New to wrenching; making some silly mistakes. Share yours?
Quoted: 146 Post(s)
My latest one was trying to use chain tension to secure a master link... with the master link on the bottom of the chain circuit. I was literally jumping up and down on the pedals (super bad for my poor Fuji, I'm sure), and sweat was pouring off my forehead, before it finally dawned on me that I was putting literally zero tension on the master link.
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 290 Post(s)
Liked 58 Times
The other day I was working on my bike. I was tightening up a stem bolt and a spoke fell off. So I laced it back up through the tire. Then I torqued the seat post clamp putting a kink in my rear brake cable. After that I pumped up the bar ends and greased the frame bearing.
Quoted: 86 Post(s)
not a bike story, except it happened during my daily ride.
i stopped at the Starbucks for my habitual small plain coffee that costs $1.95. i pulled two singles and a five out of my wallet and layed down the two singles. the young woman quickly had my coffee, picked up the two singles and headed to another cash register to get my change. i walked after here, and and when she handed me my change, i had somehow forgotten, probably because i had been asked a question by one of the other customers, that i had already paid, and handed her the five.
she immediately squealed to her workmates, "oh, my, a five dollar tip!". then quickly put it in the tip jar.
after that, there was nothing for it, it was over in a flash, the damage had been done and there was no good way out of it. to make matters worse, she probably thinks i'm some pitiful old man trying to impress young ladies by over tipping. jeez!
Quoted: 86 Post(s)
Quoted: 27 Post(s)
5 minutes in the cold trying to thread a pedal in the wrong way.
In spite of correctly saying 'ok, THAT way to tighten', kept trying to install it the other way!
Bikes: 91 Trek franken '81 Schwinn Voyager
Quoted: 9 Post(s)
I've mounted brake shoes incorrectly and shredded a brand new tire, tried to remove a crankset and missed the washer, mounted a bottom braket backwards so the rings hit the chainstay, cross threaded a bottom bracket, laced several wheels wrong, etc. It's all good stuffl-I'm a lot smarter now than I was before....
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 383 Post(s)
Destroyed a stem by over torquing the screws - the stem manufacturer even etched the proper torque range on the stem in a very visible location. It was on our tandem, wife not happier either, as it took almost week to get a replacement of the correct size. Also got a precision torque wrench so that will not happen again.
Lacing up spokes incorrectly - didn't figure out until the third of four groups of spokes that I had started one off, and there would be extreme difficulty in getting the pump chuck on to the valve......had to take it all the way back to the first spoke.
Bikes: '80 Miyata 210, '05 Fuji Team Issue, '75 Motobecane Nomade Sprint, 2010 BMC Racemaster, '77 Raleigh Grand Prix, '83 Raleigh Marathon
Been working on cars and motorcycles for decades and recently got into cycling. While putting together my first modern bike with sti shifters, I thought I could break down an Ultegra 9 speed shifter to clean and lubricate it. Didn't take me long to realize I could not even begin to get it back together. And all LBS I went into would not touch it. Worst part is worked fine before I disassembled it.
Sunshine
Quoted: 5006 Post(s)
Liked 2,312 Times
I typically don't have major issues when rebuilding bikes, just random mistakes that always come from not paying attention. I work on almost only 80s bikes, so its not like I have a bunch of difficult new tech to account for.
Just last night I was putting some components together while watching tv. I ended up installing a brake shoe/pad on the outside of the caliper. I actually looked at it for a few seconds confused because it didn't look right but I couldn't figure out why. That's how little I was paying attention.
I also installed the rear wheel skewer on the wrong side- the QR was on the drive side.
Just little things that I end up doing because I am not paying attention and catch right after doing them- I clearly cant multitask.
Latest random mistake: Installed the cable end on my rear brake cable, then realized I didn't install any donuts on the cable itself. Oh well.
Quoted: 4362 Post(s)
Liked 24 Times
Gee, I hope this was a suspension fork.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FB
Chain-L site
Bikes: Pashley Roadster Sovereign, Cycles Toussaint Velo Routier, Yuba Mundo, Raleigh Sports (1970)
Quoted: 21 Post(s)
First time I used a crank puller I failed to remove the larger plunge adapter, which was not needed for the crank style I was removing. Needless to say, after completely shredding the removal threads out of the aluminum crank, I had to resort to removal with some more archaic tools.
Hello
Hey this thread should be called the amaetuer Hour.....I love the bike mechanics forum and have learned a ton from the pros who take the time to share....NOW for my public confession (please forgive me it was a very long time ago).....
I installed my sons ashtabula crank backwards (and chain and wheel)..pedaling forward would engage the foot brake. "Daddy my bike won't work". Arggghh!
Quoted: 146 Post(s)
When I was 13-14 I decided to make my 'stingray' cooler by replacing the 20" front wheel with a 16" wheel. I put it on and went for a test ride. Hammering down the street I decided to pull a wheelie. The last thing I remembered after waking up from being unconscious in the street, was the front wheel bouncing away from me.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 116 Post(s)
Liked 16 Times
I've been wrenching since I was 6 yrs old. Bicycles, mini bikes, go-karts, lawn mowers, outboard motors, motorcycles, cars, Army vehicles, my own cars (Jaguars), anything in the house that breaks. I don't expect to make any silly mistakes on a bicycle. The only recent one I can recall is, after spoking up a wheel, finding the label on the rim facing the wrong side, even though I had put some thought into making it face correctly.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano, 1987 Bottecchia Team C-Record, 1982 Colnago Super,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron Super Record
My C&V Bikes:
New Colnago C50 build, last bike I plan to buy, ever. Anxious to go for I ride all I needed to finish was to mount the stem on the carbon fiber steer tube. Stamped on the stem near the pinch bolts was "8 nm". With my new 1/4" drive Park TW wrench I gradually brought the torque up alternating between the two bolts. At 8 NM I get a loud pop and a 4 inch long crack. The new replacement fork was $800+. Lessons learned: 1) the torque value good for the pinch bolts was not good for the material being pinched. Mistake 2 was that I had not used the longer Colnago expansion plug but instead had used a plug that did not support the backside of the steer tube behind both pinch bolts. And 3, I had cut the tube 1/8 inch below the top of the stem with no spacer above the stem. Five NM is more than enough torque to mount a stem to a cf steer tube.
I know its a 10 year old story but one still worth telling.
Quoted: 146 Post(s)
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 248 Post(s)
Liked 36 Times
My mistake was I had a bike with a square taper triple crank, and I wanted to swap it out with a double I had. But the chain line was wrong. I figured I could over come it just by tightening the crank a little farther up the taper. Never did get the chain line right, but when it was time to service the BB, nothing I did would get that crank off again. Final solution was to take an angle grinder to the spindle and then hammer the s--- out of the part left in the crank till I finally drove it out of there. Was planning on replacing the BB anyway so it wasn't really a loss, but I wasted weeks trying different non-destructive means of removing that crank.
scott s.
scott s.
Bandolero
Bikes: ...
Quoted: 5195 Post(s)
Liked 164 Times
Liked 24 Times
The right direction is whichever direction you wan it to be. Since it doesn't have any mechanical implications, it's strictly a style statement and your choice. Hub stamp orientation is just one o those things that the OCD folks are trying to make a big deal out of.
FB
Chain-L site
FB
Chain-L site
