Best chain lubricant?
Any suggestions on the best chain lubricant out there? Also, any suggestions for really good chain lubricants I can easily find at a hardware store?
Likes For 10 Wheels:
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
A quick search of this forum yields this https://www.bikeforums.net/commuting/...hain-lube.html
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times
Google Chain -L and he will send you a free sample of the Best
Fred "The Real Fred"
anything is better than nothing.. ok WD40 may be not but they added confusion by making a bicycle chain lube.
Go off and experiment.
Too bad you could not find any chain lube topic threads on this site, Ever..
Big search Block at the top of the page, 'Archive' link at the Bottom..
You can catch up on the history, There.
Quoted: 2952 Post(s)
Liked 3,106 Times
I like Pro-Link.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
It's nothing personal; you just happened to touch a nerve with the subject. Chain lube is an oft-beaten dead horse around here.
Between the topic and the fact I originally misread your name as "Nixon Fan", I had you pegged for a troll. ;-)
Liked 1,243 Times
Kinda like asking what is the best bathroom tissue.
When I was 10 y/o we just used Oil. It worked
No hurt feelings! ☺
Totally unrelated; I recently switched over to Canon, so I'm wondering if I should try to switch my name to Canon Fan! 😊
That's the pattern, 50+ pages of various "I like X brand product " statements..
so it gets the 'Dead Horse' Smilie ..
Bike chains are much more exposed to the elements than other mechanisms. The city I live in in Florida is notorious for sand everywhere. The soil here contains lots of sand, sand is always on the roadways and bike paths I ride. Sand seems to stick to my bike chains every time I ride. My guess is that some types of oils are better at repelling sand/dirt than others.
P.S., Having recently gone from septic tank to sewer system, I can say for sure that there are really great toilete papers on the market today. When you have a septic tank you are limited to only a handful of medoicre brands of toilette paper, however, when you are on a sewer system you can use the best brand out there!
Pattern? I don't get paid to endorse anything. Ask me anything you like about photography equipment and guns ( my only two areas of many years of experience), and I can give you an unbiased answer.
Non omnino gravis
What I can remember using, off the top of my head...
White Lightning wax lube
The good
--no chainring tattoos
--pretty quiet... for awhile
--it doesn't care about water
The bad
--I've had the chain go clattery after 30 miles.
--chain gets chunky
--a big ol' bottle doesn't last very long, as it's getting applied as much as twice a day (YMMV)
T9 Boeshield
The good
--it works
--compared to other lubes, it's cheap
--fairly good when wet
--chain stays quiet
The bad
--hope you like applying before every ride, ~50 mile application interval
--think you've seen a dirty chain? THINK AGAIN
--forget trying to clean it, the solvent will run black until you give up
TriFlow
The good
--smells like bananas
--it works
--doesn't get as gross at T9
The bad
--apply before every ride, pretty much, maybe every other-- 70-80 dry miles, tops
--washes off with water, basically
--as the teflon builds up, gets gummy
EcoSheep "Sheep on the road"
The good
--my god is it cheap
--it works
--really quiet-- when fresh on a fresh chain, the quietest I've used, hands down
--~200 miles between applications
--water resistance is "average," but they have a formula designed for wet riding
--chain is easy to clean
The bad
--as it builds up, it gets sticky. Hella sticky.
--the stickiness gets worse over time, until the chain looks like a Wooly Willy.
ProGold Xtreme Chain Lube
The good
--by bike chain lube standards, it's cheap
--it works-- really well.
--above average quiet
--~400 miles between applications
--water resistance very good
--never gets tacky
The bad
--does hold onto grime, though not as bad as T9 or TriFlow
--thin, so it can be a bit splattery
MucOff Team Sky Extreme Hydrodynamic Chain Lube
The good
--it works-- amazingly
--it smells fancy. I'm not even kidding
--~700-800 miles between applications
--water resistance ridiculous level-- I've done 4-5 consecutive rain days without re-applying
--a little goes a long, long way. One tiny drop per link.
--comes with a neat UV light so you can see if there's still lube on the chain. Gadgets are neat
The bad
--dear lord is it expensive. It's the polar opposite of EcoSheep.
--forget trying to clean it off. Wipe the chain down between applications, throw the chain away when stretched.
--it's really expensive.
The good
The bad
--chain gets chunky
T9 Boeshield
The good
--it works
--chain stays quiet
The bad
TriFlow
The good
--it works
The bad
The good
--it works
The bad
The good
--never gets tacky
The bad
The good
The bad
Want to buy my Pentax 35mm cameras and various Lenses ?
I stopped bothering with pictures when My parents died and I had no room in my tiny apartment for all those slides and such, so I got to thinking of the meaningless off all that stuff
in the larger theme of life, as the empire eats its Children.
<insert unsubstantiated claim of superiority, here>
The good
The bad
--chain gets chunky
T9 Boeshield
The good
--it works
--chain stays quiet
The bad
TriFlow
The good
--it works
The bad
The good
--it works
The bad
The good
--never gets tacky
The bad
The good
The bad
The good
The bad
--chain gets chunky
T9 Boeshield
The good
--it works
--chain stays quiet
The bad
TriFlow
The good
--it works
The bad
The good
--it works
The bad
The good
--never gets tacky
The bad
The good
The bad
Quoted: 5888 Post(s)
Liked 3,471 Times
The OP gets bonus points for handling the pushback on this thread with humor.
Fwiw, you can still keep some of their memories alive with those slides. Scanning them and saving them as digital files is tedious work at first but definitely worth it. A few years ago I had a friend who was a fighter pilot during Vietnam in the late 1960's. He loved photography and took a camera with him on many missions. He also took his camera during his "down time" with his buddies. He had a box with close to 400 color slides.
Several decades went by and he had forgotten about the box. One day he and I got to talking about photography and he mentioned his old box of slides. I offered to scan all of them for him so he could at least view them on his computer screen. After a few weeks I completed scanning all his slides. It was like traveling back in time! I was seeing that era from his perspective. He hadn't seen these images since he took them back in 1969! It was beyond awesome! Many images were of him and his buddies being themselves; drinking, cars breaking down, partying, etc.
A few weeks ago my buddy passed away due to heart issues. I am happy that his kids at least got a chance to see a glimpse in the life of their father during the war. Someday his grandchildren will get to see these images as well I hope.
The beauty of pictures is that you are capturing an instant in time.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 704 Times
And I have a Nikon EM that I received as a high school graduation present. Still wondering if it'll be worth something someday.
Jeff Wills
Jeff Wills
