Ergotec adjustable trekking bars
https://www.ergotec.de/en/products/l...mium-25-4.html
Hi folks.
I was wondering if anyone owns or has tried these handlebars. Some feed back would be greatly appreciated.
Thanks
Hi folks.
Thanks
just crickets chirping ? .. Nope, I have ITM trekking bars that came via Koga of NL..
you may just have to go for it.. I think SJS Cycles sells something similar in UK. under a different brand name..
https://www.sjscycles.co.uk/handleba...p-black-600mm/
not impartial but they do reply to product inquiries ..
Thanks Bob, but after thinking about it for a while, I realized that if you sweep the handlebars back, the bar ends become unusable due to the angle. I'll try the trekking bar ends on my flat bars and see how that works out. Plus the joints (hinges) take up valuable real estate for lights, computer, etc.
I may just have to cough up the cash and get the Jones Loop bars
you could also try folding straight bars
https://www.aliexpress.com/item/CNC-...477779543.html
Modolo in Italy also makes a couple models Trekking Bars, SJS stocks those too, to see them online..
Bikes: Tout Terrain Silkroad Xplore Gold
Quoted: 11 Post(s)
I got some Koga Atalanta bars recently after reading about them on the blog of a guy I met touring in the UK:
Dark Newt: Koga Atalanta Handlebars & Bontrager Wrap with Bike Ribbon inserts
They are a bit more expensive than the Ergotec and I had to get mine from the UK at a cost of £138. Here is a picture of mine with the bars fully loaded with wrapping, mirrors, Ergon grips etc. Although I expected to use the verticals at the sides more (similar to bar ends) I have actually found myself alternating between upper and lower horizontal sections more.
I presently have butterfly bars and the angles for the side and far reach are a little too straight (right angled). The bar ends have the sides with a slight inward curve and the far reach have a slight upward curve, which is how I naturally place my hands. I already have the flat bars and the price is not bad, so I'll give the bar ends a try.
Thanks for the suggestions
Ergon GP 5 have a little forward hook to them..
The bar ends arrived today and just in time. They really show promise as they are completely adjustable. I leave in a couple days for a week long tour. Let's hope for the best
Status report
I just got back, had to cut the trip short by a day because of rain and dropping temps. I can say that the bars worked out quite well. Because my flat bars are wider than the butterfly, there is more hand room, and found the alternate hand positions much more comfortable than my butterfly bars. However, I am going to replace the hand grips with Ergon GP 1. Overall, very satisfied. Only downside, I lost the rubber caps almost immediately.
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
Do you have details on the trekking bar ends (manufacturer and model)? I want to see if they're available here in the States.
It seems they have a USA distributor through KHS. I picked them up through Amazon
I have the Basic Sport bars on my folder and really like them. With the Basic model the sweep angle is fixed but the grip angle is adjustable. I found the foam padding insufficient for longer rides so I wrap over it with cork bar tape. I should also note for a more aero option I added clip-on aero bars.
I have yet to see 'gel' tape that is any more than a way to keep the wrap from slipping an opening a gap.
so more a reusable adhesive than a real cushion, functioning like the Gel Pads, made for drop bars under tape.
Do Share.. your all gel tape find..
[ I have been double wrapping foam tape for diameter and cushion.. (on ITM trekking bars)]
Proud hobo biker
Quoted: 202 Post(s)
https://www.ergotec.de/en/products/l...t/touring.html
Found them on Amazon but no longer carried. The nearest KHS dealers are about 50 miles away, but might stop by next time I'm in Austin.
