Gunnar for a Clyde?
Bikes: 2012 Surly LHT, 1995 GT Outpost Trail
Gunnar for a Clyde?
Hey folks, long time no see. I'm still truckin. Hit 10,000 miles on my LHT and I'm thinking of buying a new roadie to celebrate the milestone.
I'm looking at the Gunnar Fastlane and Hyper-X frames. At this point I'm thinking I'd like something a bit more sporty than the LHT, so I can keep up with my clubmates a bit easier. But I'm unsure of whether that's a wise choice. Will the shorter wheelbase cause issues for an uberclyde (350+)? Or are there any other considerations I should take into account?
Other frames I'm looking at in the off-chance that I decide Gunnar isn't right for me are Surly Straggler, Kona Rove, and Salsa Vaya.
Quoted: 18373 Post(s)
Liked 4,507 Times
The LHT sounds like it should be a great bike. I'm not sure I'd rush to replace it. Have you tried other bikes? Friend's bikes?
Both the Fastlane and Hyper-X sound like they accept big tires (38mm) which should be nice. Are these bare frames or complete bikes. The photos seem to indicate "enough" spokes.
It is an American company. Send them a note and ask about rider weights.
If I was getting a custom frame made, I would seriously ask about getting a 48h hub and 145mm rear dropout spacing, although that does put you pretty custom for replacement parts in the future too, although a steel frame should flex enough to mount a narrower wheel in a pinch.
I'm not sure about the shorter wheelbase. Issues with touring are often related to too much weight too far back on a rack, and kicking one's bags. I don't like my folding bike because it is too short, and too upright, thus I have troubles keeping the front wheel on the ground when climbing.
I actually run some pretty strong 32h wheels at the moment, and I've never had issues with my 36h's. As I'm on the optimistic side of weight loss, I'm probably just going to go with 32 or 36 again. Having gone 10,000 relatively trouble-free miles, I don't really feel 48h are necessary. What does the 145mm spacing get me, though? I've been running 135.
I bought a Crosshairs last August and really like it. It rides great and I weigh 280. I have no problems with the cantilever brakes, they are Avid Shoty 4's and I descend down some steep stuff here in West Virginia.
Lost at sea...
Bikes: Schwinn Paramount (match), Trek 520, random bits and pieces...
The big reason I'm looking for a new bike is because the cantilever brakes on it are sub-par for the hill rides I've begun doing in the past year. Pretty much every major downhill I've done has caused me to want to **** my pants, and I need a better braking solution. So I'm thinking discs are the way to go here.
Liked 4,507 Times
The wider the dropout spacing, the less dishing required on the rear wheel. Thus, more of the weight is distributed between the right and left spokes, and theoretically a stronger wheel with fewer spokes.
Ideally one could make a no-dish rear wheel which would be essentially as strong as the front wheels.
Of course, that is really limited to the tandem market, but there is no reason why it could not be incorporated in a road bike.
I suppose I don't see why a company wouldn't be able to make bikes specifically for heavyweights when working in the custom market.
It does sound like you're doing well with your current bike. 10K miles is good!!!
I was seriously considering a Gunnar Sport before coming across a very nice used Bianchi frame that I'm building up now. If the Bianchi doesn't work out, chances are good that I'll transfer the parts over to a Gunnar.
Quoted: 2604 Post(s)
Liked 1,927 Times
One other thought, check out Zinn bikes, specializing in big bikes.
Hills were a matter of faith, at 285 with a light pack.
My BB7's are marvelous.
Thought about a DT?
I built up a custom,
Tiagra STI's and 22,32,44 11-32 gearing.
Likely about moving up a couple on the crank next chain, as I'm down to 250...
48sp chukkers on ph disc hub... Never been out of true, not even after a hard landed airborne bit with about 50lbs in the pack.
Overkill? YEP! but always get me home...
Quoted: 18409 Post(s)
Liked 15,530 Times
I don't understand this. My LHT with me and a full load for a camping and cooking tour is about that weight. The stock cantis have been fine for descending mountain passes, some of them unpaved, and steep eastern grades, even in rain, snow and sleet. Switching to Kool Stop Mountain Salmon pads has made them more effective.
The Fastlane has heavier/stronger tubing than the Hyper-X, so it would be better suited to a Clydesdale, but I think in the larger stock sizes Gunnar also uses heavier/stronger tubing instead of the True Temper OX Platinum. Both have such close geometries that you probably couldn't tell the difference in handling, and both are well suited to the type of riding you're talking about. Something that can be ridden anywhere (dirt/gravel/trails/double or singletrack) but would also be right at home in fast group rides and centuries. That's exactly why I just had a Hyper-X built after demoing a Crosshairs on the Honey One Hundred, which I rode on Clement X'Plor MSO 40mm, which just barely fit.
As noted above by laxpatrick, I've heard Richard Schwinn would probably talk with you on the phone to answer any of your questions if you called Gunnar/Waterford.
I have a Gunnar Crosshairs. I selected the custom geometry option because of my long legs/short arms. They also built the bike based on my weight and I think they over did it (it's too stiff, IMO). You can get them to do anything you want if you work through your LBS. It was never flexible at all and after losing weight, it's even worse.
Gunnar is a insanely conservative company. If you flag them on the weight issue, they'll probably overdo it (almost certainly would).
If I had it to do over again, I'd probably build a Sport instead of a Crosshairs. It will fit the largest tires I need (35c) for unpaved trail riding anyhow and I like the geometry much better - more bottom bracket drop is good.
J.
J.
J.
J.
