No ride today too cold
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4423 Post(s)
Liked 4,527 Times
Only be in the 30s today I don’t have the clothing, it was 71 yesterday. Not worth investing in cold weather garb since it doesn’t get cold here too often. The clothing I have will work with temps in the mid 40s but not the 30s.
Quoted: 5224 Post(s)
Liked 3,581 Times
yikes, that's quite the 40 degree jump!
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
FWIW, if it's a shorter ride, like under an hour, I've found that I can wear a sweater under whatever I'd have for the 40's and it's good for the 30's.
Life Feeds On Life
Liked 4,527 Times
It wasn't any warmer in Houston. I stayed inside too. Tuesday it was 81 and then Wednesday it dropped into the 30's.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times
We've had the same thing in Tucson. I'm set up to be good into the low 50's, below that I'm just going to wait till it warms up, maybe head to the gym instead, or go on a hike.
Like the OP, no point in spending a lot on cold weather stuff when I spend the majority of my ride time trying not melt from the heat.
I was working in the snow on Wednesday
Non omnino gravis
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
this from 3 days ago.
This of my south facing lawn. The house is at almost 800ft elevation.
Got a garage/project time after the
on Feb 3rd, when the first snow started on that same day afternoon/evening.
Then, only back to bike on 21st when most of paths and roads were cleaner.
Mornings are below 30 (now getting warmer). I am using my ski gloves to keep my fingers warm
Quoted: 8 Post(s)
Cold is relative, and you would be suprised how well a quality shell, with a longsleeve liner is overall. Light althletic pants work for me until about 29 or less. I use some cc ski/bike pants after that until it hits single digits. Low 20s means a thicker shell, with perhaps a fleece on top of a ls athletic shirt. I swear by neck gaiters, wool, and moisture wick. Hat thickness depends on temp, but i bought a rain snow cover for my helmet which helps. Wool hiking socks are a must. I live in CO, so i have tons of layering options though including different glove/mitt combos. It is more about bejng mentally willing to start the ride, after pedaling a bit, i never regret it.
Then there is wind but that's not such an issue on a bike since we generate our own wind and most of the effect of wind chill is seen between 0-2mph of wind speed. To stay warm, you have to first have good windproofing.
Riding in the cold is completely doable but it takes a lot of experimentation to figure out what works for you in the locale in which you ride. My biggest problem still remains in figuring out how to keep from overheating. For me, at least, I seem to have a harder time getting it exactly right and I either tend to slightly overdress which leads to rapidly overheating or slightly underdress which leads to getting cold fast. In the cold, it seems you swing between extremes much faster than when it's warmer.
Quoted: 659 Post(s)
Liked 595 Times
We have had a night at -30 and a night at -18. Highs today way up to 12f. Yeah, cold is relative. Maybe if related to penguins.
My cutoff is 30 degrees. In Atlanta those days are few and far between.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
In the mornings I use Burton snowboarding gloves. Some people have had good luck with Barmitts. It's been in the 20's here in the PNW, and a week or 2 ago it was in the teens.
I also wear standard cycling leggings & a pair of blasphemous Levi's or Wranglers over the top.
Wool socks are cheap. So are hiking boots or Neoprene booties. As long as I mention foot wear: Lake MKZ303's are pretty decent cold weather cycling boots. Pricy for sure, but worth every penny. Standard hiking boots & flat pedals work well too.
Don't get stuck in cycling fashion dogma. Standard hiking gear on close-out is plenty good enough.
I find rain gear doesn't ventilate enough for cold weather riding. It's too hard to regulate. It's weird though. I'm more miserable & cold when it's 37 & raining than I am at 17 degrees & dry.
Quoted: 874 Post(s)
Liked 2,288 Times
I hear ya'. Up here in Ventura County it has been an amazing winter. The hills are as green as Ireland! I still get out between the storms and only got caught in the rain once, so doing ok. I think we are way over 20" so far and I am not sure that it is over yet. Joe
J.
Quoted: 659 Post(s)
Liked 595 Times
Exactly. Same weather here. I'm not sure you can have a thread and get understanding where some think 30F is cold and others thing -30F is cold. One night about a month ago we had a 45 degree swing in temp from night to day -35F to +10F. What's cold? That 10F felt pretty warm at the time.
J.
J.
Quoted: 659 Post(s)
Liked 595 Times
My cadence is right around zero at the moment. Hoping for a snow ride on Friday before that storm hits Saturday night. We are getting that same junk.
