wtb: 26.6 seatpost
Quoted: 1419 Post(s)
Liked 251 Times
wtb: 26.6 seatpost
~300m with setback, vintage preferred. Campy would be cool but not necessary. I'm more concerned with function, so I'd prefer the clamp to use allen bolts and not hex like on old Campy posts.
FOUND for now
FOUND for now
2019 Salsa Warbird
2019 Salsa Warbird
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1966 Schwinn Deluxe Racer, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules
Quoted: 1390 Post(s)
Liked 690 Times
I'm sorry to say that I've had this very problem, and 'vintage' (1995 and earlier) 26.6mm seatposts seem to max out under 300mm in usable extension. I have a saved search for 26.6 suntour XC posts, which give around 250mm of useful post. Road posts will rarely be longer than 180mm total. I suspect longer posts didn't come about until after wide use of sloping top tubes in frames. I hope you can find what you're looking for, though!
Liked 251 Times
These are the ones I'm looking at. Good price and over 200mm: https://www.ebay.com/itm/NOS-Vintage...IAAOSwGllaYkgd
2019 Salsa Warbird
2019 Salsa Warbird
As already mentioned, not likely you'll find anything that long in a vintage post. I'm looking for one too but in a shorter road bike version.
Here's a Kalloy Uno on ebay. Picture shows a short post but the description is for 350mm. Check with the seller.
https://www.ebay.com/itm/Kalloy-Uno-...53.m1438.l2649
Liked 251 Times
2019 Salsa Warbird
2019 Salsa Warbird
Confirmed my frame takes a 26.8. Have additional info on ISO and For Trade sticky.
Likes For IsleRide:
small ring
Quoted: 252 Post(s)
Liked 244 Times
The dropped
Liked 690 Times
Just finishing up a Trek TX300 (actually a '79 310 but there really is no such thing) which is supposed to take a 26.8 but with the single butted Ishiwata Hi-ten the ID is 26.9 so that's too tight. Have a nice Campy NR 26.2 in there but that's too small. It's shimmed for now but want to get a 26.6.
This is all assuming it's not just a pinched clamp area from previous use of an undersized post.
If you asked this question in the mechanics forum, they'd likely advise you to use the 26.8, or ask a shop to ream the seat tube. From what I remember, the heat needed to braze the seat cluster frequently distorts the seat tube, and a reaming to restore it to the correct dimensions isn't an uncommon task.
Probably from pinched clamp area as the bike came from the PO clamped down on the Campy 26.2. (I added a piece of handlebar shim) The bike is over 40 years old. Who knows what it was originally equipped with. I'm guessing 26.6 as usually there is more than .1 mm difference. This was a custom bike with butted Hi-ten. Not on Trek's build sheet in 1979.
Could be reamed as well. Good idea though, and may ask in the mechanics forum.
Liked 251 Times
2019 Salsa Warbird
2019 Salsa Warbird
Likes For IsleRide:
