Cone wrench set - good and cheap?
Old 01-23-21, 04:54 PM
KC8QVO
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 290 Post(s)
Liked 58 Times in 50 Posts
I'm looking for a cone wrench set that covers between 13-17mm at least. I'll probably get 2 so I have 2 of each size.
Any ideas on the double ended ones vs. the single ended ones? I could see where having 1 set would be problematic if you needed one size of each that is on the same wrench, but with 2 sets that would give me 2 of each size regardless of what wrench the size is on.
KC8QVO is offline
Old 01-23-21, 05:20 PM
veganbikes
Clark W. Griswold
Quoted: 2028 Post(s)
Liked 940 Times in 659 Posts
My current set is Kingsbridge and Sugino both of which are of quality but vintage and no longer produced. A double ended one is not a bad idea at all I am fine with mine being double ended saves space and weight in my toolbox. The Park DCW-1 - 3 would be a good solid set of cone wrenches I probably wouldn't look cheaper than that but if I wanted alternatives, Hozan and Pedro's make some solid tools or even the Campagnolo set would get you close (though I don't know that they do a 17)
Like with any tool buy the absolute best you can unless using as a disposable tool set or one that is used in very very very very very rare circumstances that are not essential. Life is too short for crap tools.
veganbikes is online now
Old 01-23-21, 05:42 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1251 Post(s)
Liked 439 Times in 343 Posts
You only need one 17mm cone wrench assuming you have another 17mm box or open end wrench. Those nuts are on the "outside", so the wrench doesn't need to be thin.
I started off with the PARK double ended wrench, but they'll spread if you have an exceptionally tight nut to break loose.
Else, I have pairs of PARK blue handled wrenches from 13-16mm. They are plenty good for a home mechanic. That's what I see the front room mechanics/salesman at my LBS use. Not sure about the mechanic in the "back" room.
Anther option is 1 set of singles w/ double enders to compliment.
You can always take 2 17mm's to get things to unscrew. It just might not be the side you prefer that loosens.
Bill Kapaun is offline
Old 01-23-21, 05:59 PM
KC8QVO
Quoted: 290 Post(s)
Like these?
https://www.ebay.com/itm/Park-Tool-D...kAAOSwz3JeogX4
I have a bunch of other tools. My regular wrenches are all Craftsmen, between 10-20+ years old, not the new crap. The cone wrenches I'm after are specifically the thin ones for bike duty. I did make some last Fall (13mm and 15mm, 2x each) but I want a proper set.
As for the tight nut/cone scenario - I can see where that would stress a wrench.
The blue handle park wrench sets look to be in the mid $70 range. Thats a ton more than I wanted to spend. Though, I am curious - what purpose do the larger sizes have on bike repairs that normal wrenches wouldn't be able to be used for? I am not aware of any parts on any of my bikes that would use, say, a thin 22mm wrench?
KC8QVO is offline
Old 01-23-21, 06:40 PM
HillRider
Quoted: 1595 Post(s)
Liked 427 Times in 332 Posts
Good and cheap almost never go together when it comes to tools. Yes, the Park blue handled single size wrenches are a bit more than you had in mind but well worth it. They are strong and comfortable. I have a pair of Campy double ended cone wrenches (13x14 and 15x16) and, while they are beautifully made of very hard steel, they are also very uncomfortable to use.
Basically the commonly needed sizes are 13, 14, 15, and 17mm with the 17mm being optional on most hubs since, as Bill noted, lock nuts are usually on the outsize so a standard 17mm box or open end will fit. You don't have to buy the entire set at once, just buy the sizes for your particular hubs as needed. Yes, the set is cheaper per wrench but you will wind up with a few you never use.
That said, I have hubs that need two 14mm cone wrenches, one using a 16mm and I have a new set of Shimano GRX thru axle disc wheels that use a 22mm cone wrench for the rear wheel and a pair of 17mm cone wrenches for the front wheel. I added wrenches individually on an as-needed basis.
HillRider is online now
Likes For HillRider:
Old 01-23-21, 06:42 PM
grizzly59
Quoted: 184 Post(s)
Liked 113 Times in 82 Posts
I have used 2 Hozan C-503 wrenches forever. Each wrench does 13&14, 15&16, two wrenches will do anything I've ever seen, never needed a 17mm cone wrench. I have an ATD and a Campy, the Hozan's are as good quality as the Campy. I've never had any issue with the Hozan's spreading with really tight nuts. I use any decent mechanics wrench for the outer nuts. The Hozan's are old enough I've forgot when I got them, they are made in Japan.
https://www.ebay.com/itm/HOZAN-C-503...0AAOSwvApaBI1J
grizzly59 is offline
Old 01-23-21, 09:53 PM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 395 Post(s)
Liked 141 Times in 109 Posts
If you're going to be working on traditional cup and cone hubs, two 13/15 mm double ended wrenches, the Park DCW-4 or equal, will cover most of what you'll see.
andrewclaus is offline
Old 01-23-21, 11:14 PM
SurferRosa
Señor Member
SurferRosa's Avatar
Quoted: 1570 Post(s)
Liked 1,546 Times in 883 Posts
I use the inexpensive double-ended Park wrenches. Two of each of 13/14 and 15/16mm. I add to that an adjustable wrench and socket set. Covers all vintage hubs. Sometimes I wrap a rag around the Park cone wrench for a more comfortable handle to tackle stuck cones and locknuts.
SurferRosa is offline
Old 01-24-21, 03:16 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 148 Post(s)
Liked 70 Times in 51 Posts
We started with the double ended ones but found the single park tool ones had better leverage. We actually bought quite a few used on ebay so there are multiple sets in the shop and our mobile setup.
