Trouble with 105 shifting
I have a drop bar bike with Shimano 105 ST-RS505 shifters. In the last year it has gotten progressively worse shifting. here is the problem. I can adjust (turn the adjuster at rear derailleur) to shift into the largest cog 32 tooth (11-32) on rear. but when I do the other gears are slow shifting getting worse the smaller the gear. ie I shift up and pedal a rotation or so then it shifts. Or I can adjust it so it shifts smoothly into all of the other gears but wont shift into largest cog 32 tooth. I am on the largest cog on the crank (50/34) I realize this is cross chaining but should shift into gear.
The shifter lever (ST-RS505) feels like it is hitting a stop when I am shifting into the largest cog on rear. It isn't the rear derailleur stop because It will shift into it when adjusted but makes all other shifts worse. Is there a stop limiter in the shifter?
Any advice on what is causing my problem. It is almost like the indexing is off. I can choose to adjust to shift into bottom gears or top gears just not both?
Quoted: 2952 Post(s)
Liked 3,106 Times
How many miles on the chain and cassette? When's the last time you replaced the cables?
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Your description of the problem sounds like a bent derailleur hanger. Bike shops have a tool to accurately align the hanger with the wheel.
https://www.parktool.com/product/der...e%20%26%20Fork
New Chain. 4,300 miles on bike.
Replaced chain within last 500 miles. no change in shifting.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
This seems too easy to diagnose you need new cables and housing. If it does not shift back down this tells me that cable is getting friction and this is the obvious problem. The biggest culprit is the rear derailleur loop on the end going to the RD. Get good housing and good cables. Then report back.
Quoted: 6177 Post(s)
Liked 4,794 Times
Cables run on the outside bottom of the BB shell? Turn you bike over an make sure they haven't started sawing into the guide and binding. My 1990 era bike just ran bare cable under the BB without a guide and when I started having shifing issues I found the rear DR cable had almost sawed through the thickness of the shell.
Frayed cable can be an issue too. Look up inside the shifter.
