Is it bad to change tyres too often?
Bikes: Voodoo Limba, Carrera Vulcan, Revolution Trailfinder
Quoted: 27 Post(s)
Liked 17 Times
Backstory: I've got 2 sets of tyres for my MTB, a fairly knobbly set for offroad and one that's got a better centre profile for on-road (because 90% of my MTB time is cycling on smooth ground to get to the rough stuff). I've only got 1 set of wheels.
Will I do any damage to my tyres if I swap them whenever I want to go back to the knobbly ones for a pure offroad trip?
WALSTIB
Maybe if their a real tight fitting tire to get on rim might be rough on the bead eventually with multiple changes. But I'd say with most tires you could change many times without damaging.
The tires should be fine, but the other thing to be careful about is damaging the inner tubes or valves as you swap tires. Don't use metal tire tools, make sure the tube isn't getting trapped under the tire, etc.
I'm assuming you are not using tubeless tires! That would eliminate the tube issue but have other issues.
Quoted: 27 Post(s)
Liked 17 Times
Thanks! I'm sticking with tubes for now, tubeless sounds good but with my low usage I'm wary about them unseating and/or having to deal with the mess.
If you do it often enough you may look into a second wheelset, or N+1. If you need so different tire thread, you likely need 2 different bike types. and N+1 always is the answer.
I guess over time the tire can get damaged, and there is a chance for pinch flats when you install the tube.
how oftHn are we talking about? Daily, weekly, monthly?
Quoted: 27 Post(s)
Liked 17 Times
I'd probably change the tyre over and back every other month or so at best. Most of my riding is from home which means there's miles of road before I get to any mud.
N+1 is always tempting, since I could have a hard tail for the mostly road stuff and a full suspension for the mostly rough stuff, but I'm trying to be good
I may look at picking up another wheelset at some point though, which would be the best compromise.
Yeah, definitely a new set of wheels which always comes in handy. I'd hate to have to change tires and tubes each time you needed to switch for terrain.
A second set of wheels is an excellent idea. Then the stage is set for concern about damaging the axles and brake alignment through changing the wheel sets too often, thus justifying N+1 on the grounds of safety.
Likes For Pratt:
Cyclochondriac
Airplanes, bikes, beer.
Bikes: Canyon Endurace CF SL 8.0 current favorite, newest bike.
Quoted: 230 Post(s)
Liked 465 Times
If you’re changing tires (or tyres) so frequently that it prevents you from actually riding the bike (or byke) then yes, that’s bad, and too often. HTFU, and have a nice ride.
Bikes: Schwinn Varsity
Quoted: 1717 Post(s)
Liked 437 Times
You will get tired (pun intended.. LOL) soon with changing tires.... and then you will soon get tired (LOL) of changing wheelsets and readjusting the gears and brakes.... and you will end up buying another bike.
Based on my experience, tubes are easily damaged if changing tires too much... Best to just get a second wheelset, even if used to get the tires on them, and maybe en extra cassette so you don't have to worry about damaging anything
