Shimano Ultegra 9sp Running Gear Compatibility
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 102 Post(s)
Hello friends, doing some maintenance on brothers bike and need to order some parts, so wanting to know if there is any compatibility issues with other brands or even different Shimano products.
Don't mind either way but don't want to chase a rare part when something else will do/will work.
He is rough so can't tell him to go easy, he is miles away so I can't drop in to do running repairs and it's a high mileage bike.
The components would be -
• Cassette
• Chain
• Outside Chainring
The cassette is a Shimano Hyperglide CS 6500 12-21
Any help would be greatly appreciated.
• Cassette
• Chain
• Outside Chainring
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 326 Post(s)
Liked 234 Times
Shimano parts are readily available for that bike but please, tell your brother to do some maintenance every now and then. IE-cleaning- that cassette and chain are disgusting haha. If you're just looking to save some money there are many off brands that are Shimano compatible for less money, but nothing should be rare or hard to find. Good luck,
Quoted: 102 Post(s)
Thanks for responding, yes he cleaned the next day apparently...
No so concerned saving money per se, but will an Ultegra cassette work better than an Altus or Alivio etc and;
because of ramps and pins, will the correct Ultegra chainring work any better than any 105 or Dura Ace (with correct BCD) of later or same era etc?
Cheers
Cheers
Quoted: 834 Post(s)
Liked 610 Times
I do have to laugh when I read that you have to replace a 53t chainring and a 12-21 cassette. That is pretty serious riding.
You can find Shimano SG B-53 130mm 9 speed chainrings on eBay. Either a 6500 or 5501/02 should be the same.
The cassette is up to you. I doubt you will find a 12-21 9 speed cassette. But you can get a Sunrace, SRAM, Shimano 11-25. Since 9 speed is not as popular as it used to be, there is a very small market for a 9 speed with a 21t or 23t large cog.
I like KMC chains, but SRAM or Shimano are fine. Make sure you get one with a master link.
You might want to add cables and housings to your list. Last thing you need is to get there and find old and/or frayed cables.
Maybe brake pads???
John
Maybe brake pads???
John
Quoted: 390 Post(s)
Liked 184 Times
Maybe brake pads???
John
Maybe brake pads???
John
Unless you actually think he's been replacing cables routinely, get a set of brake and shifter cables + housing and just do it. He can probably send you photos of the brake pads, but that's also something you might want to just assume he needs.
I have seen a few "new old stock" complete 6500 cranksets on eBay. Depending on what you find for availability / price for the chainring (I haven't been shopping for those, so I don't know), that might be an option worth considering.
There are a few 6500 cassettes kicking around out there, but a lot of vendors show them as out of stock. I was able to buy a 12-27 a while back for not-crazy money.
I see some new ones on eBay in 11-21, but I don't think I'm tough enough to manage that!
Quoted: 102 Post(s)
Thanks to all that responded, will do the chainring (53), cassette (13-23), chain, brake and gear cables.
SRAM 9 speed cassettes will work if you find one cheaper than shimano. I use SRAM chains because I like the quick link.
