Does this fork look bent? Trek 610
Thanks.
Quoted: 18369 Post(s)
Liked 4,507 Times
Should that model of bike have braze-ons for downtube shifters?
Thanks.
Quoted: 2362 Post(s)
Liked 1,749 Times
My '82 613 did not have braze-on shifter bosses.
Cyclist
Even my 84 610 didnt have bosses
Yes - the original 1983 (?) brochure photo is hard to see, but the DT shifters look like they had a clamp/strap attachment to the down tube. I should have realized this myself because I have a 1984 620 that had the clamp/strap set-up when I got it.
If the seller provides the serial # as I have requested all will be known.
The subject bike is one size up (appears to be 24") from my 410 and 620 - might be a slightly better fit. The bike needs many new components and it would be fun to try a set of 650b wheels I have on it.
To really know, you have to pull it out seek out a shop with this tool:
Park tool bike fork alignment checker a reference to straight .. fore and aft
and each blade can be bent.. out of whack..
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Some Treks from that approximate era had a single aero boss atop the downtube, or had a clamped-on aero Symmetric shifter.
Quoted: 796 Post(s)
Liked 522 Times
Someone went home made Single speed and a bit crazy with the stickers, could be a nice resurrection though.-for the right $$
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 691 Times
If you find a brazed on clamp stop under the down tube, that would confirm no shifter bosses originally. My 1984 Trek 520 came with clamp-on shifters with a clamp stop under the tube.
Liked 1,749 Times
^^^ That's exactly what you'll find on an '82 or '83 61x. This one appears to be an '82; looks like the rear der. cable stop is on top of the chainstay. (Hard to tell for sure with the background.)
And yeah, bike needs TLC/intervention/deprogramming. Handlebar looks mummified.....
Liked 1,749 Times
Liked 4,507 Times
Sorry about sending the thread down a rabbit hole.
I think the question about the fork was answered.
Some people have found surprises lurking under stickers. I've heard of denting the downtube with the font brake, but that may well be in front of where the sticker is. Anything hidden?
Look at the large gap between the rear wheel and seat tube - it has long chain stays and the color looks to be 'Pewter' - it may be a 6xx - definitely pre-1984 with the old-style decal.
I looked at the '82 and '83 catalogs and the only 'pewter with red panel (decal)' I could find was the 1982 736 - but the chain stays look too long for a 736.
Maybe @The Golden Boy can identify this.
Still no response from the seller re: my request for a serial #..
Here's another photo from CL - looks like there is a bottle cage bolt sticking down from the bottom of the down tube - given this feature and the long chain stays it may be a 620.
www.theheadbadge.com
Quoted: 2421 Post(s)
Liked 4,388 Times
Liked 1,749 Times
That material on the ground looks like ground-up Kentucky coal; makes it almost impossible to distinguish minor frame features from background. I don't think any of the pre-'84 bikes had bottle cage bosses on the bottom. And pre-'84 6xxs should all have rack braze-ons. The other possible 411 source would be @JohnDThompson . Seems like even the serial number can lead to as many questions as answers; still worth getting if the seller ever coughs up.
Edit - is it now sporting 700s? Brake blocks are at the bottoms of the slots, suggesting the possibility. That would explain what would otherwise appear to be a long wheelbase (tire / seat tube gap).
In any event, it's a nice old Trek with good bones remaining, and weeping for a true C&Ver to bring back at least some semblance of her previous glory. A set of old Blue Lines and Power Ratchets would wake her right up, turn the pumpkin back into a chariot.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,699 Times
Commence to jigglin’ huh?!?!
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
1983 400, came in silver with red panel, and the fork crown and crankset match the pictures. Chainstay looks long because of the switch to 700c wheels, the P.O. removed the big ring, and it's a 24" sized frame.
Quoted: 27 Post(s)
Liked 7 Times
But that catalog photo ^ shows under-the-chainstay cable routing, and in the craigslist photo I'm pretty sure I see the little bell cable stop on top of the chainstay.
I believe this likely puts it as earlier than '83.
It looks quite a bit like my '81 710, but mine has rear rack mounts on the seatstays, and the chainstay cable stop on mine is also a different shape.
My guess based on all this and the observations above was going to be '82 730 or 736. But the catalog photos seem to show under-the-chainstay routing for those models -- and above-the-chainstay routing for the more "touring" oriented models! A transitional year, I guess.
Whatever it is, if it is cheap, and I were in your shoes, I'd snatch it up.
Here's mine:
Here's mine:
Quoted: 684 Post(s)
Liked 370 Times
Here's mine:
Here's mine:
520 1984
610 1984
620 1984
720 1983
Quoted: 684 Post(s)
Liked 370 Times
