1994 Stumpy M2 FS Headset Bearings?
Old 01-26-21, 12:05 PM
MarkusT
MarkusT's Avatar
Bikes: 99 GT XCR 3000, 01 Titus Racer X, 80's PUCH Meteor MTB, 14' Crosstrail Elite, 92&93 Bridgestone OX-3, Marin Point Reyes (polished), 80's Mongoose Hilltopper, Giant Cypress SX, 92 Bridgestone X0-1, 96 Giant ATX 890
Quoted: 22 Post(s)
Liked 8 Times in 7 Posts
Hi All!
I picked up this bike with a bum front Future Shock. Taking it off I see the headset has sealed tapered bearings top and bottom. Can I use any threadless shock up front or will the headset bearings need replacing? I have a RockShox Silver 30 I was thinking of using.
Thanks for any feedback!
Mark
File Type: jpg
MarkusT is offline
Old 01-26-21, 01:38 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2711 Post(s)
Liked 891 Times in 647 Posts
One would think that any other fork that has the same steerer specs will interchange within that headset. No mention of this headset's condition?
Before you invest too much $ in this frame do a very thorough look over. There's a reason why M2 tubing material is no longer in use. Cracks at or near the welds is the first concern. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 01-27-21, 05:57 AM
MarkusT
MarkusT's Avatar
Quoted: 22 Post(s)
Thanks Andy. It’s an Aheadset headset. I’ve looked over the bike and no signs of crack, so that’s a plus. Appreciate the info on the possible M2 issue!
Mark
MarkusT is offline
Old 01-27-21, 08:13 AM
70sSanO
70sSanO's Avatar
Quoted: 748 Post(s)
Liked 511 Times in 347 Posts
If the crown race fits and the bearings are smooth I don’t see an issue. I would guess that if you wanted to, you could replace just the sealed bearing cartridges.
I’m not up to speed on differences between headset mfg’s cartridge bearings, (i.e Aheadset vs Cane Creek), but I can’t imagine component mfgs make their own cartridges. There may well be a standard OD/ID and race angles.
John
70sSanO is offline
Old 01-28-21, 06:34 AM
MarkusT
MarkusT's Avatar
Quoted: 22 Post(s)
John
Thanks John, seems they should be fine with a newer fork (RockShox 30 Silver). I'll just move the crown over to the new shock.
MarkusT is offline
