Show your classic sports touring bicycle
#426
Would like to hear what Handlebars everyone is using!
#427
Quoted: 38 Post(s)
@mkeller234 that Fuji Finest is stunning
#428
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
#429
Quoted: 38 Post(s)
My touring Surly and my Eroica bikes all use the Nitto Noodle (Mod. 177) in 44cm. I like the engraving near the clamp, the fact it sweeps a little closer to you on the flats, but still has a rather classic profile. The subtle flare on the drops is also a nice touch without being so great that it stops looking retro.
#432
#433
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
However, my New Years resolution is to get out cycling with my daughter this year (she is 7). I also built a road bike for my wife. She has ridden with me before, so I expect she will join us this summer too.
Short touring has always been a someday item for me.
#434
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
#436
My 1987 Bridgestone 300 Sport touring, was put out for scrap, had bent rear wheel and derailleur dropout . Went through it and updated a few things.
#438
Quoted: 4510 Post(s)
Liked 6,374 Times
H**Y CRAP!!!!
Where in H**L did you get that man!
Between you, @mpetry912, @pcb and @obrentharris, you'd think anyone could get their hands on one.
That is so awesome.
That is so awesome.
Likes For merziac:
#439
The normal red (Tigra)
The yellow (Chiorda)
The orange (Mondia)
The gold (Tigra)
The dark red (Mondia)
#440
Quick photo of my 1980 Peugeot PH8M after dynamo light install. It's my daily driver / randonneur / do-it-all bike. Built from Carbolite 103 tubing, so longevity should be more than built-in.
I'm pretty sure if I ever need to replace this, it's going to be a custom build with exactly same frame geometry, as this is spot on for me.
#441
Quoted: 5888 Post(s)
Liked 3,471 Times
#442
Liked 3,471 Times
#444
Quoted: 1854 Post(s)
Liked 663 Times
1952 Rudge Aero Special, a classic British Sports tourer
This is a Clubman-style bike made by Rudge (has the white hand of Ulster on the head tube!). They were owned by Raleigh at the time. With sibling models in Raleigh and Humber branding, they were made at Raleigh's huge plant in Nottingham. The Raleigh was rather famous, the Super Lenton. These were Raleigh's top model in the road performance line, save the special-order Raleigh Record Ace.
Features:
all-531straight-gauge frame, pinned brazing
laid-back low-trail geometry, fully lugged
mainly aluminum parts, except hubs, chainset, chain, stem, seat post, and pedals
S-A A-W hub
27x1 ¼ rims and tires
48 x 17 main gearing
long-reach GB sidepulls
fenders (not shown)
Aluminum handlebars Sylvere Maes
Originally Broois B15 saddle, now showing a modern Brooks B17 Imperial with lacing.
Clubman bikes were made for performance, comfort, versatility, and durability. Riders used them for endurance rides, clubs, commuting, and just about anything else.
She's not built up now, all the bearings but the AW need overhaul. The rebuild wil probably have a TA chainset. I have high hopes for a great ride. I'm considering ways to provide a wider gear range, improve braking and reduce weight, but first I need to just make sure I can ride it.
I think these bikes pointed the direction for what we now call a sport-tour, providing inspiration for Raleigh and Dawes, and later Trek.
Features:
S-A A-W hub
fenders (not shown)
#446
Liked 663 Times
I'm hoping to have it rolling in a month!
#447
Quoted: 76 Post(s)
Liked 19 Times
What size tires does it run?
I've toyed with the idea of making a faux clubman out of a midrange 70's bike even if just for the looks all the serious cyclists would give it..
#448
Liked 663 Times
But I actually made a Clubman-style when I was in high school, around 1966. I didn't know what the word "clubman" meant, but the 10-speed thing was just beginning in Chicago and as an avid Lakefront rider I wanted to get with it. I had a mens' pre-Raleigh Phillips or Hercules 3-speed with a Sturmey Archer AW, that I bought from a neighbor boy maybe 5 years older than me - $12, a fortune! As riding went on I had the LBS put on a set of steel drop bars and later a Miller generator lighting set. The tires were the standard British 26 x 1 ⅜, but I don't know the correct designator today. After all that, all it needed to match the spec of the late '1940's Clubmans' like the Rudge Pathfinders, was Bluemels fenders (plastic, lighter but more fragile), a Brooks B17 or B15, and well, a frame made of straight-gauge 531. In some model years there were double-butted frames as well (see the blogging by Peter Kohler). There were some more exotic specifications as well: alloy rims, Sturmey Archer AM hubs (with medium spread of gear ratios), alloy shells, and even an alloy FM which was a four-speed medium-range IGH.
A similar conversion could be done with any Raleigh-designed 3-speed. Key features include a laid-back seat tube to properly install a Brooks saddle and a frame built for a Sturmey-Archer IGH.
If this bike is a good enough fit for me (seat tube is a little tall), I would want to hot-rod it! I would go for an alloy hub, alloy rims, seat tube, and stem. I'd also work on adding a granny capability, either make the TA into a 48/32 or add several cogs to the SA rear hub, and a rear derailleur. It should be possible to take 5 pounds off.
So this Rudge represents the next step forward for Rudge/Raleigh/Humber toward the 1962 Grand Prix, which had alloy hubs, 8 speeds, fully double-butted 531 frame (except the seat tube), and was very similar to the late-60's International. At least that's how I see it.
And BTW, this bike and others such WERE what serious cyclists used back in its day.
#449
Quoted: 76 Post(s)
Liked 19 Times
That head tube angle looks fairly conventional, but until you mentioned it I hadn't really noticed the seat tube angle. I can get by fairly well with 3 gears where I ride mostly. The couple of hills that would punish me are routes I only ride occasionally since they are on the way in to town and I usually head away from town when I leave the house.
#450
Liked 663 Times
Check out this in the C&V for sale: FS: 1951 BSA New Hudson Silver Arrow (23", 531 tubing)
The Brooks saddle, then and now, has a rail that is roughly 10 mm longer than the clamp of a modern seatpost, and a vintage seatpost. I can't say exactly how the seat tube angles were or are selected, but for me I like a deeper setback like this, if I want to use a Brooks. Earlier Club-styles were deeper yet.
The head is conventional, 73 degrees.
For me what's important in gearing is having a gear I can use. That Hercules with AW had a gear for every occasion I needed, considering my teenage legs. Now at 65 I think I need more range, but I think frame dynamics might have something to do with it, within limits. In my area of Michigan we definitely have hills where I need a 35" granny, but I just want to see what I can do. British champions rode the full length of the United Kingdom, from the north end of Scotland to the southeast end of England (Land's End to John O'Groats) on gearing narrower, hence not as low as, what a Sturmey AW affords.
