Do Cool Stop Salmon Pad Have a Break in Period?
Old 10-10-14, 09:58 PM
rommer25
Bikes: Windsor Carrera Sport, Fuji Absolute 3.0, Cannondale H400
Liked 3 Times in 2 Posts
I had these Cool stop pads installed on my Fuji Absolute while have routine adjustments at Performance Bike. The breaks did not squeal but were wearing down. When I got my bike back, the front wheel squealed very loud. The back if fine. I took it back and the mechanic tried to adjust the pads but without success. He told me that due to the residue left by the former pads, I needed to break in the new Cool Stop Pads. I never heard of this. If this is so, how long should one expect to wait before the noise stops. If this is not so, I will return the bicycle and ask them to fix it right. I would appreciate opinions from people that have experience with these pads. TM.
rommer25 is offline
Old 10-10-14, 10:03 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 2405 Post(s)
Liked 2,045 Times in 1,052 Posts
You can use a Scotchbrite pad to clean the residue off of the rims.
As far as squealing, that is an esthetic issue, not a functional problem.
Some people play around with toe-in to get rid of it.
I don't bother, and on the rare occasions I've had it, after some use it went away.
Shimagnolo is online now
Old 10-10-14, 10:43 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2792 Post(s)
Liked 733 Times in 516 Posts
1mm of toe-in usually works for me.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 10-11-14, 12:31 AM
ofgit
Senor Puppet
ofgit's Avatar
Bikes: Mostly '80s MIJ steel.
Tape a piece of card stock from the pad's packaging at the trailing edge and snug everything down to get the toe in. Might have to fold it to get it like you want it.
Disclaimer: Remove the shim before riding.
Old Fat Guy In Tights.
ofgit is offline
Old 10-11-14, 04:25 AM
Kopsis
Kopsis's Avatar
Quoted: 83 Post(s)
Even with proper toe-in, new Kool-Stops can shriek like a banshee. It may take 100 - 200 miles for them to bed in and quiet down. You can sometimes speed up the bedding process a little by sanding the braking surface of the pads with some 200 grit sandpaper, but I really think it's heat cycles from actual use that eventually quiet them down.
Kopsis is offline
Old 10-11-14, 08:28 AM
spdracr39
spdracr39's Avatar
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
Cycle them by doing a few brake drags and they will "seat in". The squealing should stop after that. Mine still made a little noise occasionally after that but it was rare.
spdracr39 is offline
Old 10-11-14, 08:39 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,308 Times in 821 Posts
maybe the surface left from the mold release in manufacturing can be sanded off.
fietsbob is offline
Old 10-11-14, 09:15 AM
Barrettscv
Have bike, will travel
Barrettscv's Avatar
Quoted: 848 Post(s)
Liked 165 Times in 100 Posts
+1
Clean the rim with alcohol to remove grease and grit. Then just ride the bike and after a few extended rides, the squeal will go away.
Barrettscv is offline
Old 10-11-14, 09:28 AM
kingston
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1505 Post(s)
Liked 298 Times in 196 Posts
Mine actually squeal more when I clean the rim, so I stopped cleaning the braking surface on the rim. One less thing to worry about.
kingston is offline
Old 10-11-14, 10:56 AM
Barrettscv
Barrettscv's Avatar
Quoted: 848 Post(s)
Considering that it's common for chain lube to contaminate the rim, you may be risking the safe function of the brake.
Old 10-11-14, 11:28 AM
kingston
Jedi Master
kingston's Avatar
Appreciate the concern, but it's a risk I'm willing to take. In any case, my bikes are immaculate. There is no chain lube on my rims, just a little brake dust that keeps them from squealing.
kingston is offline
Old 10-11-14, 12:24 PM
fietsbob
Bikes: 8
you apparently dont mind replacing the wheel's rims more frequently , due to the abrasive grit left there.
fietsbob is offline
Old 10-12-14, 01:17 AM
rommer25
I was wondering if the rim material might also be part of my problem. The back if fine; it's the font. I had to replace the font wheel when my bike fell off the back of my car a few months ago. The replacement is a cheap rim that the bike shop had in stock. I've been planning to buy a good replacement but have not got around to it yet. I adjusted the toe and cleaned the rim with Simple Green first and then with alcohol. I gues I'll keep using them and wait to see of they quiet in time.
rommer25 is offline
Old 10-12-14, 03:59 AM
kingston
Jedi Master
kingston's Avatar
you make a good point, fietsbob. I'll try cleaning them with alcohol to see if they start squeaking again. If they do, I may just be willing to tolerate shorter rim life to avoid the squeaking. They squeak the worst on my mountain (winter) bike which has an inexpensive set of sun rhyno lites that I wouldn't be too worried about replacing every couple of winters.
kingston is offline
Old 10-12-14, 06:37 AM
OldsCOOL
OldsCOOL's Avatar
Quoted: 634 Post(s)
Liked 457 Times in 251 Posts
That is what I do. Find a mild descent and apply the brakes lightly.
