First time gluing up tubular. Need a little advice
Quoted: 378 Post(s)
Liked 1,409 Times
Removable cores are, like, essential and smart, like. I buy tubes with them now, too.
I have had one flat in my life on tubulars (at the valve), but now I put 2 oz of sealant in them, too.
I rode 60 miles on my tubeless tires on Sunday, shakedown ride.
The anxiety lasted 20 miles, then I was just too busy being cold and climbing and trying to keep up.
They ride nice, once you get over expecting them to blow up and spew sealant all over the place.
Quoted: 1948 Post(s)
Liked 2,010 Times
I think I got 3 Rally's in size 25 for 68 dollars delivered from some British Isle. AND they have removable valve cores. I did 75mi/7k ft on the Ironman Sunday and they felt pretty good. I did 25/2.5 today on The Turbo with same wheels and thought they were fine.
RVC I took one out to be sure.
Quoted: 2432 Post(s)
Liked 638 Times
I only have two bikes with tubulars, both are C&V. I won't use tubulars now because there aren't any light rims. I raced on GEL280s and GL330s, not even carbon tubular rims are that light anymore; that include carbon tubulars for disc brakes. If there were some light (and I mean less that 400 grams, pref closer to 350g) I'd ride tubies on a regular basis. But with a number of clincher rims that are lighter than a lot of current tubular rims I'm not for the extra work. If I never have to pull the base tape, cut stitching, patch a tube, re-sew, re-tape the base tape and re-glue/tape it'll be too soon.
https://bicyclewheelwarehouse.com/Components/Rims/700c-rims/Pure-Tubular-23x22mm-380g.html
Liked 638 Times
And for those who don't know, a chain tool will remove the core, I use the one on my Crank Bros multi tool. I believe an 11mm spoke wrench works as well.
Likes For Lazyass:
Quoted: 1104 Post(s)
Liked 1,824 Times
I have a set of wheels from BWW and their house brand Pure tubular rim (6700 hubs/DT Comp's). The rims weigh 380g and cost $40. Light enough for me. They sell a 1370g wheelset with their house brand hubs. I mean how light do you really need them. I have zero issues with the rims, they're very nice and not flexy at all.
https://bicyclewheelwarehouse.com/Co...22mm-380g.html
Liked 638 Times
If they truly weigh out at 380 grams that's a start. As I said, my rough duty wheels were 330s and my climbing wheels were 280s. The whole "these wheels weigh xxx" doesn't tell the whole story. I'll take a pair of wheels that weigh more overall because the hubs are heavy but have a lighter rim/tire combo over a set of wheels that weigh less but have more rim/tire weight. It makes a difference on climbs and accelerations. Are these 380g rims as light as an aluminum rim come? I guess what I'm saying is, for all of the technology that's been infused into bikes during the last 3 to 4 decades it's kinda tough for me to believe that it can't be done when it was done before. I raced and trained on tubulars decades ago when someone else was paying for and mounting them. I appreciate the link, I'll look into these and find out what they weight weenie out to be. If somebody is making something lighter than this I could be a player.
I know light hubs and spokes help make a light wheel, but I doubt a sub-1400g wheelset is going to have heavy rims.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
It's already said but may bear repeating..Tape!
Ben
Ben
Likes For xiaoman1:
Liked 638 Times
I don't think I'll ever use tape because I've read from people who had problems removing the tire and I wouldn't want to deal with that on the road. I use less glue than most people and still have to use a tire lever to pry up the first section. I only use two coats on the rim and one on the basetape which is more than good enough. A Pro Tour team was selling used tires, and you could see by looking at the base tape that the mechanic only put one spot of glue between each spoke, it wasn't even spread over the entire rim or basetape. I enjoy the process of gluing anyway and I don't mind the mess it makes. Disc brake cleaner actually removes the glue right off the rim and side of the tire.
