'93' Cadex ALM1 Fork Recall
Old 12-10-20, 09:18 AM
merlinrkd
Bikes: BMZ Performance Touring
Quoted: 16 Post(s)
Liked 7 Times in 5 Posts
Ancient stuff here! I've had the Giant Cadex MTB sitting for years. SunTour drivetrain. It came with the so-called butterfly shifters that never worked right. Recently got a set of Sun Tour rapid fire style shifters and installed them. Better. Did a Google on that bike and up pops a CPSC fork recall. The crown has a nasty habit of separating from the legs. Injuries, broken bones reported. Ouch ! Contacted Giant. Not much help there. I'd like to replace the fork. It's my understanding the fork is elastomer dampened and appears to be short stroke.The bike would be used for city with a rare smooth gravel jaunt. No plans for single track gonzo stuff. My question is: are there still forks made that are that design? 1 1/8" headless steerer.
merlinrkd is online now
Old 12-10-20, 09:22 AM
mack_turtle
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 424 Post(s)
Liked 455 Times in 271 Posts
please share some photos so we have a frame of reference. there are almost certainly forks available that will fit the bike, but they are most often heavy and poorly damped.
you might also find a rigid fork that will work well. the suspension on older bikes like that was often almost useless, so a rigid fork would probably do the job. put a fatter tire on it if you want a softer ride.
mack_turtle is offline
Old 12-10-20, 09:27 AM
mack_turtle
n00b
Quoted: 424 Post(s)
this fork should work, but make sure you can bolt a cable stop to the crown Bikeman Carver Bikes Steel Rigid Mountain Fork, 1-1/8'' 410mm
this bike?
this style of bike with carbon fiber tubes "glued" to aluminum lugs also have a bad reputation for coming apart. inspect it carefully.
Old 12-10-20, 09:33 AM
merlinrkd
Quoted: 16 Post(s)
That's the bike. Nice job! Deore thumb shifters? Is that frame carbon fiber tubes??? If it is I had no idea.
Old 12-10-20, 02:23 PM
70sSanO
70sSanO's Avatar
Quoted: 831 Post(s)
Liked 606 Times in 403 Posts
Call SRAM.
This might help give you some guidance...
https://www.bikeforums.net/mountain-...rk-recall.html
John
70sSanO is offline
Old 12-18-20, 03:29 PM
merlinrkd
Quoted: 16 Post(s)
Apparently I replied on the Rockshock post and it went a little sideways. As mentioned the Giant dealer couldn't find info on this recall because it was old. So it looked likeI was on my own. That triggered my post with this question about sourcing a vintage fork. I was just surprised by the dealer getting back to me last week. Apparently corporate found the recall info and has come back with a proposal to replace the fork or supply a new hardtail ! I'm hoping to keep the CADEX. It's one a of a pair I have. The other CADEX is several years newer and came with a Marzoochi fork that leaked with very modest mileage. I replaced it years ago. I like them because they have short top tubes.
The CADEX under recall discussion has a Zorbers fork. It's described as the legs separating from the crown causing injuries.
I'm still looking for vintage style fork that has a short stroke, cable stop on the crown brace and pivot posts for cantilever brakes. Oh-1 1/8" unthreaded steerer.
Old 02-24-21, 11:03 AM
merlinrkd
Quoted: 16 Post(s)
Update on the Giant Zorbers fork recall. Giant suppled a new Talon bike to satisfy the warranty! I turned in the CADEX to the dealer. Hats off to Folsom Bike for a smooth process. They are great!
Likes For merlinrkd:
Old 02-24-21, 11:50 AM
70sSanO
70sSanO's Avatar
Quoted: 831 Post(s)
Just to understand this. Giant gave you a new 2021 Talon for your 1993 Cadex.
John
70sSanO is offline
Old 02-24-21, 12:56 PM
merlinrkd
Quoted: 16 Post(s)
Yup, quite a surprise for me. I got to pick size and color !!! The hydraulic disc brakes are quite the treat.
We went around a bit because I was hoping to preserve the CADEX with a replacement fork. It was just not feasible to replace the Zorbers fork. A new fork sits considerably higher and messes with geometry. Brakes would have to go from cantilever to V. Which changes brake levers too.
The CADEX wasn't a cheap bike back in 93.