This is very helpful to me. I contacted Gunnar to see what they said, and they basically came back with "no way will our stock frames work for you, let's build something totally custom", which had me suspicious. They claim their frames are rated for up to 300 pounds. Likewise, the Surly LHT I've been riding for 4 years is rated the same, and I've had exactly zero issues with it. I'm thinking that a stock frame *will* be fine, and they're just trying to cover their asses.
Now, about flex. What's the deal there? Some people tell me stiffer frames are better, some people say flexy frames are better. Personally, I feel a little weirded out when I feel my frame flexing... but you seem to think that is better? Any particular reason why?
I also have a standard carbon fiber 2007 vintage Lemond Versailles. That is much stiffer and none of that happens, but there is some flex side to side in the bottom bracket. The Gunnar Crosshairs that I have is so stiff in the bottom bracket that there is no horizontal or vertical flex that I can see. It's really stiff and doesn't have as much vertical compliance as I would like and I attribute that to the overbuilding of the frame.
My Crosshairs weighs in at about 22 lbs with tubular tires on Al rims. With clinchers, it would be around 23lbs. When I add up the component weights carefully and even give them a heavy fork weight, the frame still comes in at just under 4.7lbs. That's a massively heavy frame. The bike frame I'm having built right now for my road bike will be in stainless and lugged - all of that should be heavier - and it's going to come in at 3.8lbs or less (1725g) and a ~16 lb bike when done. When I had the Crosshairs built, I weighed in at 250. So this is a lot of overkill, IMO. I'm 25lbs less now and this is way too stiff of a frame for me. I feel more than I want from the road and that's on 28c tires. It was too stiff when I got it. At your weight, you should have a beefed up frame, but you don't want Gunnar to overdo it.
I also think the geometry would matter and you should look into that. I think the Sport would give a better ride and you may want to consider that too. Take with your LBS about brakes etc... I think there is a version of both the Sport and Crosshairs that offers disc brakes.
So what I'd do is have the custom frame option because you will need a stronger frame but I'd fudge the weight a bit to get it to be where you want it to be in terms of compliance etc... I'd also get their fork because the carbon forks would not work at your size.
Gunnar is conservative and that's good. You just want them to manage it a little better. If you have a good LBS to work with, they can help you with that.
That said, the Gunnar is a nice bike and it rides well. I use it for my adventure bike so it has a rack on the back and often a pannier or two for a day ride with my wife. It's a comfortable geometry for me, very predictable handling. I'm going to switch out the bars for a more compliant set (I have an AL bar on it now) and maybe the same with a seat post. I'll also be thinking pretty hard about changing to a CF fork this summer. All of that will help make up for the heavy build on the frame, lighten it up and make it more comfortable. I'm not worried about the weight of the bike, but adding some more vertical compliance to offset the Gunnar conservative build is good.
J.
But that's just me. Bike's 35.5 with racks, cages and such... Light pack is as low as 15 though can be 50 usually about 20.... 9lbs of water if it's hot. I was up to 350...
The bike I had braking issues was a 2007 Fuji Tourer. And yes with Koolstops, salmon rear, slimline black front., A local Builder was the one who finally diagnosed it. He had me look at the fork while squeezing the handle, forks would bow outward. He suggested brake booster to stiffen the fork. But I had other issues with the Tourer, like tearing the rear wheel free and into the chain stay if I torqued up.
I don't like walking home, especially in the heat, So I built up a custom DT. Only "issue" with this one is that the chain stays flex a bit in some circumstances and the speed/cadence sensor ticks against the magnet. Kind of trivial all things considered.
oh, forgot to mention I think the idea of a fork swap to get you a disc on the front would add the braking power you're looking for.
BB7's work wonders for me!
Quoted: 56 Post(s)
J.
J.
Another great option is Habanero cycles - a standard Ti frame runs $995. Custom is $1595 and they will collaborate with you.
I’ve since added tubeless clinchers to my Gunnar and fit them with 30c Schwalbe G-1 speeds and it rides fast and plush at a weight very close to a 25c tubular.
J.
Black Mountain Cycles. I own one of the new MCD's and it is brilliant.
Mike will build for a Clyde, I have 36H wheels on mine.
MCD / Road+ Frame Geometry - Black Mountain Cycles
Compared to the LHT it is a little less trail, slightly higher bottom bracket, shorter wheelbase and slightly steeper head tube. All that adds up to a good balance of handling vs stability that is about 80% of my road bike. I lose about .75 mph compared to the road bike, 15.2 vrs 16 mph average. I have fat tires on the MCD, 38s vrs 23s on the road bike.
Comfy, well behaved and brackets for everything you might want: up 48x700 tires, racks, fenders, 3 or 4 bottles... it is pretty damn versatile. Comes in at 21.6 lbs as equipped below.
My MCD:
My MCD:
Bikes: 2001 Waterford RST-22, 2002 Gunnar Sport, 1999 Trek 520 gravel grinder
Quoted: 35 Post(s)
Liked 5 Times
I have a Gunnar Sport. It was a joy to ride even when I weighed 295 pounds (I'm now at 235, thanks in part to that bike). Its geometry is a little more forgiving than the Roadie's or the Crosshairs', IMO. I ran 32c and 35c tires on it when I was heavier, and I run 28s on it now.
you will never go wrong with a hand-built steel frame! i guarantee you will go through endless amounts of wheels before that frame will fail. Straight from the Gunnar website"There’s something about a hand-made steel bike. It has soul. It speaks to you. It begs to be ridden. Like a faithful canine pal, your Gunnar will be a friend for life, and it’ll always be ready to go out and play."How could you not
