Derailleur Adjustment Issues
Intrepid Bicycle Commuter
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 76 Post(s)
Liked 94 Times
Bike mechanics, I need your help. Here is my dilemma. I have a vintage steel Hardrock, and have installed a Microshift Advent X rear derailleur onto it. It shifts well, except for dropping back onto the smallest cog.
With the high limit screw backed fully out, the derailleur’s guide pulley just doesn’t come out quite far enough, to line up with the small cog.
Also, the derailleur’s b-limit screw, adjusted all the way, is barely making contact with the ramp on the bike’s dropout. If I back the screw out at all, it misses the ramp entirely.
I tried the fix the high limit screw issue by inserting a washer between the derailleur and the bike’s dropout, but that caused the b-limit screw to move outward away from the dropout’s ramp altogether, and not make contact at all.
So my big question is, would something like a Wolf Tooth Goat Link solve both of my derailleur issues? Would it place the derailleur slightly further outward from the dropout, allowing me to screw in the high limit screw to get things lined up? And would it serve as a surrogate, to get proper contact with the bike’s dropout ramp?
If not, and good ideas on how to fix these issues?
Here is a pic of how the b-limit screw is hitting currently.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Bent hanger can cause the high limit issue
Quoted: 1438 Post(s)
Liked 1,092 Times
How many speeds is your shifter/cassette? The advent X is a 10-speed derailleur. This document states that it is compatible with Advent X shifters opnly: https://www.microshift.com/en/product/rd-m6205am/
Quoted: 76 Post(s)
Liked 94 Times
I think I know the answer on the high limit screw adjustment. To get the Advent X to work with my ancient 7-speed wheel, I replaced the old freehub body with an 8/9/10 speed freehub body, and re-spaced the rear hub on the axle. I bet I moved the hub a little too far away from the dropout.
Quoted: 76 Post(s)
Liked 94 Times
I’m using an Advent X shifter, derailleur and cassette.
Really Old Senior Member
You'd remove the extra 3-4mm spacing from the NDS and redish the wheel to do it properly.
Quoted: 76 Post(s)
Liked 94 Times
I bought just the freehub body, no cone or locknut parts with it. So I had to monkey around a bit to make it work.
Apparently you need better trained monkeys.
Quoted: 76 Post(s)
Liked 94 Times
