Chainring on a Tern Verge N8
Old 01-21-19, 01:35 PM
Jigote
I own the older model of the Verge N8, and I'm thinking of changing the chainring (actually 52t) for a bigger 56 or 58 t litepro. If I buy the new chainring is there anything else I have to take care of in order to make the swap?.
Jigote is offline
Old 01-21-19, 01:55 PM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
Most likely will have to make the chain longer. Sometimes yes and sometimee not necessary. Roger
rhenning is offline
Old 01-22-19, 11:45 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Probably a good time to renew/replace, the chain and hub cog (s) at the same time ..
fietsbob is offline
Old 01-23-19, 10:06 AM
Jigote
Thks for the tip
Jigote is offline
Old 01-23-19, 11:25 AM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
Think about the chainguard if you care about pants not getting stained. The one you have on 52t will not transfer to a bigger chainring. You either need to get a chainring that is designed to work with a guard and this is not common in the intended size (unless you get some ring made specifically for a folder) or get a tad heavier guard that mounts onto the same holes as the chainring. Litepro produces such guards, but you have to make sure that you get right bolts too. Some vendors send guards with the needed long bolts for mounting and some not.
2_i is offline
Old 01-28-19, 10:16 AM
Jigote
Great advice, thank you very much.
Jigote is offline
Old 08-02-19, 11:56 AM
Jigote
Update: went for 58t, new chain as well, everything works fine, very satisfied.
Jigote is offline
Old 08-11-19, 01:40 PM
biker8989
58t is the best options
biker8989 is offline
Old 08-12-19, 05:35 AM
tomtomtom123
Quoted: 350 Post(s)
Liked 122 Times in 90 Posts
I use 44t on my 406 rims.
tomtomtom123 is offline
TromboneAl
Bicycle Mechanics
23
09-30-13 10:02 AM
JAJ0404
Bicycle Mechanics
4
09-16-12 07:49 PM
Oramas
Singlespeed & Fixed Gear
23
04-16-11 09:03 PM
Ryrog
18
03-04-11 05:35 PM
dbwoi
9
10-07-10 03:46 PM