Likes For Lazyass:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Liked 638 Times
I also learned there is no need to let it all dry for 12-24 hours before mounting the tire as many recommend. I mount them as soon as I'm done gluing. Then I take it for a slow ride down the street to check for lumps. If there is a lump it's easy to stretch it out because the glue isn't dry yet. Then I let it sit overnight and ride the next day.
One of these days I may get around to trying tape. Glue is pretty easy, not sure why so many have such hatred for it?
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Well box section rims are going to be lighter. I don't know of anyone making modern box section tubulars. The Pure rims are 23mm deep and IMO 380g is pretty good. I didn't personally weigh the rim, they could be lying I guess but I doubt it. HED makes the Belgium at 24mm deep but those rims are heavy. I don't even know of any others out today.
Quoted: 378 Post(s)
Liked 1,409 Times
NOS box section rims are all over ebay. Ambrosio may still be in production, if you look around you can find fairly recent (last 5 years) NOS Ambrosio F20 and Nemesis. And just keep looking, there are lots more tubular rims sitting in storage than will ever be used. My personal stash has been cut back and not giving more away, still have more than will likely ever be built up.
I picked up a set of DA7800 hubs laced to NOS boxed Ambrosio Montreal's that are silky light, right here on BF. They took some work but are nice nice.
I'm picking up an NOS set of Ultegra 6600 hubs laced to NOS Mavic Reflex hard-anodized box tubulars. NOS and cheap, two words I can deal with.
I have a set of AVA 36-hole box rims I've been saving, they look new, weigh nothing, and will make a great climbing set one of these days.
I laced a set of NOS Performance M21 polished tubular box 36-hole rims to NOS GPX hubs, but am seriously considering swapping them over to some Record 8sp hubs.
Now that 63rickert mentioned it, I seem to have a lot of very light tubular box section rims, in very good shape, sitting around.
I've about had it with the limited life of Velocity Aeroheads, and moving "up" to a lighter, older NOS box-section tubular rim on those sets sounds satisfactory.
Liked 2,568 Times
Y'know, every year I wonder if I'll be tempted into tubulars by a pair of inexpensive NOS rims at the Brazen Dropouts swap meet...
Quoted: 378 Post(s)
Liked 1,409 Times
I can vouch for the feeling when you first heft your newly laced, very light, older box section tubulars, laced to the best hubs you can find for them. Magic. You can't wait to carefully TAPE on a set of tires and go climbing.
Likes For RobbieTunes:
Liked 638 Times
Last winter on ebay I scored a wheelset with GP4 rims and Suzue sealed bearing hubs for $120. The owner built them up in the 80's for a spare and never used them, they were NOS. I got lucky because he had them listed in the wrong section so no one else looking for wheels probably saw them.
Likes For Lazyass:
Quoted: 378 Post(s)
Liked 1,409 Times
It's MY mountain
Liked 2,980 Times
That's where I learned my gluing technique, went through a half-dozen tires or so, but I cracked that criterium bike and my next bike had a freehub so I never used them after that.
After a long time of not having sew-ups I bought a set off eBay that fit my 130mm dropout and had a Shimano freehub and I learned to love them all over again. Tubular wheels are on my vintage steel bike all the time now and get used a lot. Makes for a good conversation starter too.
Quoted: 2338 Post(s)
Liked 2,822 Times
bit OT but just saw a guy on clearly high end carbon bike with his spare tubie proudly strapped under his seat...... to bad he did not do a proper DiabloScott tubie fold, but points any way
Quoted: 1607 Post(s)
Liked 2,216 Times
I fouid a couple of sets of GL330 a few years ago and paid lvery little for them. They were intended to be back ups for the Colnago. Now they will be utilized for the Pinarello.
It's MY mountain
Liked 2,980 Times
I usually go for longer and thinner, but this is a nice example of the compact look, perfectly executed.
Liked 638 Times
I just bought a Wabi Special single speed bike with a Reynolds 725 lugged frame and I want to build a set of tubulars for it with Phil Wood hubs.
