Modern Hub on old bike
Old 02-26-21, 01:06 PM
eyemkeith
eyemkeith's Avatar
Bikes: 1992 Bridgestone XO-2
Quoted: 30 Post(s)
Liked 31 Times in 17 Posts
Hi all. I'm hoping you smart people can help me.
I'm looking at a new set of wheels for my 90s Bridgestone XO-2 - its first ever new set of shoes -- and I've found a set that I like but I'm not sure I can pull it off on my bike.
The rear is 130mm spacing, which is fine for me, but it's got a 10-speed cassette hub on it. My bike is old and runs 7-speed. My questions is: Should it matter how many speeds there are if it still has the same 130mm spacing? It'll fit regardless, right?
Thanks in advance.
Keith.
eyemkeith is offline
Old 02-26-21, 01:20 PM
alcjphil
alcjphil's Avatar
Quoted: 1101 Post(s)
Liked 486 Times in 325 Posts
Yes, it will fit if your dropout spacing is 130mm. In order to use a 7 speed cassette you will need a 4.5mm spacer installed behind the cassette
alcjphil is offline
Old 02-26-21, 01:27 PM
Dave Mayer
Quoted: 771 Post(s)
Liked 125 Times in 84 Posts
Yeah, a wheel with a 130mm, 10-speed compatible cassette hub will work. Confirmed that you will need the spacer to fit a narrower 7-speed cassette.
These wheels are now selling for a song as bikes have moved on to 11-speeds (and beyond); 10-speed wheelsets will not fit most wider 11-speed cogsets.
If you have access to older parts, or a bike Co-op, then an even better solution would be a wheel with a 7-speed cassette hub with 130mm stay spacing. All things being equal, this will be superior due to less dish, and more even spoke tensions, right and left.
Dave Mayer is offline
Old 02-26-21, 02:21 PM
eyemkeith
eyemkeith's Avatar
Quoted: 30 Post(s)
Thanks, guys. I should have been clearer, tho. If it fits, I'd just as soon go with a 10-speed and give the old girl a little upgrade.
Old 02-26-21, 03:19 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1301 Post(s)
Liked 499 Times in 384 Posts
IF you have a triple in front, you might also consider 9 speed.
Look at the cog combinations that are available in both and determine which cogs you really want.
IF you have no need for an 11T cog for example, no sense getting a cassette with one. Ditto for overly large cogs.
I run a 13-25 & 12-27 on my 9 speeds and they give me pretty much what I need for each bike without cogs I don't need.
Bill Kapaun is offline
Old 02-26-21, 03:28 PM
70sSanO
70sSanO's Avatar
Quoted: 831 Post(s)
Liked 599 Times in 400 Posts
I’m assuming you are running moustache bars with thumb shifters. You can friction shift or get Microshift thumb shifters.
10 speed chain on 7 speed crank might cause the chain to float between rings.
9 speed might be a better option.
John
70sSanO is offline
Old 02-26-21, 05:04 PM
Bill Kapaun
Originally Posted by 70sSanO View Post
Iím assuming you are running moustache bars with thumb shifters. You can friction shift or get Microshift thumb shifters.
John
Considering the fewer # cogs, the DER cages are a little wider.
This might result in sloppier indexed shifting as the chain gets narrower.
If friction shifting, no problem.
Old 02-26-21, 07:51 PM
eyemkeith
eyemkeith's Avatar
Quoted: 30 Post(s)
I think I am leaning toward the 9-speed cassettes, actually. Seems like that fits me best. Plus, they're about $20 cheaper.
And to answer questions: I run a triple up front and use bar ends, exclusively in friction mode. I really don't care for index much.
Should I go with the 9-speed cassette, this requires of course a spacer of some width on the hub, and a 9-speed chain. Does this then require me to swap out my 30-year old crank as well? Doesn't seem like it should.
Old 02-26-21, 07:58 PM
Bill Kapaun
8 or 9 speed cassettes don't need a spacer on an 8-9-10 speed hub.
The "stack" is about the same width with the greater "speed" cassettes having thinner cogs & spacers.
Scroll down just a little bit-
https://www.sheldonbrown.com/cribsheet-spacing.html
Old 02-26-21, 08:23 PM
eyemkeith
eyemkeith's Avatar
Quoted: 30 Post(s)
Oh, awesome. That's great!
Old 02-26-21, 08:30 PM
70sSanO
70sSanO's Avatar
Quoted: 831 Post(s)
Once upon a time there was concern about a 9 speed chain floating in between chainrings on a 7 speed crank but I believe it was more of a Shimano concern. I don’t think there will be an issue.
If you are so inclined there was a work around from yesteryear to run 9 speed middle ring, good luck finding one today, based on the positioning of the chainring teeth. The inner ring can easily be accommodated by sanding down the inner ring spacers.
John
70sSanO is offline
