New Sirrus 3.0 bottom bracket loose
Old 08-23-20, 06:00 AM
timgriffin2
Bikes: 2020 Specialized Sirrus 3.0
Quoted: 61 Post(s)
Liked 34 Times in 19 Posts
New Sirrus 3.0 bottom bracket side to side movement
I was looking for the source of a creaking noise on my new Sirrus. I found that the cranks move in unison side to side quite a bit - maybe 3/16 inch side to side - and when it does it pushes the chain against the front derailleur making noise while I ride. I'm not a mechanic, but that doesn't seem right (or safe) to me. I was getting ready to go for a ride and decided to try and find the creaking noise source first. I guess a trip to the shop is in my future plans instead of the ride which sucks!
I already had to bring it back to the shop the day after I bought it when the front derailleur cable came undone in the shifter housing during my first ride. I never had any issues with my Crosstrail Sport over the course of a few years and 2,000+ miles other than normal maintenance - and it NEVER had any sloppy movement in the bottom bracket/crank area.
Has anyone else seen something like this? It doesn't seem normal for the front gears to move sideways like that. I'm thinking that's what's been causing my shifts to sometimes be clunky or jump 2 gears sometimes instead of one.
Here's a video showing the movement - can anyone answer if this is normal?
timgriffin2 is offline
Old 08-23-20, 06:41 AM
freeranger
freeranger's Avatar
Quoted: 221 Post(s)
Liked 321 Times in 206 Posts
Sounds like yours may have been one which should have had the recall. https://www.specialized.com/us/en/safety-notices
freeranger is offline
Old 08-23-20, 06:57 AM
timgriffin2
Quoted: 61 Post(s)
I sure hope not since I purchased it 2 weeks ago and was told that this one was good to go in reference to the recall issue
Old 08-23-20, 07:29 AM
freeranger
freeranger's Avatar
Quoted: 221 Post(s)
Definitely not normal--take it back, and hopefully they have a good mechanic that can look it over to ensure everything is installed correctly. Assuming it was sold like that, I'd look over the whole bike to ensure all is good with it. Or demand the LBS do it-without charge.
Likes For freeranger:
Old 08-23-20, 08:59 AM
hokiefyd
hokiefyd's Avatar
Bikes: '18 Redline Zander MTB, '14 Surly Pugsley, '97 Trek MultiTrack 750, '70 Peugeot UO-18 Mixte
Quoted: 1154 Post(s)
Liked 379 Times in 292 Posts
That's absolutely not normal. It appears like they didn't get the bearings or preload adjusted correctly on that crank spindle. It should be fairly easy for them to do. It probably was like this right out of the box, too...I can't believe this would be something that would loosen up that much over time, though I guess that's possible.
hokiefyd is offline
Likes For hokiefyd:
Old 08-23-20, 11:06 AM
timgriffin2
Quoted: 61 Post(s)
Funny you should say that about loosening up over time because that's exactly what they told me when I took it into the shop today. I told him it's only 3 weeks old and only around 100 miles on it. He said that he re-torqued it and it shouldn't return but if it does bring it back Time will tell I guess but I shouldn't have to keep returning for the same repair IMO...
