Road link with Rival22 12-40?
Quoted: 8 Post(s)
I currently run the following on my gravel bike:
SRAM Rival 22 46/34T
12-36 Cassette; 11spd
Rival 22 derailleur
Bought some property near Asheville, and looking forward to getting back into some steep gravel rides after a few years off the bike. In the past my lowest gear was 34x32 and not enough. Posted this in 2017 for the same dilemma:https://www.bikeforums.net/showthread...3#post19806333
https://www.bikeforums.net/showthread...6&goto=newpost
Eventually arrived at getting the 12-36 cassette working, going from 34x32 -> 34x36 but haven’t spent time with the change in the mountains since implementing it.
I am anticipating that I will still want an extra gear, something in the 34Tx40 or 34Tx42 range. It seems there are some new options out now that it is a few years later?
A key point is I have a left arm SRAM power meter, so I can’t jump to another vendor’s subcompact crank.
Entertaining some possibilities if I feel I still want another lower gear:
* The roadlink to allow for 4T extra clearance which should get me 40T in the back. I assume I have to be careful not crosschaining with my 46T front? Has anyone done this with SRAM? I’d then put something like a Sunrace CSMX8 11-40T 11spd on.
* Diving all in the 43/30x10-36 SRAM Force eTap. Price hurts.
Any thoughts?
Rival 22 derailleur
Any thoughts?
I live outside of Asheville. I've got a 42T front and an 11-36 on the back, and I've not had an issue getting up anything. I've got a 205 pound dad-bod and I have trouble getting in more than 3-5 hours a week these days, you'll be fine with a 34x36. I'd at least get out here before you make any big changes.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Rival 22 derailleur
Any thoughts?
Rival 22 derailleur
Any thoughts?
A Force 1 RD will allow up to 46t cassette. I would look towards a 42t low cog cassette, you might need to extra gearing at some point so why not just get it taken care of now.
I regularly ride hills in the 10%+ range. Sure on a road bike with smooth tarmac I can climb some pretty steep hills with a 34x32 low gear. But on dirt and gravel I want low gears.
Quoted: 8 Post(s)
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
A mid length cage derailleur should work with the 2x. But each set up is a bit unique when going beyond the published limits of the equipment. This is also based on my experience with Shimano.
As a vastly inferior rider to Ted King, I use a 36 front ring and 11-speed 11-42 cassette (and can easily swap in 11-46 if needed). I've ridden that up and down Alps with easy gears to spare. What I give up is big gears to hammer downhill - which I'd need for fast group rides, but don't need or even want on gravel adventures.
Rival 22 derailleur
Any thoughts?
Rival 22 derailleur
Any thoughts?
I have a Force 22 group set up with 46-34 front and 12-40 cassette, using a road link. It works great. No problem using the 46:40 ratio.
Quoted: 8 Post(s)
