lacing pattern for 28 hole rear rim brake wheel
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Per the title, I have a wheel that I'm rebuilding for a road bicycle. It is used for tarmac only, no gravel and no racing: just riding for enjoyment and exercise. I'm fairly light at 150 lbs and the wheel is 700c
The wheel had a 28 hole 2X pattern. I will reuse the rim as it is in great condition but will replace the hub and spokes (the hub isn't smooth anymore even after an overhaul). From what I've read, 3X is the strongest way to go for the least spoke weight penalty.
I'm thinking of doing either a 3X pattern or a 3X drive side:radial non drive side. What is the benefit to either one?
Would love to hear opinions on this.
Thanks
Thanks
Quoted: 194 Post(s)
Liked 204 Times
Ah, it is always good to see people tackling spokes
My question is how much of a benefit do you expect to derive from minimising the spoke weight, since you are not intending to race? I only ask because if the wheel has been a success in its current pattern, why not continue with it - or does the front wheel already have a 3x pattern?
Lacing pattern has a minimal effect on the wheel, to be honest. To reduce stresses on the hub flange it's good to get the spokes nearly tangential. 2x is the convention for a 28h rear wheel and there's no real advantage to lacing it 3x. 3x would also be fine, though with some hub geometries you run the risk of having the spokes overlap each other spoke holes which isn't great.
Radial NDS has the pretty slight, relatively theoretical advantage of reducing fatigue on those spokes (which they are more susceptible to being under lower tension) because it effectively keeps any torque from being transferred through those spokes, assuming the hub shell effectively transfers torque. It also means that you can lace all heads in or out. All heads in seems more common, which slightly increases NDS tension at the expense of slightly worse triangulation and lateral stiffness. It definitely looks fancy. For what it's worth my personal, stupid light aluminum road wheels are laced 24h 2x in the front and 28h radial/2x rear, mostly because it was fun to lace and looks cool.
TLDR: You should probably lace 2x. Lace radial NDS if that sounds fun or you think it'd look cool.
Likes For cpach:
Quoted: 345 Post(s)
Liked 237 Times
Ended up doing 3x both sides. No overlap of spokes on flange.
my first wheel build - pretty fun learning experience!
Quoted: 4208 Post(s)
Liked 3,874 Times
Good job! 3X on both flanges is what I was going to suggest. So many people think that spoking does something to with making them faster... Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Likes For davidad:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Ok teaching moment for me, but isn't 28 spokes, 28 spokes from a weight standpoint? Or is there some miniscule spoke length difference here?
Quoted: 2026 Post(s)
Liked 1,096 Times
Radial lacing uses slightly shorter and slightly lighter spokes than 2X and 2X uses slightly shorter spokes than 3X. The weight differences are trivial but there are those who agonize over the slightest amount.
Really Old Senior Member
As a rule of the thumb, I figure 3>2 saves the weight of about 1/2 spoke.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I was taught to get the spokes as close to tangential as possible. In my experience, most 28 spoke road or mountain wheels fall right in between 2X and 3X, so I usually go with 2X because it eliminates the chance of crossing the spokes at the flange and (as Bill mentioned above) is marginally lighter.
As for the OP, it appears your 3X is no weaker than 2X would be, so go enjoy the pride of riding on wheels you built yourself.
It's like riding a bicycle
Likes For urbanknight:
