.
Thanks in advance.
Quoted: 380 Post(s)
Liked 106 Times
Not on a folder but I have used 40mm tires on a rim made for 25mm tires for a long time with no problems. A little hard to install the first time and used Presta tubes with it. Smaller valve stems made it easier to seat the tires beads. Used V brakes to get tire brake ckearance. Roger
Rim not so fussy, you Just cannot go wider than the frame allows..
Brompton , 349 - 37 is It, unless you hire the frame/fork modified & Thor is into Dahon/Terns.
OP did not say which folder, so measure your frame clearance..
Part-time epistemologist
Velocity on rim to tire width
Velocity Wheels - Hand Made in USA
Mavic on rim to tire width
https://www.bikerumor.com/2016/08/12...-best-results/
DT Swiss on rim to tire width
https://www.dtswiss.com/Resources/Te..._Dimension.pdf
A narrative on bicycle driving.
BITD Narrow MTB rims did not exist , they do Now. Of course this is for low Pressure .. 2" tires.. on dirt..
Quoted: 35 Post(s)
Thanks for all the feedback. The links are particularly interesting. I have a Velocity 349 rim with an inner rim width of about 19mm which seems to be pretty standard. It has no problem fitting narrow or wide tires. I also have a Kinlin rim which has an inner rim width of only 13mm and have only fitted Kojaks (1.35). Never tried something wider due the max. recommendation. According to the linked charts, even Kojaks are stretching it on such a narrow rim. Don't think I'd feel comfortable going wider.
Cheers
Cheers
My own semi-scientific experiments found that tire squirm was more likely with wide tires on narrow rims.
FWIW, I have 406-47 tires on CR 18 rims as supplied in Bike Fridays build of my Pocket Llama.
If memory serves, the range recommended by SB is 1.4-2.5x for the rim to tire width. That is far too conservative. I use a 1.2-3.0x relationship. Currently using 42mm tires on a 14mm rim.
Quoted: 3461 Post(s)
Liked 1,466 Times
Of all the charts out there, I prefer the one at the bottom of the page at this link for rim width (inner width) and tire width.
Tire Sizing Systems
If you have too fat a tire on a narrow rim, it can become evident at low pressure where the tire can flop side to side. I wish I had wider rims on my expedition bike because there are times I wished I could run lower pressure than I do.
Tire Sizing Systems
Quoted: 35 Post(s)
From recent experience it seems that if a rim has an internal diameter of < 15mm, it may not be able to mount commonly used wider tires such as Marathons and Big Apples. A 14.3mm rim from a Dahon Visc p18 can only mount tires up to 32mm! 35mm tires are not able to be mounted.
Best bet is to get a rim with internal diameter around 17-20mm which can mount a wider range of tires.
I've been running 42mm Marathon Supreme on 14mm bead width rims for several months with no problem.
**thusi*st
I've been putting 1.95" tires on rims that come standard with 1.35" tires. 2.125" tires on ones that come standard with 1.75" tires. RIM (outer) measures are about 18 mm and 22 cm respectively. Depth of the channel of course is important.
I've done both for over a year now with no issues what so ever (Dahon Visc and Dahon Jetstream)
Quoted: 14 Post(s)
A wide rim will increase the inflated width of whatever tire you use on your small wheel. Even small increases in rim width give you a substantially larger cushion of air to ride on.
Unfortunately there aren't many choices of wide rims for small wheels, other than in 36 hole drillings for the BMX bikes. I was looking for a wide 28 hole 406 rim- something wider than the 24mm (external width) Velocity, but could not find anything.
I will use Box rims (28mm wide, 36 hole, 362grams) in my next project. The rear wheel will use 36 spokes of course, but the front wheel I had to figure out a way to use it with a 28 hole SON XS (74mm OLD) dynamo hub (they are not offered in 36 hole drillings). This is how I solved the issue on my first set of wheels using the Sun big ****** rim. The new Box rim is a bit narrower (27 vs 30mm), but a lot lighter (362 vs 547 grams). I'm looking forward to trying the featherweight Box 406/51 race tires with them.
