Repairing a tire
Live to ride ride to live
Bikes: Calfee Tetra Pro
Repairing a tire
I have a tire with about a 1/4" cut on the top of tire so it is nowhere near the sidewall. Should I just use a boot or could I use a tube patch and patch the inside of the tire?
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
If it's just tread and the cut doesn't include the casing you can super-glue it closed.
If ANY of the casing is cut it will start to unravel with use and your tire will develop a fatal tumor. Put it down before that happens.
The cut goes all the through so I guess that means the casing is cut. I thought that cuts in a tire were survivable as long as it isn't on the sidewall.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Put a piece of good duct tape over the inside cut and ride it.
Lets us know how it works for you.
Fred "The Real Fred"
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Boot it from the inside and fill the tread with shoe goo.
"When I hear another express an opinion, which is not mine, I say to myself, He has a right to his opinion, as I to mine; why should I question it. His error does me no injury, and shall I become a Don Quixot to bring all men by force of argument, to one opinion? If a fact be misstated, it is probable he is gratified by a belief of it, and I have no right to deprive him of the gratification."
T. Jefferson
T. Jefferson
Mr. Dopolina
Quoted: 149 Post(s)
Liked 117 Times
You can boot and shoo goo but it will unwind at some point. If you ride it give it a quick once over before you head out; Just spin the wheel and look for wobbles in the tire. If you see one it indicates that the casing is coming undone and it's time for the tire to go.
I've never had any luck with a large cut. Smaller ones can be glued or booted. The big ones just keep causing problems or worries and who needs that? Just replace it and enjoy the ride.
Thanks, for all of your responses. I think I will use this tire on my trainer. If it falls apart, at least it won't cause a crash.
Quoted: 3376 Post(s)
Liked 5,522 Times
I have a nasty gash in a Rubino Pro that I booted a couple of yr.s ago. Still going strong. Used some Bell patch material that came in a kit from Wmart. Stuff was as thick as the tire casing.
Experienced
Quoted: 16 Post(s)
Yeah, you can just patch it if the cut is small with a regular patch kit. For a larger cut, you'd want to use car tires patches cut down a bit. I've had to do that for Road Tubeless.