OldsCOOL is offline
Old 10-12-14, 10:15 AM
1 Miyata Biker
Bikes: Schwinns and Miyatas
I've always used rubbing alcohol for cleaning the brake area of the wheels. If they need a bit more attention in a problem spot, then a combination of the rubbing alcohol and 400 grit wet sand paper gets everything back in order. It doesn't take much pressure at all. You could also give the new Cool Stop brake pads similar treatment, along with a "toe-in" adjustment at the front of the brake pads. A cleaning/sanding "may" decrease the squealing, but a few hundred miles of riding is the best cure.
1 Miyata Biker is offline
Old 10-12-14, 12:58 PM
ThermionicScott
7-speed cultist
My brakes squeal a bit after the rubbing alcohol treatment, but it's very obviously because the pads are gripping the rims better (a good thing.) They always quiet back down after a bit, and I figure it's good practice to clean off the grit every so often.
RUSA #7498
Old 10-12-14, 01:06 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 659 Post(s)
Liked 290 Times in 188 Posts
I have had intractable squeal with Kool-Stop salmon pads when combined with new and/or very clean rims. My solution is to use the Kool-Stop black pads for a couple months and then reinstall the salmon pads when it starts to rain. They work great then.
Jeff Wills
Jeff Wills is offline
Old 10-12-14, 01:46 PM
Al1943
I like the squeal, it lets the cars know where I am.
Al1943 is offline
Old 10-12-14, 02:13 PM
ThermionicScott
7-speed cultist
Or people, if you're on a MUP. Who needs to yell "on your left!" or ring a bell when a squealing brake not only alerts them to your presence, but that they made you slow down?
RUSA #7498
Old 10-15-14, 09:03 AM
pdlamb
Quoted: 1474 Post(s)
Liked 606 Times in 404 Posts
My "cleaning" is to wipe dirty rims down with a paper towel, folding occasionally to keep the wiping surface reasonably clean. The result is better braking after a rainy ride and/or extra chain lube hitting the rear rim.
It still squeals sometimes, but I second (third?) the sentiment of these posters:
pdlamb is offline
Old 10-15-14, 09:08 AM
RaleighSport
Hogosha Sekai
RaleighSport's Avatar
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 14 Times in 13 Posts
As others have noted I also have only ever had to do toe in, no break in perioud etc... love koolstops.
RaleighSport is offline
Old 10-15-14, 09:23 AM
JTGraphics
JTGraphics's Avatar
First off I'm a big fan of KoolStop pads and use them on all my bikes.
That said from my experience some rims just squeak and you can do nothing about it for any length of time, you may get it to stop for a little bit but it comes back no mater what you do.
Now I also have a Fuji crosstown it has the same kind rims low grade smooth non machined rims the front squeaked like crazy with KoolStops. The rear did not really have this issue I notice that it's seems this way on most bikes it's mostly the front that will squeak if you have this problem why? who knows.
I finally removed the fronts and put a harder pad on it stopped but the nice fill of the KoolStops are gone rear is OK with them.
All my other bikes have no issues with squeaking but the rims are much better quality.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
JTGraphics is offline
Old 01-12-15, 08:55 PM
rommer25
I wanted to update everyone who offered their helpful opinions. The noise never went away. I got a almost new rim that was taken off a Fuji Roubaix 3.0. The result of the switch is no more noise after only about 25 miles. I'm going to give the performance bike rim to a co-worker who said he wanted to replace his front wheel. I'm have already gave him notice on the fault I found with the rim.
rommer25 is offline
Old 01-14-15, 08:52 PM
lopek77
Bikes: With round 700c & 26" wheels
Even with the proper toe-in, and after 300 miled, my front is still as loud as my wife when she is mad. The rear was super quiet from day one. I love these pads, and I don't really care if they are loud or not. I guess it may be even a safety future on crowded city streets lol
lopek77 is offline
