Can you install a front derailleur on any titanium frame?
I'm looking into titanium bikes and want a hybrid hardtail frame built for the road. I'm not finding many hardtails with front derailleur and am curious if there has to be a slot on the frame or does it just clamp on.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Most front derailleurs are clamped on to the seat tube. However, this is not to say that you can clamp a derailleur on to any bike - the tube may not be round in the area where you intend to clamp, or there may be some other obstruction there (a water bottle boss or suspension mount or something), or the tube may be some exotic thin walled stuff that is not designed to be clamped.
If the tube is round and there is room to mount a derailleur, and you are unsure, contact the manufacturer and ask if the bike is compatible with front derailleurs. I am not specifically familiar with any brands that are not compatible with front derailleurs, but better to ask than to risk crushing your new titanium frame!
There also used to be a style of derailleur attachment that Shimano called 'E-type' that were attached to a plate that was designed to be clamped under one of the (e-type specific) bottom bracket cups. With bikes going to 1X and press fit BBs and other changes in the last decade or so, I don't know if E-type is still an option.
Edit:
Also, not sure what you mean by 'hybrid hardtail' - a 'hybrid' generally refers to a bike with narrower tires and lighter construction than a mountain bike, but more upright position than a road bike. A 'hardtail' is a bike with front suspension but no rear suspension, generally an off-road focussed mountain bike. Technically, many hybrids have rigid frames and some sort of suspension fork, but the name hardtail is usually reserved for mountain bikes.
Also, "29"' wheels found on many modern mountain bikes are the same size as the 700c wheels found on most hybrids, and some have incorrectly commented in the past that 29" wheel bikes are 'just hybrids'.
Edit:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yeah, what he said.
While 1x seems to be the fad these days, some frames are designed differently knowing there will be no derailer. Mostly that applies to mountain bikes, but if the mfg does not offer a 2x option in there catalog- there may be a reason why.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
DSCN0934 by Stuart Black, on Flickr
Untitled by Stuart Black, on Flickr
Stuart Black
Stuart Black
