Tarmac S-Works SL3 vs Roubaix S-Works SL3 vs Trek Madone 6.9SSL
Hi guys,
I've ever mentioned that I was interested in getting Tarmac S-Works SL3 bike but after reading and researching it seems that the Roubaix is smoother than the Tarmac? Is this right? The Roubaix - apparently - is not as stiff as the Tarmac (that's what they said).
What I'm looking for is a very smooth bike that will absorb as much sting as possible from pothole/uneven/hard surface. I live in Perth, WA south of the river and the path to city (where I work) is a bit bumpy. I'm currently riding Giant TCR Advanced 1 and it's vibrating a lot although it's carbon frame.
What's your take on those 3 bikes? People also say that Trek Madone 6.9SSL is the best of both worlds because it's smoother than Tarmac but stiffer than Roubaix.
Please do not answer with "You have to test them yourself to know what's best for you" because I don't have the luxury to test those bikes. The LBS around my suburb just don't have the bike in the shop unfortunately.
Thanks guys,
Steve
Thanks guys,
Steve
While the S-Works Roubaix is a bit more compliant than the SW Tarmac do not think that it is comfort bike. The S-Works version of the Roubaix is built with a very stiff and light carbon layup. I have owned both bikes and yes the Roubaix is more comfortable but I feel that it is more due to the taller front end and longer wheelbase than anything else. I have found that my tubeless road tires at 90psi have made a much bigger difference in ride quality than simply swapping frames ever did.
The S-W Roubaix is stiff enough for Boonen so I have to assume it is stiff enough for you and me and while I have not ridden the lower end Roubaix's all that much I do know the ride gets more compliant as you go down in the model line up but I have no way of quantitating that......
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
SkinnyStrong
Specialized till I die. And I'd go with the Roubaix because that's what Spartacus used to solo all the way to victory in the toughest of the spring classics, which also happens to share the same name as the bike you should buy...
MyBikeRunsonNukePower
Bikes: 2013 Specialized Roubaix Expert / 2009 Specialized Allez Elite
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
Get the Roubaix SL3 and don't look back if it's smoothness you're really after, especially if you're not willing to find a way to test ride them.
Boom.
Quoted: 16 Post(s)
I might be wrong here, but I'm pretty sure the Roubaix's that Boonen and Cancellara used had completely different geometries than the one that's available to the public.
Bikes: 2010 Trek Madone 5.5 CAAD9
Any of those bikes will be fine. In fact, the bike he has will be fine, he can add carbon bars and stem if he wants to absorb more bumps, he can lower the tire pressure if he wants a softer ride. All that talk about certain bikes being uncomfortable is bs, if a bike fits properly it will be comfortable. I like a super stiff bike, I've ridden carbon and aluminum frames all day long on some shoddy Pennsylvania roads, both are comfortable for me cause they fit correctly. I have a Madone and a CAAD9, they are both stiff and comfortable.
I said get the Madone cause it's what I did. All of those bikes are fine.
I'm pretty sure you're right -- they ride specials with a "team" geometry, which I think means it's got a shorter head tube than the standard issue Roubaix.
With the exception of Boonens one off frame a couple of years ago I am pretty sure the race frames are off the shelf models. The cost to make a mold for a monocoque frame is so expensive I do not think that rider specific frames are much done anymore but I could be wrong.... Wouldn't be the first time.
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Bikesman
Bikes: Giant Seek 1 IGH; Specialized Roubaix On Order
Roubaix - not the s-works one. The expert is aces and the parts are cheap to replace. I am on my sixth chain on my Roubaix and very pleased.
I am a tad older, a tad heavier and a tad more arthritic than I would like and the Roubaix has been a life saver.
Like others have said, tyre pressure makes a huge difference to ride. Sure you haven't got them up at 130psi and you're only 65kg or something?. I ride the southern Perth PSP all the time and 99% of it is pretty smooth. Bumpy would be the Holmes Road descent from Maida Vale towards Forrestfield.
I can't speak to the s-works frames, but I've got a Tarmac (comp) and Roubaix (expert). Main difference from my standpoint is the handling. Tarmac wants to turn, Roubaix likes to track straight. If you ride/race a lot of technical areas, you might appreciate the Tarmac. Both are plenty comfortable with an edge to the Roubaix on chip seal and soaking up potholes, etc., I don't find the Tarmac harsh at all (but mine is not the s-works frame). I ride my roubaix 80+ percent of the time because I prefer the handling and the ride is marginally better.
I have the ride position set up identically on both, so the geometry is really just affecting the handling, not my power output or postion. One thing to look out on with the Roubaix is the huge head tube. You cant' get too much saddle to bar drop. I don't like a very agressive position and I still don't run any spacers and my stem is set for maximum drop. If you like a lot of drop, the Roubaix is probalby not a great choice. I almost went down a frame size when I bought my Roubaix, but it worked out to be a great fit.
Quoted: 2952 Post(s)
Liked 3,106 Times
Short hand: Tarmac = crit bike; Roubaix = century bike
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
I like reading things like this because the more I'm told the roubaix is a century bike, the more I'm determined to race mine and do well. 99% of us don't steer either bike close enough to it's limits to notice the difference in the extra 1cm (or however much) of wheelbase. >.<
Liked 3,106 Times
To the OP, I'm surprised you find the Giant TCR Advanced uncomfortable.
I have an 07 and I've always thought it was the 2nd smoothest bike I'd ever ridden (the first being my 07 S-Works Roubaix).
Until I bought my 09 TCR Advanced SL1 - that bike is butter.
If you're planning on racing I'd go with the Tarmac.
Spirited group rides, centuries, long days in the saddle, I'd go with the Roubaix. I haven't ridden the revamped Roubaix, but a friend was at Specialized dealer's convention this past summer, rode a lot of bikes (even rode with Mike Sinyard) and confirmed the '10 S-Works Roubaix is pretty sweet!
BarryJo,
Thanks very much for your reply. I have tried Amira Elite (Ultegra) few weeks ago and that was a lot smoother than my TCR especially on rough roads. That bike - although it came with exact same group as my TCR Advanced - was $2K more expensive than my TCR so I'm assuming if I get the highend bikes (which costs a lot more), I will get even a lot more smoothness out of them or am I wrong?
I'm not doing road racing but riding centuries is what I'm interested in doing. I'm a beginner by the way and the longest I've ever ridden was 73km on ~28kmh speed which was not too bad but yeah....why I asked the question was because of my experience riding the Amira. That - seriously - felt so different. That bike was a lot smoother than mine.
FYI I'm using Continental GP4000s tyres and Selle SMP Extra saddle which is a lot more comfortable than the OOTB Fizik ARione. But even with these I'm still not too happy with my TCR. In terms of the riding position I'm fairly happy with the TCR. I actually prefer a higher riding position. I feel that I can ride quicker with that. I'm assuming if I get Madone/Tarmac I can always do the same? I know the Roubaix has already had a higher riding position.
So all in all....out of those 3 bikes I'm interested in...which one would suit me best? Grrr..if only the shops here have those bikes to test.
Cheers,
Steve
Cheers,
Steve
Honestly, if I were in your shoes (and I wish I was because I'd love the opportunity to chose between the Tarmac and Roubaix), knowing what I know from my bike shop buddy, I'd go with the Roubaix SL3.
It's going to be a lot more comfortable for the kind of riding you plan on doing.
And it's plenty fast.
Good luch with whatever bike you end up choosing
Is it time now for me to post a pic of my Roubaix and say how much I love it?
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
