Wow! I just raised my seat and...
Old 05-19-10, 11:22 PM
wmgreene85
Mission Creep
wmgreene85's Avatar
Bikes: raleigh macaframa, motobecane record
So I noticed something very amazing today. I raised my seat about 2 inches and it became noticeably easier to skid and skip. Maybe raising the seat (within reason, of course) helps in 2 ways: 1) positioning 2) weight distribution
Any similar experiences? What do you guys think?
wmgreene85 is offline
Old 05-19-10, 11:27 PM
cleanupinaisle3
cleanupinaisle3's Avatar
You could just stand up. Seated skids are more difficult. Also, two inches is a big change in saddle to bar drop and leg stroke. Are you sure you're even fitted to the bike correctly?
cleanupinaisle3 is offline
Old 05-19-10, 11:31 PM
wmgreene85
Mission Creep
wmgreene85's Avatar
yes, I know what I am doing on my bicycle. I was posting this from the standpoint of "in-theory" rather than practicality. Obviously I adjusted my seat back to where it had been. I was working on my bike, installed a new seat-post, and forgot to set it before I went for a test ride out in front. thats all..
Old 05-19-10, 11:43 PM
filtersweep
filtersweep's Avatar
Huh? You make no sense. So do you believe you are lighter because you are further from the ground?
If you consider a bike's geo, you actually have more weight over the rear wheel the higher the saddle.
filtersweep is offline
Old 05-19-10, 11:47 PM
WoundedKnee
Antarctica awaits
WoundedKnee's Avatar
Legs have more power when they're extended I think.
WoundedKnee is offline
Old 05-20-10, 12:02 AM
wmgreene85
Mission Creep
wmgreene85's Avatar
If I had the answer, do you think i'd be posting this question?
Im simply sharing an experience, wondering if anyone else here has had a similar experience
Old 05-20-10, 12:51 AM
fuzz2050
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 17 Post(s)
Liked 3 Times in 3 Posts
I'm a little confused here, I'm having trouble imagining a properly fitting bike that can have the seat post raised 2 inches and still be able to reach the pedals. Two inches is an awful lot, especially for saddle height. Optimum saddle height tends to be as high as you can get it without being uncomfortable to ride.
well, having it that high would definitely make it easier to lock up your knee.
fuzz2050 is offline
Old 05-20-10, 01:19 AM
WoundedKnee
Antarctica awaits
Optimum saddle height is supposedly 109% of your inseam from the lowest pedal, with the crank arm aligned with the seat tube.
Old 05-20-10, 09:47 AM
RigHty
Bikes: Nishiki Sport 10 speed
the guy simply had his seat very low. then started trying different seat heights until he found it. i could see him raising 2 inches if it was low. so i dont know why its so hard for some of you to understand...
RigHty is offline
Old 05-20-10, 10:06 AM
lubes17319
Chronic 1st-timer
lubes17319's Avatar
Bikes: ...take me places.
Makes perfect sense.
A bodie's gravitational pull is lessened when objects are more distant, so being 2" further away will make him that much lighter.
lubes17319 is offline
Old 05-20-10, 10:09 AM
cg1985
Goon
Bikes: Rocky Mountain RC30, Soma Sport Fixed
I rotated my seat back a little bit per suggestion in my soma before/after thread and it seems more comfy, which is hard to imagine because it was awesomely comfy before. Little moves!
I rotated maybe 20 degrees.
cg1985 is offline
Old 05-20-10, 10:11 AM
seedubs1
lulz at thread.
If I raised my seat 2", I wouldn't be able to touch the pedals.
seedubs1 is offline
Old 05-20-10, 10:30 AM
kringle
I step on puppies
kringle's Avatar
so we're all in agreement, his original fit wasn't correct, but he doesn't want to admit it.
kringle is offline
Old 05-20-10, 11:14 AM
bryguy27007
bryguy27007's Avatar
bryguy27007 is offline
Old 05-20-10, 11:50 AM
seedubs1
This.
seedubs1 is offline
Old 05-20-10, 12:06 PM
cleanupinaisle3
SO much lighter.
Old 05-20-10, 04:11 PM
wmgreene85
Mission Creep
wmgreene85's Avatar
I think you guys are right, my seat was initially too low. it feels much more natural now. thnks
Old 05-21-10, 10:15 AM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 55 Times in 38 Posts
...every thread's a pissing contest.
lostarchitect is offline
Old 05-21-10, 10:54 AM
Moozh
+1...gets fuc***g tedious sometimes doesnt it!
Moozh is offline
Old 05-21-10, 11:01 AM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times in 432 Posts
This thread has run it's course. Closing.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
sabado225
Road Cycling
10
05-30-18 02:56 PM
Boricua Kid
Mountain Biking
1
07-08-16 11:28 PM
kenshireen
Road Cycling
7
08-31-13 06:07 AM
subzeroLV
General Cycling Discussion
7
08-23-10 04:07 PM
ZippyDan
26
06-18-10 01:23 AM
