Rule of 105, 28 vs 32.. and the Rapide CLX
#52
Quoted: 4414 Post(s)
Liked 4,867 Times
I think you guys need to watch Alex Howes here talking about all these 25mm tyres he ran at 100psi last year
https://youtu.be/QGii0vh66eE?si=o3Hr47eA2qssmO9p
Obviously took DM’s sage advice.
#53
Originally Posted by FL_Gator;[url=tel:23188482
23188482[/url]]This is awesome, just ordered one, thanks!
30/32 mounted now though, hoping to ride Sunday.
Likes For FL_Gator:
#54
Quoted: 682 Post(s)
Liked 453 Times
#55
Originally Posted by choddo;[url=tel:23191773
23191773[/url]]Did you spray the last area of the rim with mucoff or similar to let the glider slide more easily? Hold the wheel and tyre in your left (if right handed) hand at the end of the unfitted section, with the wheel braced against your body so that portion of the tyre can’t progress round the rim as you chase it :-) and then push the glider with the heel of your right thumb, fingers pulling on a spoke. I do it here (this tyre was easier than a gp5000 so I didn’t need to pull on a spoke) from about 2 minutes. https://youtu.be/oo9FE4CpeLw?si=V0SqeizroAMr9lbm
The video is helpful, I have a couple more tires to do so I might try it with your tips. Thanks!
Likes For FL_Gator:
#56
Quoted: 682 Post(s)
Liked 453 Times
No, I didn’t try that, I was trying to simulate how it would be if I was changing a flat out on the trail. I tried and tried and could get the glider under the edge of the old tire to get it off. Struggled with sliding the new one on without any spray but wouldn’t have spray on the trail.
Likes For choddo:
#57
Results
Ok, got a good test in. Personal feel, they are super super smooth on a typical cracked pavement flat Florida bike trail… and also feel very fast. However to check my confirmation bias I have two nearly identical test runs to compare.
It’s a 12.5 mile flat loop through the woods that is very circular. 2 loops 25 miles total. Same kit, helmet, socks, shoes, bottles, etc.. all identical. Temp within 5deg. Tried to keep similar body position, no drafting. All tires are GP5Ks.
RUN 1, 28mm front and back 74/76 psi:
25 miles
Avg 20.2mph
Avg 232w
RUN 2, 30mm front, 32mm back 70/65psi:
25 miles
Avg 20.9mph
Avg 208w
The only real variable here was wind. Both days had moderate wind, however since it is a circular loop I feel like you get equal benefit and penalty as you go around the loop that should essentially offset. Thoughts?
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
Likes For FL_Gator:
#58
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Wind doesn't work that way. On a loop or out-and-back course, higher winds produce higher penalty.
Likes For terrymorse:
#59
Quoted: 3952 Post(s)
Liked 7,299 Times
It might seem counterintuitive, but even with a perfectly circular course in a constant wind, the wind will hurt you more on the upwind segments than it helps on the downwind, and it will slow you down on more than half the course. (The double whammy is due to the non-linearity of aerodynamic drag.)
#60
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
You never get back from a tailwind what you lose to a headwind.
Likes For genejockey:
#61
Liked 11,912 Times
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
I can tell you that I noticed the difference between the 32mm Corsas and 28mm GP5Ks in a single ride. The fact that you have power numbers, too, helps a lot. I don't. All I have is RPE.
#62
climber has-been
Liked 3,567 Times
#63
All the wind comments make sense, no real way to mitigate that in real world riding comparisons. So I’ll just ride a few more of my normal courses and compare as I go. Definitely didn’t seem to be any slower today at least.
#64
Quoted: 222 Post(s)
Liked 304 Times
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
As already mentioned, wind doesn't cancel going in a circle or an out and back.
The reality is it is very, very difficult to make these types of comparisons in the wild. Especially with single runs at different times under what will always be different conditions to some degree. It takes many runs to be able to make statistically significant comparisons. Though I don't fault you for trying.
I've tried to compare performance at different speeds, in an effort to extract CdA and Crr from data. Even though I did multiple runs with one immediately after another, very flat course, and no obvious wind, it was difficult to to come up with anything that appeared accurate. It's simply a very tough problem. Crr (rolling resistance) itself is pretty easy, it's just that aero drag dominates at all but the slowest speed. And aero drag is always significant. Also, aero losses are super sensitive and complex. Air density has a direct relationship to aero losses and varies day to day and throughout the day. Even humidity is a factor.
In the end, there is enough data and information out there to support that wider tires, in the ranges we are considering, do not hurt significantly under controlled conditions, and likely have a net benefit in the real world with varying surfaces conditions we find on our rides. Then factor in the much improved comfort and wider tires for the win.
I think what might prove more useful over time is ride the wider tires, collect ride data, and then compare that to the, presumably, many rides you did on the narrower tires. A generally faster average speed for similar power may emerge from the data. Or if nothing else, you'll prove it didn't hurt to go wider and gain the comfort.
Complicating this is the effects of rougher roads and selecting tire pressures. The ones you used would be high for me. And I'm not a light person at 190-195 lbs. I'm running close to 60 PSI on 28 mm GP 5000 (measure 30 mm). It's slightly lower than the Silca calculator recommends for poor pavement. But the penalty for running a lower than optimal pressure is very small, while the penalty for running too high a pressure is much higher. I.E., better to optimize for the worst surface condition you spend any significant time on and err on the side of too low rather than too high a pressure.
Nice thing is, we get more comfort at these lower pressures, and unless you hit a lot of potholes, there's just little downside to the wider tires and lower pressures and they may actually be faster.
Likes For Mtracer:
#65
Liked 7,299 Times
The majority of the difference in power you are seeing cannot be from the rolling resistance of the tires. At those speeds, the entire rolling resistance would be on the order of 30 W. So, the difference you would get from tire width would obviously be a fraction of that.
#66
Liked 4,867 Times
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
25 miles
Avg 20.2mph
Avg 232w
25 miles
Avg 20.9mph
Avg 208w
Likes For PeteHski:
#67
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Likes For RChung:
#68
Originally Posted by PeteHski;[url=tel:23193762
23193762[/url]]As others have said, the speed difference will be mostly from wind variation. But the smoother ride is certainly valid and I doubt there would be any speed penalty. You could probably run lower pressures too without any penalty. Now you need to try some 23 mm tyres at 110 psi!
Likes For FL_Gator:
#69
Liked 11,912 Times
Fun thing I just validated.. my 2010 Specialized Roubaix (stock 23mm tires) was able to accept the 28mm tires I just took off of my main bike. Specialized told me a few years ago that only 26mm would fit that old frame but the 28s with some deep section carbon wheels looks and fits great!
