Cone adjustment
Quoted: 5 Post(s)
Liked 37 Times
Cone adjustment
I've read this somewhere and I'm wondering if its correct, When adjusting the cones for the hubs to leave a tiny bit of play in it so when you tighten the quick release it will illiminate the play. Is this correct?
S'Cruzer
yes. and its a just a hair. first few times, you'll probably find you want to redo it until its right
Curmudgeon
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Here's all you need to do it: Read the text, and follow the embedded link to the Park Tool site for further information.
Wil's way
HTH -
- Wil
Wil's way
HTH -
- Wil
Quoted: 5833 Post(s)
Liked 2,664 Times
Keep in mind that hub bearings come in 2 general classes, the angular contact traditional cop/cone bearings which need to be adjusted for absolutely zero play, and radial contact typical of cartridge bearings, which should be left with a bit of axial play (radial play is not adjustable).
The goal is to end up with correct adjustment for either design after the QR is tightened, so you start just slightly (very slightly) looser to allow for some compression of the hollow axle.
FB
Chain-L site
FB
Chain-L site
This is because the hollow axles bow a little under compression. I seem to remember reading a Sheldon page on which he showed a tool he had made using an old QR. It had some low profile spacers - so you could clamp it and load up the axle - but still get to the cones to adjust them.
2/3 way down this page, heading [h=2]Special tool for rapid cone adjustment under load[/h]
: https://sheldonbrown.com/cone-adjustment.html
Nutted axles should have the preload before they are installed because the axle is not compressed.
Quoted: 41 Post(s)
I have also learned this in many guiding articles. But I am confused when I check on new or nos hubs and wheels at LBS. They are factory-adjusted without any tiny play when off the frame.
Really Old Senior Member
That's just the way they are from the factory. (not always, but typically)
Quoted: 18398 Post(s)
Liked 4,525 Times
I've always just adjusted the cones to how I want them before installing.
However, perhaps you could add a couple of thick washers (5mm axle spacers?) to the ends of the axle, and clamp down the skewers, just to see if everything is perfect.
Bolt on axles don't significantly compress the axle.
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times
I adjust my C-record cones on the bike, tighten off the bike, and re-check on the bike.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes, some Campy hubs had split adjustable cones that allowed you to do the final adjustment with the wheel fully clamped in the dropouts and tighten the cone until the play at the rim just disappeared. Then you locked the cone in place with a set screw that pinched the sides of the cone together. A great system and too bad it wasn't more common.
Quoted: 939 Post(s)
Liked 5 Times
I can make them free-spin just as long as the very best sealed-bearing hubs. Don't know that it really gains anything, but it feels good.
Quoted: 4218 Post(s)
Liked 3,903 Times
I believe it is the carrier of the cone or bearing that is split, otherwise the balls would be riding over the split and erode the ball track there. Chris King has a similar system, Mavic's just uses a friction fir between the carrier and the axle.
But the goal of a free as possible bearing with no (angular contact) or minimal (radial contact) slop is a real benefit to bearing life. Regardless of whether a rider will feel it as they ride. Andy
Liked 2,664 Times
The system was borrowed from the original design of threadless headsets. It uses a split centering cone to locate and adjust the bearing's inner race.
FB
Chain-L site
FB
Chain-L site
Liked 1,096 Times
Right. It isn't the actual "cone" that's split but what amounts to a an adjustable compression ring that pushes on the insert that is the true cone. Nevertheless, it's a great design.
Quoted: 101 Post(s)
Liked 49 Times
Zombie thread walks the Forum.
Still stupid and seriously neglected..
Liked 3,903 Times
Liked 1,096 Times
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
I never worry about leaving play. I believe the issue is over-rated. Your observation about factory settings suggests as much.
Liked 1,096 Times
Well, us fussy types consider those hubs as too tight as assembled and usually check both for adequate lube and readjust the bearings before putting them into service.
Mechanic/Tourist
Believe what you choose, but the factory "adjustment" is often extremely tight, rather than just not having play. I have seen hubs/cones damaged because they were never adjusted when first assembled.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Hub overhaul, the OCD way:
Bicycle hub overhaul - Cycle Gremlin
