'75 Motobecane Nomade Sprint
Old 10-23-14, 07:39 PM
Scratcher09
Scratcher09's Avatar
Bikes: '80 Miyata 210, '05 Fuji Team Issue, '75 Motobecane Nomade Sprint, 2010 BMC Racemaster, '77 Raleigh Grand Prix, '83 Raleigh Marathon
I just picked up this bike for $50. It was pretty crusty so I degreased it and it rides smoothly and shifts fine. I didn't want to push it on these rotted tires. I don't know anything about Motobecanes other than it was made in England. It just looked to me like a well made bike. I am thinking about putting aluminum rims on it. I've heard some older bikes can be swapped to 700c rims without problems because the brake shoes are adjustable enough to accommodate the 700c rims. Is this true?
Scratcher09 is offline
Old 10-23-14, 07:50 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 634 Post(s)
Liked 457 Times in 251 Posts
Made in France, wasnt it?
OldsCOOL is offline
Old 10-23-14, 07:53 PM
bikemig
bikemig's Avatar
Quoted: 4961 Post(s)
Liked 1,442 Times in 957 Posts
MBKs were made in France. You'll want to check the frame carefully as that is a replacement fork and the bike was quite likely crashed. No big deal replacing 27 inch wheels with 700c as long as the brake shoes can be adjusted down a bit.
bikemig is offline
Old 10-23-14, 08:08 PM
Scratcher09
Yes, I meant France. Frame looks to be in good shape. The rear rim has a texture on the surface that contacts the brake shoe, but the front rim is smooth.
Old 10-23-14, 08:20 PM
Scratcher09
What size chain would be on this bike?
Old 10-23-14, 09:48 PM
OldsCOOL
OldsCOOL's Avatar
Quoted: 634 Post(s)
My guess is that it has been wrecked which is why you have a different rim on the front with that odd fork. Let me guess, that is a chrome Rigida rim on the back, called a "superchromix"? The chain is just a standard 5/6 speed chain, readily available and cheap.
OldsCOOL is offline
Old 10-23-14, 09:50 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Still a garage full
Quoted: 842 Post(s)
Liked 52 Times in 33 Posts
The Nomade is Moto's entry level bike. High tensile frame and low end components? You paid about FMV for the as is condition of that bike. I bought one a year ago for $20 that needed a full overhaul. They ride nicely though, despite their weight. I would clean and overhaul the bike, replace the consumables, and not change the rims. Standard ten speed chain, about $9.00.
enjoy!
oddjob2 is offline
Old 10-24-14, 07:20 AM
Grand Bois
Grand Bois's Avatar
Quoted: 436 Post(s)
Liked 8 Times in 8 Posts
The shoes would have to be moved down 4 millimeters. You are in the best position to judge if that is possible. It doesn't look like it from here.
Grand Bois is offline
Old 10-24-14, 07:34 AM
Kobe
Kobe's Avatar
Quoted: 210 Post(s)
Liked 102 Times in 78 Posts
Your brake pads look like they are already as far down as they can go. You would probably need to buy long reach brakes to get to 700c.
There is nothing wrong with 27" rims, there are still a lot of tires still made for them.
If it were my mine. I would pick up a set of Panracer Pacelas and a 2 pair of Kool Stop brake pads.
'78 Chris Kvale, '88 Proteus, '07 Rivendell AHH, '13 Black Mountain Cycles Cross, '16 Clockwork All-Rounder, '19 Gunnar Sport
Kobe is offline
Old 10-24-14, 09:42 AM
icepick_trotsky
Aspiring curmudgeon
icepick_trotsky's Avatar
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 103 Post(s)
Liked 3 Times in 3 Posts
Weren't some Motos made in Switzerland? I know a lot of them have Swiss threaded bottom bracket, which are pretty much impossible to replace now. How does your crank feel?
"Party on comrades" -- Lenin, probably
icepick_trotsky is offline
Old 10-24-14, 10:10 AM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1577 Post(s)
Liked 464 Times in 273 Posts
To me, those brakes don't look long-reach enough to swap in the 700c wheels. This is a low-end bike; be careful what you spend on upgrades.
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is offline
Old 10-24-14, 12:37 PM
Scratcher09
The crank feels smooth. I think I can adjust the shoes down another 3 or 4 mm--more if I pull out my dremel. Not planning on spending much on this bike. Tires, maybe rims, chain, cables, and kool stops.
Old 10-24-14, 05:45 PM
noglider
noglider's Avatar
Quoted: 6815 Post(s)
Liked 1,416 Times in 907 Posts
I'm pretty sure they didn't make them in Switzerland. They used Swiss threads because Swiss threads are smarter than French threads. In other words, it's good to have a fixed cup with a lefthand thread.
noglider is online now
Old 10-24-14, 07:05 PM
icepick_trotsky
Aspiring curmudgeon
Quoted: 103 Post(s)
Where did the Swiss thread come from, then? Are there any Swiss marques? Motobecanes are the only bikes I ever hear of with that threading. Perhaps they were never exported.
Old 10-24-14, 07:12 PM
Bledfor Days
Bledfor Days's Avatar
Bikes: Vintage cheapies and some modern stuff.
This is my 74 Nomade with new Sun CR-18 271/4 wheelset. I just snagged a Motobecane leather saddle for it. Cottered cranks on this one.
File Type: jpg
Bledfor Days is offline
Old 10-24-14, 07:21 PM
noglider
noglider's Avatar
no permission to view the picture.
auchencrow
Classic & Vintage
38
03-02-18 04:59 PM
ThermionicScott
Classic & Vintage
13
09-29-17 07:55 PM
thehammerdog
Bicycle Mechanics
34
09-28-14 11:05 AM
siggy2xc
Bicycle Mechanics
6
08-26-12 10:32 PM
Elduchey
Classic & Vintage
15
02-01-10 09:13 PM