Try this link https://www.ebay.com/sch/i.html?_nkw=park+tool+used
Edited to add
Actually there are two used sets up on ebay right now, not a bad price
https://www.ebay.com/itm/Lot-of-6-Us...4AAOSwk1ZgDIsL
and
https://www.ebay.com/itm/Lot-of-7-Us...AAAOSwFa9gDIh8
Good luck
JoeTBM is offline
Old 01-24-21, 05:56 AM
bwilli88
bwilli88's Avatar
Quoted: 643 Post(s)
Liked 297 Times in 199 Posts
I have 3 or 4 sets of Park DCW cone wrenches.
1 set in my tool box here in Cambodia, one set in my tool box in the US and 2 or 3 sets spread thru my touring bike, Mt bike, and my Gravel/Allroad bikes and on a bike in the States.
bwilli88 is offline
Old 01-24-21, 07:14 AM
easyupbug
Quoted: 254 Post(s)
Liked 108 Times in 86 Posts
My singles collect dust, mostly because I deal with enough bikes and I am old so I can't remember cone and nut sizes and I ofter guess wrong on the smaller than 17mm size so it saves time. I try to always wear mechanics glove or at least nitrile so they are not too uncomfortable.
easyupbug is offline
Old 01-25-21, 08:43 AM
pdlamb
Quoted: 1439 Post(s)
Liked 561 Times in 374 Posts
All my bikes take 15 and 17 mm cone wrenches. The Park SCW series is a whole lot easier on my hands than the double-ended, so I've gravitated to those. FWIW, I only need one 15 and one 17, although two 17s is a worthwhile luxury for me. YMMV.
pdlamb is offline
Old 01-25-21, 08:52 AM
davidad
Quoted: 489 Post(s)
Liked 100 Times in 88 Posts
Pretty much ditto.
davidad is offline
Old 01-26-21, 06:27 AM
Geepig
Geepig's Avatar
Bikes: Romet Jubilat x 5
Quoted: 111 Post(s)
Liked 94 Times in 75 Posts
I have one Btwin tool I bought at Decathlon that fits 4 sizes of cone, 13 to 17 mm I think.
It seems to work, and I have serviced a lot of wheels with it. It also keeps the number of tools lying around on my bench or in my toolbox down.
Geepig is offline
Old 01-26-21, 12:39 PM
rydabent
Quoted: 2191 Post(s)
Liked 552 Times in 331 Posts
Why not get a good double ended set, that way you can cover most of the common sizes you come up against.
rydabent is offline
Old 01-26-21, 01:01 PM
HillRider
Why not? Comfort. Double ends are hard on the hands. See above.
Old 01-26-21, 01:59 PM
70sSanO
70sSanO's Avatar
Quoted: 748 Post(s)
Liked 511 Times in 347 Posts
I would agree for most, but not all outside locknuts; as I discovered and needed a second cone wrench.
John
70sSanO is offline
Old 01-26-21, 03:16 PM
alcjphil
alcjphil's Avatar
Quoted: 1060 Post(s)
Liked 425 Times in 290 Posts
I would agree with you if I were working in a shop and had to service hubs several times a day. However, at home I can put up with discomfort a time or two per year. IN 35+ years of working on various bikes I have acquired a number of cone wrenches, some of them very cheaply. I still have the cheapest ones I bought and I still use them because they have offsets which are useful in close quarters. These wrenches have stood up to over 30 years of my personal use, but they probably wouldn't have lasted as long if used everyday in a professional setting
alcjphil is offline
Old 01-26-21, 10:43 PM
dscheidt
Quoted: 23 Post(s)
Liked 8 Times in 7 Posts
I like nice tools as much as the next guy, but the OP is asking about affordable options. I don't think he's working in a shop, so he's going to be using a cone wrench for a minute at a time, a few times a year. Not a big deal to use a uncomfortable one for that purpose, and easy enough to put on gloves, or just wrap a rag around the wrench.
I've also taken a cheap open ended wrench and ground it thin enough to fit.
dscheidt is offline
Old 01-27-21, 02:37 AM
Ambroseambrose
Overall I think these cone wrenches are a great value, they are very accurate when used with higher quality components and I have yet to have slipping issues when used correctly.
Ambroseambrose is offline
Old 01-29-21, 03:30 PM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 148 Post(s)
There are still plenty of used sets and individual Park Tool cone wrenches on eBay, try this link for what is currently available, this gives you the value of a quality tool at an affordable price
Park Tool used cone wrench
JoeTBM is offline
Old 01-29-21, 03:45 PM
James1964
Liked 4 Times in 1 Post
I have a pair of VAR chromed vanadium double-ended cone wrenches that I bought in France 38 years ago. Great quality and durability.
James1964 is offline
Old 01-29-21, 03:48 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 239 Times in 191 Posts
I've had my cheap cone wrenches for 40+ years now. I'm only using them on my own bikes and they've been all I need. They are the generic double ended flat type with two fittings on each end. don't know the sizes. If I've used them 30 times in those 40 years that would be a lot. My main wheels the last 10 years or so have been sealed bearings anyway, but I have other bikes too.
zacster is offline
Old 01-29-21, 11:36 PM
cjenrick
Quoted: 64 Post(s)
Liked 52 Times in 37 Posts
was working on the bike at night, as usual,
needed a cone wrench, bike shops closed,
went to garage and found a nice chrome box end combo wrench ,
then the Nakita grinder started making sparks and i had a new custom cone wrench, nice and thick, as it was "machined" to fit snugly between the nut and washer,
dip it in water a bunch of times to keep it hardened like the blacksmith in Gunsmoke who used to be Burt Renyolds.
cjenrick is offline
Likes For cjenrick:
